08-09-2021, 09:19 PM | #43 | |
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 08-09-2021 at 11:51 PM. |
08-11-2021, 04:27 PM | #44 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
Another vote for ctek here!!!
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
08-19-2021, 04:18 AM | #45 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Coming back to that because I had this happening again last night while I was doing maneuvers in order to park the car. Switched of the engine and on again and issue disappeared
Mosaic black 2018 Camaro 2SS A8 (sold) |
12-13-2021, 10:19 AM | #46 |
Makis
...And reporting back again. I didn't have the intermittent power steering loss and the "Service Rear Axle" message for the last 2-3 months. However, all of a sudden, I started having both the intermittent power steering loss and the "Service Rear Axle" message on the dash again several times during the last week.
This time I also noticed that when those two things happened, the seat memory was lost as well and, on top of that, the window would drop a couple of inches and I would have to roll it down and up again as if I disconnected the battery for a few minutes. I also noticed that when I was trying to start the car by pressing the start button, I could only hear a click, the engine wouldn't turn over and lights on the dash would go dim. I was able to start the car after a couple of tries. I concluded that my battery was dead and I was about to buy a new battery (which I might do eventually), but all this convinced me that there was something wrong with the battery connections somehow. I decided to start by using a multimeter to check my battery's voltage and that's when I noticed that the battery connector in the trunk was not sitting tight on the + pole and that it was sort of bent. I was actually able to rotate the connector easily on the pole with my hand. I removed the connector, I straightened it with a pair of pliers, then I put it back on the battery and I tightened it. This seems to have solved the problem overall. No power steering failure, no Rear Axle message on the dash, no power seating memory loss and no engine cranking failure. I drove the car for a couple of hours and everything seems fine. So fingers crossed it was just a loose battery connection. Will report back if I notice something odd.
12-13-2021, 01:51 PM | #47 | |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
12-13-2021, 02:21 PM | #48 |
Thank you Al Oppenheiser!
Yes you pull the "carpet" aka fabric coated plastic side panel down. It's stiff, but flexible enough to bend down out of the way at normal temps (i.e. not cold). Might have to loosen up the plastic trim, but if you get the pins loose you may be able to just slide it down. This is easier on the vert: just 2 push-pins and no top trim, and if you raise the tonneau you can get a better view.
12-14-2021, 08:07 PM | #49 | |
Drives: 2001 Camaro Join Date: Jan 2018
01-07-2022, 05:14 PM | #50 |
Drives: 17 SS 1LE Join Date: May 2020
Any other reported solves
For this? Mine is doing all of the above plus a dash flicker and pulsating AC/license plate lights. Would like to diagnose before I just drop off at dealer. Battery tested great. |
01-08-2022, 02:53 PM | #51 | |
Drives: Chevrolet Camaro, Ford Mustang Join Date: Oct 2019
Best regards, Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair |
