Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 06-15-2016, 11:04 PM   #43
Stormcloak
slower than you
Stormcloak's Avatar
Drives: 2012 C6 Z06
They're nice to have, but as said, the positioning is awful. If I had the motivation to do so I'd take that panel out, and make some sort of custom panel where the radio is.
But I don't, so I won't
Stormcloak is offline   Reply With Quote
Old 06-15-2016, 11:33 PM   #44
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Anyone who drives a ZL1 and is looking at the boost gage while under hard boost is crazy.....
No way would I be looking down while WOT in my ZL1.
I use Dashlogic to put the boost reading up in the HUD.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 06-16-2016, 07:25 AM   #45
ClawSS
High-tech Redneck
ClawSS's Avatar
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8
I check gauges before I move the vehicle or when stopped and running. Either in the morning after a cold start, at every stop light, and just before I shut it off. I like to see that things are where they should be. If I needed to monitor something while driving (boost, AFR, Fuel Pressure, etc), I'd get the info up into my pillar or dash area.
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning.
ClawSS is offline   Reply With Quote
Old 06-16-2016, 09:51 AM   #46
DFWZ28
DFWZ28's Avatar
Drives: 2010 SS
I love where the gauge cluster is located.....but I am 56.
DFWZ28 is offline   Reply With Quote
Old 06-16-2016, 10:00 AM   #47
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
I agree with this 100 percent, I like the guage pack and it gives the car a different look than all the other cars on the road, but it's very beneficial having boost and afr in the hud with dashlogic
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 06-20-2016, 07:10 AM   #48
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Originally Posted by scandata View Post
Thanks, I'll have to look into that and make sure it won't somehow cause warranty issues. Selling it would help pay for the cost of having it removed.
No need to pay to have it removed, simple task ... lift straight up on the back facing part of the silver trim and the clips will release. Then working forward pull up on the side edges of the silver trim. The front facing edge is held in by a 2 plastic horizontal pins, last step is to slide the assembly back slightly to disengage the pins. And then there is one quick disconnect plug on the harness for gauges, power outlet, and stability control switch. Leisure pace it takes about 3 minutes.
Here is pic of underside (borrowed from forum) 5 white clips shown in right half of this pic, sixth clip is missing), the two horizontal pins are on far left running off the picture.
And here is a video from Phastek that shows the connectors:
Here is one that shows steps in detail and complete disassembly once out of car.
The replacement piece sliver trim with the coin tray you probably could get for free from someone that took that out to install the gauge pack.
Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 06-20-2016, 11:29 AM   #49
Baba
Baba's Avatar
Drives: 2011 Camaro 2LT RS Convertible
Baba is offline   Reply With Quote
Old 06-26-2016, 05:29 PM   #50
Rocky1974
Rocky1974's Avatar
Drives: 2010 RJT 2SS M6 Camaro
I'm wondering why they put the 4-gauge cluster way down behind the shifter. If there's a reading you have to monitor immediately (meaning you don't have time to click through the DIC to find it), I'd think it would be a situation where you wouldn't want to take your eyes that far off the road to read it. Seems like they should have put them closer to the dash, or even along the pillar. I'd rather have that space behind the shifter open to store sunglasses and such, like it is on the 1LT.
As already been stated many times, these gauges, as are many of the styling cues, are a throw back to the 1st Gen, especially the '68-'69 cars. My first Camaro was 1969 COPO 427 in 1974 and I've been a Camaro/Firebird owner continuously ever since. So, for me it was one of many things that made a 5th Gen a must have. Yes, they are not in an ideal location for easy viewing. But having gauges in your line of sight is not nearly as important in modern cars as it was back in the day. Actually there's no need to monitor them constantly at all. If any parameters get out of tolerance, you will get a chime and a Driver Information Center message and you can check the gauges then. Actually, that's how they get away with building some models without them.
Originally Posted by Kopterman View Post
Not at all! The mylink does not hang down lower and block the view.
