07-26-2022, 12:36 PM | #43 |
Petro-sexual
I have to be honest in that a lot of the time, it's difficult to understand what some of these guys are saying, because they're talking tuner-talk, and I'm not a tuner. In case this might be helpful to anyone (trying to do this by memory - sorry - no laptop with me):
Disabling the codes is easy. Just unselect the check under "SES Enable" and change the column to the right (I forget the label) to "No MIL Reported". That P27A-code is a new one to me. That one was not sent to me as something to change. I don't know if that's a model-year specific-type-thing, or a new discovery by HHP. Connection to the internet is necessary because, for reasons I don't understand, that's how to access the TCM. One of the things I don't like is you can't read the TCM from the car, as it stands. You can write to the TCM, but again - your laptop has to be connected to the internet. The connection to HPTuners is automatic though, so that's nice. It says read, but it's not readable like the ECM/CCM. At any rate - you can write all you want, which is what matters to me. As far as verifying it's the correct file - I saved an OEM file of the TCM-tune, and it seems to compare directly with what comes from HPTuners' server. So - that's good. Those are easy things to check/compare. Basically - what made sense to me was reading the OEM tune (from the T93) before swapping to the HHP TCM. Then - after I connected to HPTuners the first time, I saved that file, and compared to the OEM file (from the T93). For me - there were no differences in the tune comparison, so all was good. I then started making adjustments from there. Hopefully that was helpful.
07-26-2022, 01:09 PM | #44 |
Drives: 2008 Pontiac G8 GT, Shelby GT500 Join Date: Mar 2011
I wonder if they’ll ever get it less finicky with these new TCMs. Seems like such a pain. I’m used to just reading the tcm, seeing the tables and values, making modifications, then uploading.
07-26-2022, 02:57 PM | #45 |
Petro-sexual
Yup. That's what I've tried to learn to do, and not overthink it, which is something I do, too. I'm sure it's not going to get easier. This isn't bad though. It's just trying to understand, precisely, what they mean.
07-26-2022, 06:06 PM | #46 |
I was told today that I have to reinstall the stock TCM and grab some data to eliminate my T87a DTCs. I'll know more in a few weeks
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. 1116/967. 1.35/9.25/151 at 3500 ft. (only one pass) 15" conversion/MT ET Street R 325/50R15. |
05-12-2024, 02:40 PM | #47 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
For those that made this swap to the T87A from HHP, was the car able to be driven immediately after the swap or was a base TCM tune file needed first? I realize the T93 can be unlocked and tuned now but I bought a HHP T87A TCM a year and half ago and never got around to installing it until today. Didn't make sense for me to unlock my T93 since I already spent money on this unlocked T87A. I'm waiting to hear back from my tuner on what steps I need to do next. I was just curious if the car could or should be driven immediately after installation.
05-12-2024, 03:42 PM | #48 | |
Tuner must disable P2544 in ECM Tuner must be connected to internet while reading/writing TCM Tuner must verify generated TCM tune file is correct for the application (AKA, SS, ZL1, rear end ratio, etc). *The automatically generated tune file is not vehicle specific* I had to reinstall the stock TCM and grab some data to eliminate my T87a DTCs.
'20 ZL1 1LE A10.
05-12-2024, 03:53 PM | #49 | |
I did not try to drive the car but I did have to move it out one garage into another, no service engine lights came on and it seemed to shift just fine just moving it short distances. Still waiting on the tuner though before I proceed with anything. |
05-13-2024, 07:00 AM | #50 |
Petro-sexual
I had to re-orient the plug correctly, as I believe the T87 connection flips 180* compared to the T93, connected to the interwebs, verified the file (compared to the OEM file, and it was fine), adjusted the DTC and no problem. I had the plug wrong the first attempt (because it plugged right in and didn't fight me in any way) and got a SHIFT error. There was no problem otherwise though. I jumped in the car, kept the brake pedal down, and manually shifted as much as it would allow and all was good. I was able to drive it right away.
05-13-2024, 07:13 AM | #51 | |
05-13-2024, 08:53 AM | #52 |
Petro-sexual
I'm sure it'll be fine. There's not much that can go wrong, except turning rubber to smoke.
05-13-2024, 09:07 AM | #53 |
06-11-2024, 01:01 PM | #54 |
Elite Tuned has just about finalized my TCM tune. Overall pretty impressed. I can only assume the torque management was the feeling I've disliked for years now in the A10, the car just felt a little mushy in the low gears at part throttle, but since the TCM tune, it feels like its gained a lot of torque at part throttle. Had to make several 2000-6000rpm data logs for ECM and TCM tuning, tried a 4th gear pull from 2-6K rpms and that resulted in fish tailing and having to back out of the throttle. It seems I can only do a 5th gear pull from 2-6K rpms without breaking the rear end loose. Crazy to think the first 4 gears are now useless at full throttle on street tires. 10/10 would recommend.
06-11-2024, 01:08 PM | #55 |
Petro-sexual
I can only imagine how improved it is with their tuning.
I took their on-line course for this controller and it was helpful. There was some access to get a little tranny tuning without going through the TCM (by tuning the ECM, as pointed out by others [King']) and I could see what my tuner at the time (Ben Charles) what he did. I tried a little torque model changes, too, which seemed to help, but going through the TCM - the right way, now, is the way to go. From what I could tell, the 2-3 was particularly bad for me. Like you, starting a pull in 5th was the only time I could really stay in it, and that was on DRs. I can't cross my eye on street tires without the rear going up in smoke. Fun, but not fast.
06-11-2024, 01:23 PM | #56 | |
