11-02-2012, 02:13 PM | #43 |
Drives: 2013 2SS M6 Join Date: Oct 2012
I picked it up! Some of my shifts were a little rough but I didnt grind gears or stall it on the ride back. I will admit I did stall it in my drive though. I can't stop smiling since I started when I showed up at the dealer this morning. Absolutely love this car!!
Pics coming when I get home from work |
11-02-2012, 02:19 PM | #44 | |
ROAD COURSE JUNKIE
11-02-2012, 03:05 PM | #45 |
Drives: V8 american car Join Date: Aug 2006
THIS is why the car comes with Hill Assist. They already know folks will come in to buy it and have never driven a stick shift
11-02-2012, 03:07 PM | #46 |
I wish mine had hill assist and I know how to drive a stick. Neat feature
11-02-2012, 04:02 PM | #47 | |
FOUR T 5
Drives: 2012 Camaro 45th Join Date: Feb 2012
I was in the same position. Had basically no MT experience. I managed to get it home without a stall, but the next day i stalled it half a dozen times 'practicing'
11-02-2012, 04:14 PM | #48 |
Drives: Currently 2015 Mustang GT manual. Join Date: Jul 2009
You'll be fine. Just be patient with yourself and the car and you will make it. It'll take a few miles to get back in the swing of things.
11-02-2012, 05:23 PM | #49 | |
Drives: '92 Chev K1500 + 2011 VR 2SS/RS LS3 Join Date: Sep 2011
Shortly after I got mine, I found a large empty parking lot one evening with just painted lines, no cement stops. I spent some time practicing coming to a stop in each row and then pulling up to the next. It also helped to practice backing up, if you try to shift one spot to the side from one row to the next a few times. Or you can just drive it around to get used to the clutch too. Have fun! |
11-02-2012, 09:08 PM | #50 |
Here she is! (I need to think of a name for her)
I spent all evening tonight just driving around town and getting used to the hills, intersections, how she handles in the turns with some of the bumpier intersections and such... Ive gotten pretty decent of holding it on a hill but Im worried that if I do that a lot (my city is nothing BUT hills) it will burn the clutch out pretty quickly. It seems we have a lot of hills not steep enough to trigger hill assist but still steep enough that if some one rides my ass I will quickly roll right into them. I need to get faster and getting it started I guess so I dont burn out my clutch. Couple questions: 1.) I'm used to a truck (s10 zr2 with 4.3L vortec) that ran consistently around 180 degrees. This has the needle On/Just-Past 210 constantly.... is that ok? 2.) When idling at a little the RPM needle twitches a bit.. when I first got it from the dealership it didnt do this at all. I guess it was just idling perfectly steady at the same RPM and now seems to be varying by ~100. Is this normal? |
11-02-2012, 09:28 PM | #51 |
Nothing to worry about it , press the left pedal all the way down , shift to 1 gear , right pedal a bit down till 4500 RPM on the dashboard , let the left foot up and holdown for your life , see , piece a cake .
11-02-2012, 09:53 PM | #52 |
Drives: SRT Yugo GT Super Sport with Manual Join Date: Mar 2012
Sounds like you are pretty screwed. Takes years to learn to drive stick.
11-02-2012, 09:55 PM | #53 | |
11-03-2012, 04:17 PM | #54 |
ROAD COURSE JUNKIE
[QUOTE=NoleLife;5767962]Here she is! (I need to think of a name for her)
I spent all evening tonight just driving around town and getting used to the hills, intersections, how she handles in the turns with some of the bumpier intersections and such... Ive gotten pretty decent of holding it on a hill but Im worried that if I do that a lot (my city is nothing BUT hills) it will burn the clutch out pretty quickly. It seems we have a lot of hills not steep enough to trigger hill assist but still steep enough that if some one rides my ass I will quickly roll right into them. I need to get faster and getting it started I guess so I dont burn out my clutch. Couple questions: 1.) I'm used to a truck (s10 zr2 with 4.3L vortec) that ran consistently around 180 degrees. This has the needle On/Just-Past 210 constantly.... is that ok? 2.) When idling at a little the RPM needle twitches a bit.. when I first got it from the dealership it didnt do this at all. I guess it was just idling perfectly steady at the same RPM and now seems to be varying by ~100. Is this normal? Ya mine runs at about the same and so did my 2010 Ya rpm varies about 100 rpm or so no biggie
11-03-2012, 11:22 PM | #55 |
Drives: 2010 SS/RS LS3 GFX Heritage grill Join Date: Jul 2012
You can do it. The manual is easy to get used to. the clutch feels a little different because it is a hydraulic activated not manual with linkage. Once you engage it a couple of times you'll do fine. Hold 1st until 3500 or 4000 rpm at least and you should by pass the skip shift.
11-04-2012, 10:24 AM | #56 |
Amanda
I just drove a manual for the first time in 2 years. I will say this much- the clutch on a Camaro is different from any clutch I have ever used! It doesn't take much to get used to except 1st gear.
