04-27-2012, 05:57 PM | #43 |
Too Many Great Choices
Drives: Grand Sport/Z07 Join Date: Jun 2009
04-27-2012, 06:12 PM | #44 | |
Drives: 1999 Blazer Join Date: May 2007
Clyde |
04-27-2012, 08:13 PM | #45 |
Drives: 2012 IBM 2SS/RS Convertible Bliss Join Date: Jul 2011
Don't care what place my car comes in your opinion. Only making 1000 makes them rare!
Not to mention how many GT 500s will be made? Plus you could use the press releases to launch the new GM performance packages. We all know, we can take our cars to Nicky or Hennessey and have engine upgrades done. The issue here is the "FORD GT500" can GM make a pony car equal to it? ANSWER: yes if they want too. . . Horsepower isn't the only question - it is a GT500 What is GMs answer? To stay in line with current 5gen philosophy just make the 2013 ZL1 666 horsepower |
04-27-2012, 08:22 PM | #46 |
juggernaut
2013 ZL1's will not see a power increase. and I think you've missed the point of the Z28.
no need to limit it to 1000. I'm sure the Z28 wouldn't be ordered as much as the ZL1 and the SS. |
04-27-2012, 08:55 PM | #47 | |
Clyde |
04-28-2012, 03:14 AM | #48 |
Drives: 2019 Camaro 2SS 1LE Join Date: Aug 2011
"To date" that is.
04-28-2012, 08:22 AM | #49 |
Downright Upright
Drives: Daily Join Date: Apr 2009
BTW, my "500 or so" number, above, refers to "naturally aspirated Clydesdales", not "quantity required"...
Build numbers? 5,000+ is our best guesstimate...100/State would be a good start, as far as delivering a "worthy message" to those Doubting Thomases faithful to other Brands... As to "attendance" on this Section, you will see the numbers swell when the announcement comes, so pull up a comfy chair and rest a spell...not too much longer now... Besides, the quiet is a welcome respite from the general dim, elsewhere, what with all manner of voices heard on all manner of angst and worry... |
04-28-2012, 09:15 AM | #50 | |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
The Camaro already uses a lot of high strength steel in it's construction. Chromoly steel wouldn't be used to replace body panels in a conventional sense. Unless you are proposing removing all the current structure and building it around a space frame or roll cage.......................hmmmmmmmmm is that where you are going??? I can work with that. Also keep in mind that high strength steels are progressively harder to stamp meaning they don't lend themselves to exterior panels, mainly structure. Camaro is heavy because it's big, not because GM cheaped out on low mass materials i.e. high strength steels.
04-28-2012, 09:55 AM | #51 | |
Clyde |
04-28-2012, 10:25 AM | #52 | |
juggernaut
04-28-2012, 05:27 PM | #53 | |
Chassis is either stamped steel or aluminium castings. The Corvette has the aluminium. Camaro I believe relys on stamped steel. You could convert those to chromoly tubes which might reduce weight, but I think I'd just jump to aluminium. But you could use Chromoly tube for upper and lower control arms.
04-28-2012, 06:49 PM | #54 | |
04-28-2012, 08:15 PM | #55 |
I am guessing but maybe 20 pounds per corner but that is only a guess. Did I mention that was a guess?
04-28-2012, 08:52 PM | #56 |
Drives: 1SS Join Date: Feb 2012
Just wondering why we are talking about Z/28's when GM is not planning on making one?
Are we just dreaming and wishing? |
Tags |
where's our z/28?? |
