05-21-2024, 05:14 AM | #57 | |
As I'd mentioned before, changing your 'CAI' would then need a re-tune of your MAF frequency table. |
05-21-2024, 06:33 PM | #58 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
05-22-2024, 06:31 AM | #59 |
I've had at least 1/2 dozen or more Roto-Fab intakes on multiple vehicles, and I've always run the dry filter. It will make all the HP your engine will provide. You never have to worry about over oiling your filter when it's time and oil getting on the MAF. Maybe if you live in a really dusty area or on a gravel road you might consider an oiled Roto-Fab. My 16ss made 850 plus Rwhp and my 22 Lt1 made 707 with a dry filter. Those are my proven numbers.
