TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LLT Engine, Exhaust, and Bolt-Ons
Old 08-04-2009, 10:54 AM   #43
Primus
2G1FF1EV0A9113319
Primus's Avatar
Drives: 2010 1LT/RS 6MT
Originally Posted by jschuler View Post
But is it possible to tune the 2LT, add a cold air intake and exhaust in order to squeeze a few more ponies out of it? How much would it cost to do this? Because I'm looking for a way to get a little bit more power out of my V6 (not the SS by a long shot) and keep the gas milage. Does anybody know of the brand of parts I should get if this works? I'm quite the rookie here.
There are plenty of threads on this. As far as CAI, it looks like Airaid makes a good one. Not sure how much info we have on it. Also, any cat-back or axle back exhaust should boost your HP slightly as well as fuel efficiency. Combined you might get around 20HP. As for a tune, it seems nobody has a proven method for tuning the DI LLT in the V6 yet. It's coming, we just haven't seen results yet.
2010 Camaro 1LT/RS M6 Black
1100: 10/13/2008
2000: 4/02/2009
3000: 4/08/2009
3300: 5/14/2009
3400: 5/21/2009
3800: 5/28/2009 VIN: 2G1FF1EV0A9113319
4000: 5/28/2009
4150: 5/28/2009
4B00: 5/28/2009
Delivered: 6/10/2009
Primus is offline   Reply With Quote
Old 08-04-2009, 11:07 AM   #44
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
Originally Posted by calflan View Post
O.K. puttin this question to bed :
Eh, not quite...but nice work anyway!
Of the 15ea. Z28's offered over the past 34 years of Camaro history, only 4 have had more power than the 2010 V6.
Of all the 53 engines offered, only 11 have had more Horsepower than the 2010 V6.
The SS, at 426 HP, is amongst the top 3%.
Actually, the 426HP SS is probably the most powerful one. The horsepower standard has changed a couple times...
http://en.wikipedia.org/wiki/Horsepower#SAE_horsepower
Originally Posted by Primus View Post
You really need torque numbers though. I'm not sure HP has much meaning compared to torque.
Agreed. That leads us down the road a little further, where we can then say you need dyno charts to see how much torque there is at idle when you take off from a red light, etc. Then there's the question of the gear ratios, drivetrain losses, how sticky the tires are...we can follow that discussion forever and never get anywhere.
What we really need for a numeric comparison over the internet is results. So, how about some 0-60, 0-100, and 1/4 mile times for that long list of Camaros?
Wait, that sounds like a lot of work!
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
Originally Posted by CamaroSpike23 View Post
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 08-04-2009, 11:43 AM   #45
oldag92
oldag92's Avatar
Drives: 2010 2LT/RS - SIM
Sorry I don't have the time to put it all into a nice clean post, but the link below will take you to a page that has the HP, torque, 0-60 times and 1/4 mile times for basically every Camaro up through the 4th gen. You can see that as far as performance is concerned, our new V6 has PLENTY compared to the V8s of prior generations.
http://musclecarfacts.net/camaro-statistics.html
oldag92 is offline   Reply With Quote
Old 08-04-2009, 03:49 PM   #46
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
You have to note that those numbers would be faster if they were on todays tires. They were spinning on skinny bias tires.
My brother had a 396/375 Chevelle with a 4:11 and thought that the clutch was slipping, it was the tires.
PieNsky is offline   Reply With Quote
Old 08-05-2009, 03:32 PM   #47
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
If anyone has doubt's for getting the v-6, you should read this. Wards 10 best engines. Sorry if posted before.
http://wardsauto.com/reports/2009/te...0_best_081219/
67 GTO is offline   Reply With Quote
Old 08-05-2009, 05:04 PM   #48
MontyCarlo
MontyCarlo's Avatar
Drives: 2010 2LT/RS auto IBM
Originally Posted by cstproductions View Post
Thanks for all of your help. Im sorry I wasnt able to reply sooner but my internet has been messing up. Anyways alot of you have convinced me that it has enough power but im still a little iffy. I know that with a couple mods ill be able to beat the genesis coupe which i was disappointed that it beat the camaro in some things. The only thing more I want in the v6 is more lower end torque.
If you want to beat the Genesis coupe specifically, work on the suspension. The Genesis' handling in corners is its only major advantage over a V6 camaro.
