Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 06-09-2010, 06:47 PM   #29
Pretty sure he meant to say 4th instead of 5th... but then he's talking 10.5s which I have no clue about...
Wacker did a bunch of test and tune on this. The Auto shifts into 4th right before the traps. He made adjustments to keep it in 3rd all the way through and found it was better to just let it shift to 4th as it was dropping out of the power band in 3rd.
Old 06-09-2010, 07:21 PM   #30
Supercharged SS
Drives: 2010 Camaro
No I meant 5th. I don't want the car shifting into fifth gear and loosing anything. With a 4.10 I'm pretty sure that it would put the car into 5th. I need to check and see where my rpm's are when I cross the line in 4th.
Wacker crosses the line at 111mph. I go through at 125 +. I'm pretty sure I'm into 4th by then.
Supercharged SS is offline   Reply With Quote
Old 06-09-2010, 07:24 PM   #31
Supercharged SS
Drives: 2010 Camaro
Speedster,
I start in 1st. All I do is put the car in "S". Shut both the TC and Stabiltrak off and hold on. I let the car do the rest.
Silverfox,
Jannetty tuned the car so if you have any questions what so ever I would ask him. You def don't want me trying to answer any unless you're in need of a good laugh.
Old 06-09-2010, 07:41 PM   #32
Guess I just need to work on hitting the traps faster than 109 and 4th gear will be just right...
Stall Converter and Trans Cooler is on my list... hitting 1.7 60' is a nice target.
Old 06-09-2010, 09:13 PM   #33
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Speedster,
Thanks for the info. Just wondering since with that converter you will have some really serious low end grunt and those slicks should be screaming...
Now is where the suspension tune will really become important to plant those tires. Can't wait to see watcha run both 60' and 1/4.
speedster is offline   Reply With Quote
Old 06-16-2010, 08:37 PM   #34
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
I posted this on another thread but you guys look smart too
As you can see from my build info below I have a PTC converter. At lower acceleration the transmission is a bit more squirley and seems to hunt. When you go hard throttle it is very crisp. I understand that the stock converter is a bit looser and is designed for smoother shifts. My question is should I be experiencing what I am with this higher performance converter. I honestly don't know what the stall is (long story that I will share later) but I believe it is a 10" Lock up. It's almost like it wants to shift and then stalls a bit. Help a rookie out brother!
I think what I am experiencing at the low loads is that I am bouncing off the stall speed and it is trying to lock up and I am not being consistent enough with my 'foot shifter' aka throttle control on my part? Keep in mind this is my first experience with a high performance TC. Go easy on the noob boys!
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Old 06-17-2010, 02:47 AM   #35
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Maybe gears next. I always forget to check my rpms as I go through the traps so I can tell Ted. I don't want it shifting into 5th. I'm trying to stuff in stages now. First was the slicks. Now the stall. Then the fuel system and more boost, and then gears. When our weather gets good again, the car should do 10.50's without ever opening anything on the engine. Thanks for the kind words guys!!
With that new stall you should be in the mid 10's for sure. My 4th gen dropped about half a second with a vigalante 3200. Dont be surprised if you loose a little mph at the traps. I know I did. Lower E.t. is all that matters in the end. Your car is awesome BTW
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
VADER SS L99 is offline   Reply With Quote
Old 07-06-2010, 11:35 PM   #36
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
With the 4.10's I trap 115 @ 6400 in 4th. For a blown motor 3.73's would be the way to go IMO. If you cam it and are able to spin it to 6800 you'll see about 122 with a 28" tall tire and 4.10's. 3.73's will get you 125 @ 6400 in 4th. I plan on blowing my motor soon, just hope the 4.10's aren't to steep. I'll probably have to start in second then.
I run a Circle D 3K stall. It does not hunt and my shift completion RPM is up a few hundred. I have it set to lock at 100 MPH right when the HP curve starts to dip. The 3K stall is perfect for a blown application. Also make sure it is a tight (type A) stator vs a loose (type B). Blown motors need the tight stall so there not wasting HP/TQ. I have not raced the new verter, but plan on doing so this weekend weather permitting. There is a lot of tuning involved with the 6L80E and no-one at the present time has managed to gain full and instantaneous lockup at any given speed. I am actually working on this with my tuner and upon completion the lockup converters will be able to be used to their designed potential.
