07-19-2017, 04:00 PM | #43 |
Drives: Overkill Supercharged 2016 CamaroV6 Join Date: Mar 2016
Yeah I ordered on june 23rd and not shipped yet. We all knew when we ordered there was a delay so in all fairness myself as others need to suck it up I am being impatient as well but at least hes on here giving notifications and its not all just left up in the air.
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/ Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA Supercharged with Overkill Superchargers http://www.v6superchargers.com |
07-19-2017, 04:19 PM | #44 |
Drives: 2016 SS Nightfall Gray Join Date: Oct 2016
Mine's due tomorrow, Thursday.
Just in time before my trip to Cali.... |
07-19-2017, 06:39 PM | #45 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
Arrived today. Order #3327 placed May 8th
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
07-19-2017, 08:10 PM | #46 |
Drives: 2016 Summit White 2SS Join Date: Dec 2015
Yea, I ordered on May 5 and still haven't gotten mine. You should be on the next Batch.
2SS A8, SW, NPP, Black Hash Marks, 56V.
Placed: 1/23/16 Built: 3/23/16 Delivered: 4/4/16 |
07-19-2017, 08:17 PM | #47 | |
Drives: 2017 SS 1LE Join Date: Mar 2016
IG: @NC_M1SS1LE
07-20-2017, 03:41 AM | #48 |
Ok befor you put yours on check your foam placement. On mine the foam was too close to the edge in 2 places on top. When I put it in it squished out so you can see it. I may have been able to fix it befor I put it in but its too late now. Ill take a pic tomorrow.
07-20-2017, 05:39 AM | #49 | |
Do the clips come off completely with the screws during removal or do the just relax? I don't want to drop a clip into the truck lid. Does the new light just snap in with the clips in the as delivered position? i.e. Don't loosen the screws I'm putting it on tonight.
07-20-2017, 12:04 PM | #50 |
the new light snaps in with clips on. remove all the clips on the old if you can. some jut removed the 2 middle clips and popped it out.
07-20-2017, 12:13 PM | #51 | |
2016 Camaro 2SS M6- Garage
07-21-2017, 02:35 PM | #52 |
Drives: 2016 2SS Join Date: Feb 2016
07-21-2017, 07:50 PM | #53 |
ZL1 1LE 3rd brake light
While I just finished the install. I heated it up with my wife's hair dryer, used a plastic pry tool from Harbor Freight, worked around it a few times and it popped right out. It did not scratch the paint if you are wondering, not a whole lot of pressure needed. The wire clip you need to push inward to pop it off. I used Goo Gone to soak the double sided sticky tap, then used the plastic pry tool to slowly remove the old tape. Then used alcohol to clean the surface where the new tape goes. Pushed in the new light and done. It is that easy. No screws, removing the inside panel or even opening the trunk.
07-21-2017, 08:16 PM | #54 |
Drives: 2017 ZL1 A10, 2015 C7 Z51 Join Date: Aug 2011
Finished mine too, but went a little different route of removing all the clips and pushing the light out slowly. It pretty much took all the foam with it and left nothing on the trunk that wasn't easy to remove.
2017 Camaro ZL1 - Nightfall Gray Metallic - A10 - Roto-Fab intake
07-22-2017, 11:41 AM | #55 |
Drives: 2016 Camaro 2SS, Nightfall Grey Join Date: Nov 2012
Installed this morning.
2016 Camaro 2SS, Nightfall Grey,
MRC, NPP, S/R, Nav, A8, E-Force Supercharged. Last edited by E-Ray; 07-23-2017 at 06:30 AM. |
07-22-2017, 12:39 PM | #56 |
Drives: SS Join Date: Dec 2015
Mine installed.
