09-01-2022, 05:56 PM | #43 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Just now got around to putting a ported TB on my 1LE. Been so busy with other things I hadn't had the time.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
09-01-2022, 06:38 PM | #44 |
Lifetime Philly Fan
Drives: 2015 Spring Edition 2SS M-6 Join Date: Mar 2012
Really nice car Bo!
Looking forward to your progression. Enjoy!!!!!
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter BBK LT HEADERS 1 7/8” Tune by DynoSteve via SCTx4 Tuner One of 82 GF Ragtops built in '15 out of 811 Total [/SIZE] |
09-03-2022, 04:27 PM | #45 |
RX dual valve catch can installed.
09-04-2022, 11:33 AM | #46 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
Did you get rid of the intake off the stroker too? Wasn’t it a pro flo? Plan on doin a rod mod?
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
09-04-2022, 09:14 PM | #47 |
Yes I sold the Pro Flo.
416 is for sale.
09-07-2022, 08:50 AM | #48 |
Are you leaning towards an off the shelf cam, or another custom grind?
09-07-2022, 01:37 PM | #49 |
Off the shelf. I'm not into custom grind cams unless your wanting something larger than a stage 4.
09-07-2022, 04:07 PM | #50 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
Alittle late : but awesome bo! Glad to see your staying in it .. for some reason felt like you were gonna jump to a vette .. can’t wait to see what you do to her
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9 |
09-07-2022, 06:43 PM | #51 |
Tri-County Camaro SWFL
So worth it. Makes downshift rev matching so much easier. One of my favorite mods.
09-07-2022, 09:32 PM | #52 |
Yeah my wife my purchase a C6 some day to add to her Terminator but that's it.
Ported TB helps drive ability for sure.
09-22-2022, 05:57 PM | #53 |
Fuel rail flip. Corvette fuel hose is too short for the later 5th Gens but I unfastened the fuel line off the frame rail and pulled it up. I also removed the insulator off the manifold while the rails were off.
Before and after:
10-09-2022, 07:36 AM | #54 |
Congrats and good luck with the 1LE! Just curious on your 2010 you were able to fit the Edelbrock Pro Flo 102 IM under the stock hood?
10-09-2022, 09:39 PM | #55 |
10-09-2022, 09:40 PM | #56 |
I've been driving, rolled 2 days ago..... oil changed yesterday.
