05-18-2013, 09:05 PM | #421 | |
One Slow Automatic
Drives: 2017 GS 2010 CAMARO SS Join Date: Mar 2010
Sounds like caliper bolts are loose.
650HP 2010 CAMARO SS 710HP 2017 GRAND SPORT
05-21-2013, 02:47 PM | #422 |
Drives: Camaro Justice Join Date: Jun 2007
Clicking related directly to wheel speed?
06-26-2013, 05:35 PM | #423 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
BUMP.....just ordered my CTS-V kit sans stainless lines. Last piece of the puzzle before busting my cherry on Eagles Canyon Raceway.
Went with the factory color as the natural heat coloring has me intrigued. Hawk HP Plus pads for the street and Pedders special (Carbotech) pads for the track is the plan. Motul 600 for now then will go with Castrol SRF. Gonna bleed the old fashioned way and forgo the ABS Tech II. Elected to stay with the tried and true CTS-V rotors Really worried about brake fade at 160 + mph on the back 2000' straight going into the 90 deg turn 7! Hopefully wont be an issue for the 20 minute track session. I know the oil temps will be an issue after about 3 laps in the 100+ deg Texas heat, even with the big 16 row Earls oil cooler. Thats what the right foot is for.....right, no need to go 14 psi boost on every straight! Time to re-read this entire thread!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
06-26-2013, 06:58 PM | #424 |
Supercharged LSX
Drives: 2011 2SS/RS Black/Carbon Fiber Join Date: Dec 2010
Last week spend a few hours in the canyons really pushing the car. If heated up and had big time brake fade there before. None this time around, felt strong and consistent. Well worth it for the cost.
06-28-2013, 08:01 AM | #425 |
So Pete, are these CF pads you mention here the Pedders special you mention?
06-28-2013, 08:12 AM | #426 |
06-28-2013, 07:56 PM | #427 |
Thanks Pete, on the way! I better be able to slow this fat pig from 160+ to 60 or so in a hurry, and do it for 20 minutes. Damn near $700 for pads
Cant take it with you.....right?
07-03-2013, 10:08 PM | #428 |
All right, almost done. Would be done but the guy at JDP that packs the boxes forgot one of the pin kits so my passenger side front has no spring or pins. So i am left high and dry till friday. At least they are overnighting it and should be here Friday since tomorrow is the 4th.
Ive flushed the old fluid out of the clutch and pulled the old fluid out of the brakes with a pressurized system from harbor freight. I ordered 5 half litres of the Motul dot4 and still have about 2 pints left. All is good but the passenger side front has no spring or pin kit but was able to bleed/flush the system. Car is on stands so i guess i will crawl around under it tomorrow and pretend i am doing something constructive!!!! its good to check all the fasteners on the suspension and ehaust i guess. Kit is superior, now am just about ready to challenge Eagles Canyon Raceway on the monthly track days......shouldnt have to ping over the brakes now. I will run Cobalt Friction XR1/XR2 pads for the track days and HPS pads for the street. Here are a few crappy pics since pics are a must.....never claimed to be an artsy fartsy photog kind of guy. If they suck.....blow me!!!!!!!!!!!!!!!
07-03-2013, 10:47 PM | #429 |
Negative Camber Junkie
Drives: 2010 1SS LS3/6MN ABM 1 of 23 Join Date: May 2009
Pictures are fine, garage floor being filthy on the other hand... well ...........I guess we will have to wait and see when you get it all put together and cleaned up.
JK, that you are doing it yourself. T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same. Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different. I can't wait for my next Track fix. DA HAWKS OWN DA CUP!!!!! |
07-03-2013, 11:48 PM | #430 |
Drives: pleather and Chiclets Join Date: Mar 2012
congrats! nice to see the bits of rubber on the inner liner!
07-04-2013, 05:48 PM | #431 |
Is there a rebuild kit out for these 6 pots? want to have a couple standing by.
07-04-2013, 07:31 PM | #432 |
Here you go Bull...
http://www.racingbrake.com/Boots-and...-p/bc-61bs.htm You will need 2, one for each side. Now if you want a complete kit with Stainless Steel pistons, which reduce heat transfer, then you want this kit. http://www.racingbrake.com/CTS-V-Com...p/bc-61bsp.htm T.
07-05-2013, 09:50 AM | #433 |
Thanks T!!!!
07-05-2013, 11:46 AM | #434 | |
Drives: Chevys at the limit Join Date: Nov 2010
Best regards, Tyler 888-308-6007 |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 | TAG UR IT | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 58 | 12-01-2019 09:54 PM |
Camaro Production Numbers 1967 - 2002 | PAUL SS | General Automotive + Other Cars Discussion | 3 | 07-22-2010 07:12 AM |
GM Reveals 2011 Chevrolet Silverado HD | FenwickHockey65 | General Automotive + Other Cars Discussion | 55 | 03-04-2010 01:56 PM |
Need Stopping Power? Baer 15" Six Piston Brake Upgrade now available! | Kris@BMCPerformance | Suspension / Chassis / Brakes | 11 | 12-10-2009 06:50 PM |
Baer 15" 6 Piston Extreme Plus Brake Upgrade for 2010 Camaro Available Now! | Kris@BMCPerformance | Suspension / Chassis / Brakes | 6 | 11-04-2009 09:17 PM |