I can see them perfectly fine.
I don't know where you get that. The My Link absolutely hangs down lower and blocks the gauges. That's one of the reasons that I couldn't understand all the rush to upgrade to My Link. It's nice, but you have to give up your CD player and you block your gauges. That might be a good trade off for some people, but it's certainly not for me.
I have friend who was looking for a 5th Gen last year and he asked me for advice. I told him to get a '12 because they had a lot of improvements over the '10s and '11s and no My Link. He wanted to know what the problem with My Link was and I told him that there was no CD player and it blocks your gauges. He took my advice and bought a '12.
He, in turn, talked one of his buddies into a 5th Gen. His buddy bought a new '15 2SS w/My Link. The last time I talked to him he told that he'd gotten the opportunity to drive the '15 and he was so glad he'd talked to me and bought a '12, because he couldn't see the gauges in the '15.
Follow-up, in case anyone's interested in the warranty aspect (copied from the warranty sub-forum)
I emailed Chevy to ask if removing it would void my warranty. As I half-expected, I didn't get an answer. They said I have to take it to a Chevy dealership and have it looked at by a mechanic. I called the number below and got the same answer. She said that they have to check the vehicle and make sure there's nothing else defective that might cause an issue with removing the gauges, which makes sense if they want to be sure they're covered. I'm due for an oil change, so I'll just ask about it when I get that done. If the dealership wants to charge extra to give me an answer, I'll just remove it and hope an issue never comes up, or see if they do it for a fee so it will be on paper that it was removed by certified a Chevy mechanic.
THE EMAIL RESPONSE FROM CHEVY:
About your inquiry, we are sorry to inform you that we at the Chevrolet Customer Assistance Center are not in the position to advise technical information. The reason for this is that we cannot physically see the vehicle, and might provide you inaccurate information that may cause future concerns which may add to your inconveniences. At this point, we will need to refer you to a Chevrolet Dealership as these are the right people that are technically trained and knowledgeable to assist you with your query.
Before arrangements are made with the Customer Experience Manager at the Chevrolet dealership, we will need some additional information.
Daytime and Evening Number
Best time for contact
Mailing Address
Vehicle Identification Number
Current Mileage
Preferred Dealer to work with
For your reference, the Service Request number assigned to your case is 8-2164863997. Please refer to this number on any future correspondence about your case.
If you prefer to expedite the handling of your concern, please contact the Chevrolet Customer Assistance Center at 800-222-1020. Customer Relationship Specialists are available Monday through Saturday from 8:00 a.m. to 9:00 p.m. EST.
Thank you again for taking the time to contact Chevrolet.
Sandra
I don't know why you would do this. The gauges are a plug-n-play option on the cars that didn't come with them, so they would an unplug-n-play option on the cars that did come with them. If you remove them and replace them with the shifter bezel/tray assembly from a 1SS, no dealer tech would even notice. It would take real Camaro enthusiast to even notice that you had a 2SS without gauges.
2010 RJT 2SS M6, Kooks Long Tubes, NPP Exhaust, CAI Cold Air w/Jannetty Scoop, RotoFab Washer Bottle, Elite Engineering Catch Can, MGW Shifter w/ZL1 Shaft and Knob, 2015 SS Sedan Steering Wheel and Air Bag, 2012 Heater Hose Conversion, 2012 Power Seat Conversion, RS Head Lights,Gen5DIY RS Conversion Harness, LED Fog Lamp Bulbs, Backup Camera Kit, NLP Spoiler, SLP Splitter, ZL1 Rockers and Diffuser, Color Matched Shark Fin, RS Roof Mouldings, Painted White Stripes, WCC LS3 Emblems, Heritage Grille and Blacked Out Tail Light Panel w/Retro SS Emblems, 416 RWHP, 411 RWT, Tuned by BlueCat.
Rocky1974 is offline   Reply With Quote