FAQs:
1. No, I do not have any strong opinions about the Monte Carlo.
2. Yes, I know what my name looks like.
3. Yes, but the medication helps immensely.
2LT/RS IBM/gray #21,895 ordered April 21st, delivered July 3rd
MontyCarlo is offline   Reply With Quote
Old 08-05-2009, 06:16 PM   #49
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Rather than posting just a section, look here:
http://www.albeedigital.com/supercou...0-60times.html
great site... I use it frequently! LOL
scrming is offline   Reply With Quote
Old 09-10-2009, 07:16 PM   #50
RyanotheDyno
Drives: 2001 camaro convertible
I haven't tested the new v8 yet but i know from the few other v6 and v8 models that the v6's are ever nearly as powerful. That being said, whether or not it has enough power depends on many factors: the driver, the location, roads, transmission, and all that good stuff. Yea i think the v6 is powerful enough, but don't try to compare it to a v8; compare it to other v6's. No it won't force you back on nice stretches of interstate or kick as hard when you floor it, but for the price and the and and weight its quite powerful. Most people don't have any reason to go fast, especially not on public roads (but we do it anyway cause it fun ). So through all of my ranting that didn't really have many points, yea it's powerful enough, just don't compare it to a v8
RyanotheDyno is offline   Reply With Quote
Old 09-10-2009, 07:46 PM   #51
67 GTO
13.453 @ 101.90
67 GTO's Avatar
It's rather simple, if you have doubts that the 6 will be enough just get the 8.
I'm fine with mine.
Old 09-10-2009, 08:23 PM   #52
Oshawan
Drives: Camaro
if you are driving a "normal car" or "van" then it's fast. If you already are in a sports car and want a camaro - go for the SS
Oshawan is offline   Reply With Quote
Old 09-12-2009, 01:44 AM   #53
acehole
Drives: mits lancer oz
v6 handles better drives better gets better gas milage and theres only so much horsepower you need to get a ticket with....
acehole is offline   Reply With Quote
Old 09-12-2009, 02:25 AM   #54
oilman63
rjt ordered 10-15 2ss
oilman63's Avatar
Drives: 2010 2SS badass camaro
I currently have ordered a v6 1lt automatic and will be upgrading in the future to get some more horses out of it. Ive thought about NOS but this seems like it would be bad for the pistons from what Ive heard. Anyways I recently rode in a v8 manual and the power in it was pretty amazing and my head jerked back everytime it shifted. So my question is for everyoen here that has a v6 or has driven one, does it have enough power to have fun with it? I know that it is very powerful compared to the other competing v6's but does it have that push back in your seat head jerk feeling? haha
No it doesn't have the glue me in hold on feeling.But it is a nice car.You can have some fun with .Put it on some juice you'll get glued.it'll void your warranty.
oilman63 is offline   Reply With Quote
Old 09-12-2009, 02:44 AM   #55
oilman63
oilman63's Avatar
Originally Posted by JesseJames View Post
Yes, and even the pennies with gas. Money saved will help him with a used/new SS with mods with a lower ins after the age of 25. I cant remember his age but remember reading his post awhile ago ( was it in the ibm thread) and the impression left was that he is still a young one.
The low end tq from V8s can be addicting ( some people hate it...noticably they where all women) and its definately missing from the LT/LS. Ontheotherhand, i've realized i drive more responsibly from take offs. The low end torque brings out the devil in many driver..including me. The LT/RS does need a little more tq for a proper fit ( 20's).
It does.I forgot I can be such an ass.especially people pushing my buttons.I'm to the point of not driving it as much now .I swear it's getting faster the more I drive it.The ss can definately get you in big trouble.I pulled a big no no the other day.I picked my son up at school.When pulling out I got in it a little,to merge in traffic.I never get in it if the cars not straight.Thank God I got a couple years under my belt.I got stickys on the back obviously they weren't hot because I hadn't been burning out ,I was just merging she started to go I got out of it got straight and just nonchalantly went on my way.It could have been very very bad.4100 miles .no tickets yet.
Old 11-15-2009, 03:34 PM   #56
cuspid
Drives: 04 z06 yellow
I have had 7 camaros/firebirds and 3 442's and 5 corvettes. 304 hp is more than all, but 2 of those cars. My 68 327 camaro was 210hp, My 85 442 was 180 hp. My 86 442 was 170 hp.
cuspid is offline   Reply With Quote
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 09:56 PM
Nitrous System ?????s PoleCat2SSRS2010 Forced Induction - V8 29 12-08-2010 05:55 PM
V6 Camaro Owners! 2010 V6 Zex Nitrous System now available! Kris@BMCPerformance Forced Induction 3 01-23-2010 02:41 PM
Well sunroof question answered (PIC) Black5thgen 5th Gen Camaro SS LS LT General Discussions 152 08-29-2009 10:23 PM
Turbocharge your way to efficiency.....and power! Mr. Wyndham Forced Induction - V8 20 07-06-2008 12:46 PM