2010 IOM 2SS/RS A6, Tuned by Me, ARH/NoCats, Borla Touring, Vararam CAI, G-Force 9" with 4.10's, Circle D 4500K, (Skinnies/Slicks, and Bogarts all around 24MPG
11.39 @ 118 510 DA
www.6l80tuning.com www.6l90tuning.com
Wacker is offline   Reply With Quote
Old 07-07-2010, 03:01 AM   #37
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
does circle D recomend WOT lock up??
i talked with the guys at yank when i got my converter and they said to never run there converter with wot tcc apply. they would not recomend that to anyone.
415ci stroker, TVS 2300 Magnacharger, cnc heads, cam, yank ss3200 converter, Kooks long tubes, Bwoody true cold air kit, ZL1 Pump, magnaflow 3" cat-back, lowering springs,BMR control arms and tie rod bars, 3.73 gears, diff mounts, RX can, ADM fuel controller
camaro1 is offline   Reply With Quote
Old 07-07-2010, 06:00 AM   #38
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
Since I recently converted my L99/A6 Auto over to a Cammed LS3/A6 Auto im about to throw in a 3200 Stall converter.
Since the day I dynoed the car after doing the conversion/Cam I dont know what she has gained however I left ADM with 432hp
a 3200 Stall should help in the lowend BIG TIME and put the Power to the Pavement.
Get ahold of Andy at ADM and speak to him about his Trans Cooler. Andy has an awsome set up ! It's not expensive at all and the work/job is done very clean.
With the temps reaching almost 100 up here in DFW and driving my car 70 to 90 on the highway my car barely gets past 180.
If I do some hard take offs out of the hole yeah it starts to heat up however she never gets much past 180
imo ANYONE with an A6 needs a Trans Cooler Especially with a Torque converter.
Jekyll-N-Hyde is offline   Reply With Quote
Old 07-07-2010, 08:39 AM   #39
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Originally Posted by camaro1 View Post
does circle D recommend WOT lock up??
i talked with the guys at yank when i got my converter and they said to never run there converter with wot tcc apply. they would not recommend that to anyone.
Yes...It is guaranteed to 1000HP. That is one of the reasons I went with them. Once the tuning issue is figured out us A6 guys will be golden.
11.39 @ 118 510 DA
Old 07-07-2010, 08:54 AM   #40
thesubfloor
Drives: 2010 Camaro SS
What tuning issue are you referring to?
As for locking up the converter under WOT, it really isn't a good idea because what you've got in there is a clutch disk with only a fraction of the surface material of a manual trans clutch AND it's immersed in very slippery transmission fluid.
If the converter is efficient enough there really is no need to lock it up under WOT as I've been running killer times in my Corvette for the last three years with a Yank SS3600.
thesubfloor is offline   Reply With Quote
Old 07-07-2010, 09:15 AM   #41
thesubfloor
Originally Posted by Chief Blackhawk View Post
Do you tune your own car? Im running the ss3600 in my camaro and I am always curious to see how other people are running similar parts.
Yeah, I've been doing both the installs and tuning on my car for a little under 3 years now and have built several others for various friends. If you do a search on Youtube for "thesubfloor" the video for my 9.950 pass (all motor) is posted there.
Sadly though I had to sell my soul to the devil when I bought the Camaro as I had to promise the wife I wouldn't mod it. :-(
Old 07-07-2010, 09:50 AM   #42
thesubfloor
LOL, any chance you would share your a6 tune from your vette?
Sure, just send an e-mail to syclone98@hotmail.com and I'll reply with the tune attached.
Also, as an A6 guy here's something you might want to check out:
http://forums.corvetteforum.com/c6-tech-performance/2624720-looking-to-upgrade-your-a6-transmission-well-the-wait-might-finally-be-over-new-post.html
I'm gonna start a similar post on this forum but in a nutshell I'm running a built 6L80 from Century Transmission (near Houston) using the newly developed Alto clutches and we're purposely gonna beat on it at the track as much as possible over the next three months to see how it holds up as I've gone through 6 transmissions in the 3 years I've owned the car.
Hello First Post, looking at getting one next year Rocketright 5th Gen Camaro SS LS LT General Discussions 11 12-11-2009 07:02 AM
I WILL CHOOSE MY THREADS MORE CAREFULLY, TO POST IN. SQUALO Canada 101 11-22-2009 08:20 PM
Group Buy - Custom Speaker Boxes, Amps, Subs (Updated post 25) TAG UR IT USA - Texas 41 10-19-2009 08:56 PM
Craigslist + Post = unhappy Dealers TiE2000 5th Gen Camaro SS LS LT General Discussions 75 09-27-2009 05:15 PM
