03-14-2019, 06:18 PM | #43 | |
Drives: 2018 Mosaic Black Metallic ZL1 A10 Join Date: Sep 2017
V4 DSC Controller
03-14-2019, 06:23 PM | #44 |
MCFLY
Get with us on what data to select in the record feature, and practice it a few times before you go. Nothing like being belted in, and can't reach laptop when you remember to record data, lol!
03-14-2019, 09:10 PM | #45 |
Drives: 2018 Chevy Camaro ZL1 M6 Join Date: Oct 2018
sucks that wifi is going away, so I guess cable will do
great info guys, thank you for joining.. big thanks to MadMotorMagazine so the ZL1 map is based on the SS 1le? perhaps that may explain the soft settings in the comfort zone... here is what I changed to remedy that: Touring mode - G Comfort Parameters - default rate from 1 to 7 (% of normal calibration) ; sensitivity - went from 20 to 17 (how quickly it comes out of comfort zone); G rate max - went from 35 to 30 (3.5Gs to 3.0Gs below which the comfort mode is on) Sport mode - default rate - went from 1 to 10; sensitivity - stayed at 15; G Rate Max stayed at 30 Track mode - default rate - went from 10 to 15, sensitivity - stayed at 15, G Rate Max - went from 30 to 25 now on the street the car is simply amazing!! comfortable, compliant, don't want to stop driving where as before (the tuning revision) I was a little annoyed after a 30 min drive... again, this revision has nothing to do with track driving... only straight no real maneuvering driving track impression were: insane braking ability, better than before somehow great corner entry good balance mid corner (neutral)... perhaps the car has always been this way but in the last session after the DSC install it was very noticeable and confidence inspiring, and track conditions were horrible coming out of the corner a little better than stock but there seems to be a lot of room for improvement... 2nd gear exit is still rather sketchy on the stock non-R 20" good years **** not sure how to do deal with that yet... planning on going to at least the ZLE Spec R Good Years or something similar Perhaps after the tire change I could use a little help with the tuning on that part Last edited by DOHCVTEC; 03-14-2019 at 09:21 PM. |
03-15-2019, 07:14 PM | #46 |
MCFLY
TRZO6, glad you read the novel, sorry bout not properly spacing for your reading convenience. I'll gladly refund your purchase price.
I can see my ACTIVE reference missed the mark, I should have said, "OEM controller is active, DSC Sport makes your system ACTIVE!" The DSC Sport controller is an open-interface suspension control module with lot's of processing power, unlimited tuning capabilities, and takes a driver's approach to the way it functions. The V4 has dual processors ; ) DSC Sport utilizes more data for input, to control dampers in a way that mimics racing shocks on speed, and does what the OEM controller cannot do, or it wouldn't require replacement, we'd just retune like an ECU with software from HP Tuners. Anyhow, that's my rational for active vs ACTIVE, just different approaches to function and performance. OK, that's about all I've got to say on that, but if you complain about my spelling or punctuation, I'm taking you off my Christmas card list! |
03-17-2019, 04:23 PM | #47 |
Here's a DSC controller question:
Can I connect the controller to my laptop without it plugged into the car?
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
03-17-2019, 06:02 PM | #48 |
yes, wifi, but the guys at DSC no longer want you to do it.
Fellas, I have an update for you, and possibly not a not a good one I need to speak with DSC first, before I update We shall see |
03-17-2019, 07:46 PM | #49 | |
Maybe I could reframe my question: DSC controller on my desk. USB connected to computer. Will it work? Or must it be connected to the car too?
03-17-2019, 07:59 PM | #50 | |
Drives: 2017 1SS 1LE Join Date: Aug 2017
Also curious about updates.
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers |
03-17-2019, 08:12 PM | #51 |
Ok thank you. Been chasing a connection error.
03-18-2019, 12:58 PM | #52 |
MCFLY
F1FTY, I prefer to have controller out of car to update firmware. Most connection errors are due to having multiple usb ports on laptop, and not having it set to the port controller is connected to. On my laptop, I use port 3, and make sure every time I plug in, it's on that port, or I'll get a connection error. There's no automatic connection to figure it out and set port for you.
03-18-2019, 12:59 PM | #53 | |
I'm running into this issue with the laptop...the driver installs correctly and the port on the driver matches the port in the Tuner software, yet I cannot get a connection on any of the USB ports. I guess I need to look up what the port number is for one of the USB ports and change the driver and Tuner software? Note: I'm doing this just to double-check that my firmware version is the latest for the Camaro. I have the V4 controller but the latest map listed on DSC's site says V3 so i'm curious about that too.
03-18-2019, 01:01 PM | #54 |
MCFLY
Chris V, Camaro V4 firmware update is so controller will work on new models of Camaro. Isn't necessary for the V3, or a V4 that's already installed and working on a 2018.
03-18-2019, 01:05 PM | #55 |
MCFLY
Yes, you select the port. First time I messed with a connection error, I switched usb ports until I found the one that worked, and done. Sometimes people get lucky, plug in and it works, the n next time use a different usb and nothing... not realizing you set the port number and it stays there until you change it. Then you've got to remember to plug in on that port each time.
03-18-2019, 04:52 PM | #56 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
On the V4, I would hold judgment if someone offered a free 7 day trial to test on various streets. If I was sold after 7 days, I would buy it.
But it would need to be dialed in from the get go and not something I would have to play with. I want a true plug and play and measurable damping improvements results.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
Tags |
dsc controller, dsc sport, mag ride, zl1 |
