Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Member Car Journals
Old 04-08-2013, 09:03 AM   #43
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Originally Posted by Nathan Moreno View Post
Next, lube the outside of the center pin and install.
No need for a lot of force. You can simply push it in with the palm of your hand.
Originally Posted by Apex Chase View Post
Your build is mind blowing. I would be lying if I didn't admit that I find myself strangely aroused after reading your threads.
I can see why
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline
Old 04-08-2013, 08:14 PM   #44
hcoll003
Proven Wicked Suspension
hcoll003's Avatar
Drives: 2010 Camaro 2SS/RS
Kudos Nathan, this build leaves me speechless! The work you have put into this car would cost over $20,000.... just in labor
hcoll003 is offline
Old 04-08-2013, 08:47 PM   #45
NC-V
NC-V's Avatar
Drives: cts-v
It would cost A LOT more than that! Even at a low shop rate!
NC-V is offline
Old 04-08-2013, 10:33 PM   #46
Moreno1
Drives: G5.R
That is some funny stuff right there.
Thanks Hcoll003!
Hey Kyle! I'd hate to think how much it would cost me if I were farming it out.
Quick update:
Rear Diff resurfacing
The first few pics gives an idea of were I started.
To remove the section in the red circle and get a perfect finish (Dremel will leave divots) I wrapped a piece of sanding paper around a a painters mixing stick and shaped it by hand.
And finally......... It's now off to the powder coater were it will be finished in a textured silver.
Before pic of the cover
And after.......
the cover will be powder coated texture black to match the oil pan with ARP bolts. The thing is I'm now thinking of dry sumping
Note: The areas where the bushings fit are polished to a mirror finish.
PS, sorry for the bad iphone pics.
Moreno1 is offline
Old 04-08-2013, 10:46 PM   #47
fastlane2010
fastlane2010's Avatar
Drives: 2010 camaro with fast lane stage 2
dude you are insane what would you do if the first time you take it out you have a jackass run a red light and t-bone you i think i would go o jail because i would kill him lol nah but for real this is amazing
12.4 in 1/4 at 117mph first time
custom 2tone paint fastlane stage 2 hydroformed carbon fiber cowl and cluster kooks headers and 3" xpipe with pypes axle back
fastlane2010 is offline
Old 04-08-2013, 10:51 PM   #48
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
That diff is a work of art!
Unbelievable job.
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline
Old 04-08-2013, 11:16 PM   #49
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
Looking at the pieces you are creating, it reminds me of Pagani and his attention to detail. I have nothing technical to add to you're thread but
christianmotox is offline
Old 04-08-2013, 11:22 PM   #50
SPCBA
Drives: pleather and Chiclets
holy crap i think you have outdone yourself...simply amazing. thats going to look great with the color scheme you have planned.
how much weight do you think you shed off the diff?
SPCBA is offline
Old 04-09-2013, 07:47 AM   #51
MANNYS2SS/RS
MANNYS2SS/RS's Avatar
Drives: 2010 Camaro 2SS/RS,LS3
Nathan you have some MAD TALENT. Your whole build, is a work of art, congrats.
LS-3, ProCharger D1SC
665. rwhp /562. rwtq @ 9.3 psi
MANNYS2SS/RS is offline
Old 04-09-2013, 09:43 AM   #52
snickerdoodle
Drives: 2013 1LE AGM 2SS RS M6
It's truly a shame that much of this work won't be seen as the car drives past :((((
snickerdoodle is offline
Old 04-09-2013, 10:33 AM   #53
hcoll003
hcoll003's Avatar
I'm wondering, with all that excess casting/material that Nathan has sanded off from each indiviual piece, would this actually translate to several pounds of weight loss???
hcoll003 is offline
Old 04-09-2013, 12:40 PM   #54
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
lol more than several, more like several hundred when taken in total with everything else he's doing. When he's done this car is going to be under 3,500 lbs; maybe even under 3,400.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline
Old 04-09-2013, 10:33 PM   #55
Moreno1
Drives: G5.R
LOL, I don't even want to think about it.
Unbelievable job.
Thanks guys!
Paganis are one of my favorite cars. Those are truly a work of engineering ART!
I'm wondering, with all that excess casting/material that Nathan has sanded off from each individual piece, would this actually translate to several pounds of weight loss???
That's the goal, 3,400 as it's going to be basically set up as a track car, ie, no AC, radio/speakers, rear seat, etc...
Here is a pic of the HH back from getting blasted. The only insignia I left was the Hammerhead logo.
Tomorrow it will go to get Ultrasonically cleaned. This is the same process used to clean surgical equipment. It took me a long time to find a shop with one as it's a really expensive piece of equipment, in most case $15,000 on up. Next it will go to the powder coater. The reason I'm not doing not powder coating first is because the ultrasonic dunk will hurt the finish. The goal for the cleaning it to make sure it's there aren't any metal shaving. Below id a picture of my block which I had cleaned as well.
A bunch of updates to come as I'm a lot further a heads than the updates. It just takes a lot of time to organize, sort and post and time is something I have little of right now.
Moreno1 is offline
Old 04-10-2013, 07:32 AM   #56
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS For Sale
Cool!!! This is moving faster than any other major project on C5 has ever moved. If you ask me. Maybe its just that we get an actual update, with pictures, on something new almost every day. I read C5 threads instead of watching the news haha.
vroomapunk is offline
