11-15-2023, 02:37 PM | #43 | |
Drives: ABM #93 Join Date: Oct 2018
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
11-15-2023, 02:42 PM | #44 | |
11-15-2023, 03:02 PM | #45 | |
^^^^ Nailed it bro!! We don't need another "seth21" or "scotavo".... Bye bye... We're here to help, not to listen to obnoxious replies from someone who says they ALREADY know..
11-15-2023, 03:55 PM | #46 |
Anybody that doesn't understand that the charging system is the same between the SS and ZL1 wouldn't understand a detailed discussion anyway.
11-15-2023, 04:00 PM | #47 |
I saved this a while back. Maybe there is something the OP can use, or maybe answer some of his questions..
https://www.camaro5.com/forums/showthread.php?t=245282
11-15-2023, 04:00 PM | #48 |
Drives: 2013 zl1 vert Join Date: Dec 2018
wow, this turned quick.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
11-15-2023, 04:41 PM | #49 | |
Drives: zl1 blk Join Date: Nov 2017
" Needs an attitude adjustment" " needs to learn the hard way " ..... So since u agree ..... PS. searching seth21 and scotavo |
11-15-2023, 04:47 PM | #50 |
11-15-2023, 07:24 PM | #51 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Lets get real... The two systems are very different starting with the Alternator they are different between the ZL1 and the SS (Check your Part numbers) Second even if they were the same the Zl1 is running stuff that doesn't exist in an SS, Suspension Control Module for the MAG struts, additional relays for the SC Pump, the Steering Assembly is electric vs Hydraulic, additional lights up front, HUDS display, PTM or Power Train Management just to name a few. So even if the Alternator were the same to say the voltage output would be the same is not a justifiable comparison. |
11-15-2023, 09:52 PM | #52 |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
It's all good Bud, but that's why they make emoji's no one can really tell how you coming across that way.
11-15-2023, 10:39 PM | #53 | |
At the end of the day both are still pretty similar and both designed to run on a 12v system…
11-16-2023, 12:15 AM | #54 |
Life's just a Ride
Yes Sir. but what's a few DC's more right? lol And I physically checked it with a meter at a few different places.
11-16-2023, 09:40 AM | #55 | |
11-16-2023, 09:51 AM | #56 |
Life's just a Ride
LMFAO Now I know that was sarcastic
