01-22-2023, 04:29 PM | #57 |
The DWS 06 Plus is an all-season tire while, the PS4S is a summer tire, so they don't compare directly. The PS4S has an A/S variant, too, it's in the same quality ballpark as these Contis (and similarly there is the ExtremeContact Sport that compares favorably to the PS4S, too), but apples should be compared to apples.
01-22-2023, 05:37 PM | #58 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
I was thinking if I lived in Indy in January I would not want the summer tire .
01-22-2023, 06:39 PM | #59 |
Drives: 2022 Camaro SS Convertible Indy 500 Join Date: Apr 2009
I ran the Continental DSW06+ on my Scatpack. Ran 315s all around. They were a really nice tire. I drive my Camaro 3-4 times a week. If weather is really bad it stays in garage. I can get a decent deal on the All Season Continentals or the All Season Michelin Pilots. I don’t really need a summer only tire. People say the ride quality with non run flats is much nicer than the Stock Run flats. Just not sure it’s truly worth switching the tires yet. I haven’t had any issues yet with the run flats but then again I haven’t had my car very long or driven in nasty weather. They seem to stick pretty well once they heat up some. Tough call.
01-22-2023, 06:55 PM | #60 |
I ran my run flats out at 28 k and got non run flat summers. The car drives way better. 1.3 degree negative camber on front gives better front grip in corners. I don't have a problem with rear grip , v6.
01-22-2023, 09:15 PM | #61 | |
In my specific case, I found the stock Goodyear runflats so bad in wet and rainy weather, especially under 65 degrees, that I just wasn't willing to live with them any longer. One can easily get surprised by downpours around here, even if the weather is fine when leaving the garage.
01-23-2023, 08:02 AM | #62 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Assuming this will be your only set of tires (i.e. you won't have a separate set of winter tires), then either of these would be a great choice. They are the two best performance all-seasons out there right now. I believe the PS4S AS is a little better on snow and ice and the DWS06+ is a little better in the dry and wet, but review the Tire Rack comparison test to make sure I'm remembering correctly (be sure to check their charts for dry/wet as well as ice/snow, which are two different pages). I have no experience with the OE Goodyears, so I can't give you good advice as to whether you should stick it out with them for longer or not. I do agree that either of the above tires will ride better than the runflat OE tires, though.
Matt Miller
2020 SS 1LE |
01-23-2023, 09:30 AM | #63 | |
Tags |
all season, summer |
