01-27-2013, 06:05 PM | #43 |
Drives: C6 Z06 Join Date: Jan 2010
It is not about interpretation insomuch as it is about comprehension.
First bulletin: The rubber used in these tires loses flexibility and may develop surface cracks in the tire tread/shoulder area at colder temperatures. Goodyear does not recommend using these high performance summer tires when temperatures drop to approximately 40 deg or below, or in snow/ice conditions. Second bulletin: Goodyear F1 Supercar Performance tires are a summer season tire and are not intended to be driven on snow, ice, or road surfaces below -7° C (20° F). To review - first one days they do not recommend driving below 40 deg, right after they warn about surface cracks. Second one says don't mov it below 20 deg because you might get surface cracks. Again, the first one says you shouldn't drive below 40, this one doesn't mention the 40 deg threshold and only warns about 20 degrees. If you cannot see how they say two completely different things, I will leave this thread alone. |
01-27-2013, 06:23 PM | #44 |
I used to be Dragoneye...
They don't say two completely different things as I read them...hence my use of the word: "Interpretation".
I'm not trying to argue here, I promise! ...what's obvious no matter what's read is that these are not good tires for cold weather. The first, as I read it: Under 40º = Driving not recommended, tires lose a lot of traction. Under 20º = Do not drive, or move, cracks may occur. If chilled to under 20º, let warm to 40º before driving. The second, as I read it: Under 20º = Do not drive, or move, cracks may occur. If chilled to under 20º, let warm to 40º+ before driving. So, in my interpretation...they are not different...the first one is just more detailed. In fact, as I have them up together, here....I'm noticing some of the same language between the two. Someone earlier made the distinction that one is from Goodyear, and one is from GM. I think that person hit the nail on the head. |
01-27-2013, 06:51 PM | #45 |
Drives: 2013 Camaro ZL1 Convertible Join Date: Jan 2013
A quote from an earlier post said..."They also made sure a winter tire was available for people who live in colder climates and wish to drive year round".... So, what is this winter tire that GM made available???
2013 ZL1 Black Convertible
2002 Rally Red Camaro Z28 Convertible 35th Anniversary Edition 2008 Hummer H2 Ultra Marine Edition |
01-27-2013, 11:58 PM | #46 |
Drives: 2012 ZL1 #450 Join Date: Nov 2011
I don't think that they picked these because they were the best tire, I think bean counting went into the decision, because these tires are not "supercar tires" in the least. They don't grip, plain and simple, and I am not the only one of this opinion.
I am hoping toyo comes up with tires for this car. If not I will probably get the BF goodrich set as soon as these wear down. |
01-28-2013, 01:23 AM | #47 | ||
01-28-2013, 03:34 AM | #48 |
Drives: 2012 Camaro ZL1 Join Date: Dec 2012
I live in Seattle...and I had Discount Tire switch the Supercars out for the Continental Exterme Contact in 315/35/20 and 275/35/20 up front. Great tires.....outstanding grip in the wet. And very reasonably priced..mounted and balanced for close to 1275.00. Wont be disappointed.
Vince |
01-28-2013, 09:03 AM | #49 | |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
How do the tires look? I assume there is no extreme stretching or bulging with these sizes?
01-28-2013, 09:27 AM | #50 |
Drives: Charger/TL1000R/Cobalt/ZL1 Join Date: Sep 2011
01-28-2013, 04:27 PM | #51 | |
Nope, not crazy at all, these tires don't grip in the least and wear away in 10k miles or less. Not worth having them on at all. There are better, stickier tires out there. |
01-28-2013, 06:51 PM | #52 | ||
http://www.tirerack.com/tires/TireSe...35&diameter=20 Personally, I'd recommend buying a smaller set of wheels and tires...maybe SS-size...to save some $$$. Quote:
Honestly...I am surprised at some of the comments/responses in these threads over the past few months...I can respect differing opinions on the tire versus competitors - but there's just no denying the incredible grip of the OE tire choice in the spring/summer/fall. |
01-29-2013, 12:42 AM | #53 | |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
I hope you realize that the "better,stickier tires out there" will also wear just as fast. The stickier they are the softer the compound. Try doing some track days and canyon driving they all wear quickly. The Goodyear tires have tons of edge grip they are sticky. I believe you've already stated that they "wear away in 10K or less". |
01-29-2013, 01:21 AM | #54 |
I'm well aware of that, the other tires will actually grip however, these don't, sitting there spinning tires doesn't win races
01-29-2013, 09:47 AM | #55 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
Are the nannies completely off?
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
01-29-2013, 03:18 PM | #56 | |
Drives: '12 ZL-1 #106, '10 ZR-1, 07GT-500 Join Date: Nov 2011
Scott... |
