Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 03-22-2014, 06:47 PM   #43
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
Originally Posted by Jerry7297 View Post
I wanted to do what you are talking about also, but when you get the extractor you will see the studs are lower that the top of the hood. Check ou the hood.
this is my template over what you sent me. and what i created under the hood scoop. you think my hole will be to small or to big seeing that yours white part can be seen on mine?
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 03-22-2014, 07:08 PM   #44
mickmosh
Drives: 2018 Camaro ZL1
The opening in temp plate looks a little big. I couldn't see any foam when i did mine. I see in second picture u have tape to make up size?
I did make my cut out very tight and had to trim hood a second time for vent to sit level and line up.
mickmosh is offline   Reply With Quote
Old 03-22-2014, 08:44 PM   #45
Low RS
Low RS's Avatar
Drives: 2010 ''RS1'' my own package
yea the problem is that on the factory hood the scoop is recessed in the hood. but I think I have a step tool at the shop that I can do the same thing. if I do I will post pics of it when I do it.
2010 1LT A6, Hurst shifter and handle, 3pc rear spoiler, streetscene splitter, ss front end with ZL1 grill, ABL , footwell and cup holder lighting, ss cat back exhaust, Eibach lowering springs, custom engine cover, 4pk gauges, speedhut A pilliar pod and gauges, metra kit and kenwood stereo, 2014 ss hood scoop with stock rain tray, 3D Carbon fender vents, rear lighted bowtie, and ultra gauge.
Low RS is offline   Reply With Quote
Old 03-22-2014, 09:23 PM   #46
Jerry7297
Jerry7297's Avatar
Drives: 2018 2SS/ 1LE
The clear one I sent you the Inside of the template the "hole" in the middle is what you cut out. You can test fit it over your scoop. Your cardboard one is too big.
The edges need to be almost touching the sides of the vents that come down on the scoop.
Jerry7297 is offline   Reply With Quote
Old 03-22-2014, 09:45 PM   #47
Synner
Drives: cars
Cool, Just make sure you coat any cut edges with a rust inhibitor. My preference was Cold galvanizing paint.
Aluminum hoods don't rust...
Synner is offline   Reply With Quote
Old 03-22-2014, 10:15 PM   #48
Jerry7297
Jerry7297's Avatar
Are you sure they are made out of Aluminum? It looked like steel to me when I cut into it...
That would be nice if there was no worry of it rusting.
It not steel, duh... I did a magnet check. Thanks for the info Synner.
Old 03-22-2014, 11:26 PM   #49
Deftones
Deftones's Avatar
Drives: 2012 RS/SS LS3
It shouldn't rust but it can corrode.
Deftones is offline   Reply With Quote
Old 03-23-2014, 01:51 AM   #50
zkdreads
zkdreads's Avatar
Your template fits great thanks!
C-LO or Sonic
Old 03-24-2014, 04:18 PM   #51
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
How much are you getting for the template???
olblue75 is offline   Reply With Quote
Old 03-25-2014, 11:23 AM   #52
BigBlue2010
BigBlue2010's Avatar
Drives: 2010 Camaro 2SS/RS IBM A6
Just ordered my vent form GMpartsdirect. Should be here by end of the week. Excited to put it on, I have been wanting to put some sort of vent on this car since I bought it.
I am confused on the template. What line do you use to make the template and what do you actually trace onto the hood to cut? That is the only part confusing me about this right up. Otherwise, great work OP.
I might be bothering you during the installation process! Lol
VR,
Ryan
BTR N/A Stage IV, LS3 conv. w/ trunion, 3200 Circle D, ZL1 wheels(295/305), 3.91's, Kooks Stepped LTs, SW Retro CB, AirRaid CAI, VMAX TB, SLP UDP, 160 thermo, BMR goodies
BigBlue2010 is offline   Reply With Quote
Old 03-25-2014, 02:57 PM   #53
Jerry7297
Jerry7297's Avatar
VR,
Ryan
-I took one of the sides of the box it came in and cut it off.
-Turn the Extractor upside down and trace it on to the cardboard.
(There is a curve to the extractor. I did hold down the back and the front of it to the cardboard as I traced it.)
-Cut out the template.
-Then I measured .5" (1/2 a inch) from the outside of the template measuring in and mark it. Do that ALL the way around it about every 1 inch. a little closer on the front. )
-Then connect all of your marks then cut out the the inside mark.
-When cutting the cardboard make it easy on yourself and use a new razor knife blade.
Old 03-25-2014, 03:40 PM   #54
Jerry7297
Jerry7297's Avatar
Originally Posted by stt816 View Post
Looks great...but what's the deal with water going into the engine? Any solutions to that?
Been working on that....
Here is attempt one, Fiberglass. It would still work I just dont want to put in all the time to bondo it and all that. so today...
2nd attempt. Lexan from Home Depot. This fits fine and I think I am just going to Plastidip it and be done with it...
Old 03-25-2014, 05:18 PM   #55
Dexter9522
Drives: SS
^. Info. Me likey
Dexter9522 is offline   Reply With Quote
Old 03-25-2014, 06:12 PM   #56
Malvino
Malvino's Avatar
Drives: 2013 Chevy Camaro 2LS
Nice write up *purchases heat extractor* bwahahaha!
2013 Chevy Camaro 2LS:
Gloss Black Stripe Package::K&N Typhoon CAI::Xpel Tinted Tailights::Magnaflow Cat Back Exhaust::Xpel Tinted Side and Reverse Markers::RS Halo Headlights::Xpel Headlight Covers::LED Interior Light::LED License Plate Lights::Vented Engine Cover::Sequential Tail Lights::
Malvino is offline   Reply With Quote
