Go Back   CAMARO6 > Members Area > Ask the Camaro Team
Old 11-16-2017, 09:44 AM   #43
jasonct
Drives: Camaro SS Nightfall Gray Metallic
Thanks for the explanation!
jasonct is offline   Reply With Quote
Old 11-16-2017, 12:17 PM   #44
ChadFarr
Instagram: @SSAVAGEVERT
ChadFarr's Avatar
Drives: 2016 SS M6 Vert
Great Answer and clarification!
2.9L Whipple | Compstar Rods, Diamond Pistons & GPI Cam | Mantic Triple Disc | Corsa Performance Exhaust | DSX Aux Pump | LT4 Fuel System | BMR Lowering Springs | ZL1 OEM Conversion | 360 Customs Built | And More!
Click & Follow My Build
ChadFarr is offline   Reply With Quote
Old 11-16-2017, 05:38 PM   #45
Battlezone580
Battlezone580's Avatar
Drives: 2018 ZL1 1LE, 1969 Nova SS 396
The LT4 is rated at 650hp @ 6,400 rpm. 5200rpms seems way too soon to shift, you wouldn't be hitting your peak power.
Looking at a hp chart of the LT4, shifting at 5200rpms would put you at about the 550hp range .
18 ZL1 1LE|M6|Nav|PDR|CF Hood|CF WING|CF Dash|Tow Hook|
Battlezone580 is offline   Reply With Quote
Old 11-16-2017, 06:41 PM   #46
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
I think you've misinterpreted the table. For your ZL1, you can shift wherever you want above 5000 rpm but once you execute the shift the feature will adjust spark timing and fuel to target an engine speed of 5200rpm, all while keeping the intake throttle open. So if you execute the shift at 6450rpm, once you push the clutch pedal engine speed will target 5200rpm.
The idea is to keep the throttle open, so intake manifold pressure stays high during the shift so then you can have full power immediately as soon as clutch pedal is released.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 11-16-2017, 09:52 PM   #47
Originally Posted by vtirocz View Post
I think you've misinterpreted the table. For your ZL1, you can shift wherever you want above 5000 rpm but once you execute the shift the feature will adjust spark timing and fuel to target an engine of 5200rpm, all while keeping the intake throttle open. So if you execute the shift at 6450rpm, once you push the clutch pedal engine speed will target 5200rpm.
Old 11-17-2017, 03:49 PM   #48
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Not really. It's more optimized for drag racing to help lurch the car into the next gear without loss of acceleration in the standard SS. The SS 1LE however, is clearly set to promote smooth NLS gear changes so it won't upset the car mid turn on track. Makes sense. Track calibration for the track pack car.
Then why is the ZL1 around the same range? I think there is more too it then that as having it hold at 6400 is past the power peak of the engine, and right by the limiter...and on top that after your shift point. So that really wouldn't be a "help" drag racing. Dunno...
Old 11-17-2017, 09:57 PM   #49
vtirocz
vtirocz's Avatar
Based on this power curve on the lt1, I think shifting as close to redline as possible will result in the best time. This can be calculated as well to confirm the best shift point for each gear. I'll do that and report back.
https://www.edmunds.com/car-reviews/...dyno-test.html
Old 11-18-2017, 08:07 AM   #50
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
Does a 5th gen LS3 have no lift shift? i.e. '15 1LE?
Russell James is offline   Reply With Quote
Old 11-18-2017, 08:45 AM   #51
No, it came 1st with the 2012 ZL1
Old 11-18-2017, 09:07 AM   #52
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Best time comes when you maximize the "area under the HP curve" between the (higher) rpm you shift at (in the lower gear) and the (lower) rpm you end up in, in the next gear.
This happens when the HP at the rpm you shift at is essentially equal to the HP at the rpm you end up in . . . assuming that you have enough headroom above peak power rpm before encountering any rev limit to do so. If there is an rpm limit getting in the way of the above, just under that rpm limit would be your optimum shift point.
Keep in mind that the best shift point for one of your shifts won't necessarily be the best shift point for any of the others; best shift point varies a bit as the spacings between transmission gear ratios varies. Wide gear spacing will want you to run the lower gear out to a higher rpm than close gear spacing. Rev limits permitting.
Norm
Old 11-22-2017, 10:06 AM   #53
vtirocz
vtirocz's Avatar
I used the feature several times now on my 2017 SS manual and it works exactly as advertised. I look forward to testing this out at the track next year to see what kind of gains I will see.
Thanks again, Al, for the detailed explanation! The 6400 RPM target speed was so close to the 6500 RPM redline that I thought it might not be working as intended. I'm happy to see I was wrong. In future, I would definitely recommend putting this level of detail in the owners manual or performance supplement so more owners will take advantage of existing features.
Old 11-22-2017, 05:59 PM   #54
Macaro
Macaro's Avatar
Drives: 2018 Camaro ZL1 1LE
I’m psyched to try this next season at the track, may be good for another tenth or two...
Macaro is offline   Reply With Quote
Old 11-22-2017, 07:31 PM   #55
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
No real gains, as it cuts a tad bit of timing on the shift. Mainly just easier and more consistent.
Old 11-22-2017, 08:15 PM   #56
vtirocz
vtirocz's Avatar
There will be a benefit in how quickly full power returns after a shift since intake manifold pressure won't drop as much (since intake throttle remains full open). I'd like to datalog this to quantify the difference.
I'd expect a small difference in the naturally aspirated engines and a bigger difference in the boosted engines.
