11-12-2020, 08:27 PM | #29 | |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
On my Gen5 the additional caster increased the bump steer, and the car drove like a dump truck on uneven, rutted and bumpy roads. With the addition of a bump steer kit and some trial and error on its tuning, the steering is feels pretty awesome. Lots of confidence when I’m pushing it hard. Without the bump steer kit I was very busy with inputs in the steering. I plan on purchasing a Longacre bump steer measuring kit to fine tune it, if needed. Since this thread is about the SPL parts, I see they have a bump steer kit for you Gen6 guys. Don’t be afraid to try it. If you sense a loss of your fantastic OE steering feel and feedback with adding caster, the bump steer kit can help bring it back. I test drove a 2021 SS1LE A10 this past Monday. My god, the steering feel and front grip was amazing.
11-13-2020, 12:30 AM | #30 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Randy Pobst was a first pro to test this car at large and one of the very first words that came out of his mouth was amazing front grip! And he knows what he feels, eh? My tire wear at 2.6F and 1.6R is near damn perfect. If i push my tires too long, they cord on the inside, on both sides. So for damn sure i will not dial any more camber, lest they will cord faster! The car turns in as if it was telepathic and the steering feel is truly excellent. If somebody complains about lack of front grip, may i suggest they check their alignment. And if that is ok, then may i suggest they learn how to trail brake effectively, in order to manage weight transfer and overall balance on entry. If I wanted even more grip and faster laps i would simply put G3Rs on (as many have done here with zero changes to suspension geometry). The SS 1LE comes with tons of caster out of the box. You will be hard pressed finding any race cars with this amount of caster. Maybe rear end engine sports cars, as they benefit by more caster to offset the weight balance. But rarily does a front engine car benefit by more caster as far as outright handling and pace. To the contrary. Caster indeed helps maintain camber on the outside wheel (while reducing it on the inside wheel) which may provide for better wear, BUT at a cost: 1) slower steering response (by design) 2) likely more understeer 3) possibly MORE tire wear because of the above (caused by slower transitions). 4) possibly rears getting overloaded (because of a weight shift). Higher caster makes the car less responsive and more stable. Some seasoned pros will have it reduced as much as practical, to make the car as responsive as possible to their inputs. Some pros may have it increased to dumb the car down if they are new to a given class/etc. No pro will increase caster to go faster. Lastly, you must have a good feel for the balance given your comments about the 2021 SS 1LE test drive. Now imagine this car with proper track alignment... Go buy it! Cheers |
11-13-2020, 10:45 AM | #31 | |
I like to play with my car, to better to understand it, and I'm not afraid to try something. My aim with the additional caster has been to lessen the static camber while keeping the same level of grip. All because I street drive my car more than I track it. So I drive all summer on the track alignment and as you mentioned, the inner shoulder gets abused from the high static camber. I've been reducing my static camber while bettering my PB. That's not to say that increasing my static camber won't help my lap times, it certainly will. Again, other variables effect lap times. Just trying to find a street/track balance. Caster can help both tires in a turn but as with everything else, there is a limit. The list of other side effects shows there is no free lunch. But I'm not sure about comparing caster #s between different types of suspension as there other variables that come into play. As far as what I've observed on my car, unfortunately, 2* more caster doesn't equal 2* of better dynamic camber control. I'm actually down on caster from my above picture of 9*. I'm currently at 8*. Mac strut suspension is not optimal if we want to turn and keep the tires happy as far as wear goes. The camber curves suck. I've run through various caster measurements at different steering inputs and I have seen the results. This winter I may try to measure the camber, caster and bump steer with the suspension at different ride heights, trying to mimic the car being loaded in a turn. There's other dynamic variables involved but understood. Maybe next year I'll go back to the factory 5.6* and see how she goes! My current setup is quite different from OE, going to 5.6* would be an interesting change.
11-13-2020, 12:02 PM | #32 | |
Cheers! |
11-14-2020, 06:43 PM | #33 | |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
I imagine the mount of camber desired has something to do with the track and the tires being used, I’m at a corner heavy track (19 of them with a lap time of 1:20) with lots of off camber corners and I’m using SC3R tires. Anyone want to chime in with advice and experience? Yes he does have recommendations and told me that he would phone the shop that does my alignment in order to get them to set the car up right and best for the track considering my car is also slightly lowered, although only by about 1/2 to 3/4 of an inch or so.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
11-14-2020, 10:31 PM | #34 | |
On a related subject, if these mods will cost you $4.5k (if i recall correctly), you may as well consider DSSV kit, as it starts to look like you're about to build out a race car. Whatever you do dont spend your money twice |
11-15-2020, 12:59 AM | #35 | |
I can increase camber to some thing around 3 or 3.5 considering that I already have the rears at -2 The $5000 figure was if I bought every single part SPL offered for my car. He also has no problem sharing the alignment spec goals, I just didn’t want to know how to set up all the parts in order to get there I have thought about the DSSV‘s considering I would think they would pay a bigger dividend considering just how many corners I have on my local track, however I really don’t want to ruin the ride quality of the vehicle when I drive on the street, even though it’s not a daily driver. Having said that I mostly only driving on the highway now. There seemEd to be a few guys who switched their MRC to DSSV and gained very minimal time on the track. however it was an extremely low sample size, I imagine it’s also very driver dependent and very track dependent as well. I can’t help but wonder how much of a difference the DSSV would make when doing 19 corner in 1 minute 20 seconds
11-15-2020, 12:33 PM | #36 | |
Usually corrections for roll centre are needed if a ride height is lowered quite a bit and results in negative handling effects. If your half inch is not producing these negative effects, than no correction is needed per se. If you are starting to worry about absolute perfection, then an upgrade to eliminate any roll centre issues (if you have them at all) would be to put oem springs back on at ZERO cost. This would also solve for any issues regarding springs to damper valving ratios. Something i would not forget about, if you are looking at maximizing performance set up to a proverbial "T". It would also be a timely (and cheap) test, to see if the handling and/or pace changes any. What if ya went a few tenths faster? If you wont test, you will never know. Even IMSA teams test multi spring/damper combos before picking the best handling set for a given race. As far as DSSV, i would consider them seriously, if aero was in your plans. With more aero, you will need a harder sprung suspension. Note Nicky Bobby's build details. They are very well thought out. As far as increase in pace, driver and tires will make the most difference. But, a well balanced car, which is easy to push is equally important. At this stage, given your big success this season, future gains might be in tenths vs seconds. Not having laptimes from another well driven ZL1 on the same tires, you wont know what the delta is. A good lap timer could be of help based on optimal sector times, but these are about driver vs mechanical mods and not necessarily 100% accurate (but helpful nevertheless). Judging by Fastest Laps at various venues, it seems that ZL1 1LE is damn fast as a package. This tells me that GM did a nice job marrying different components together to max pace: suspension, tires and aero. PS it seems you were surprised you have 2R camber. Do they not set up your car based on your specs? Do you not check them? Note my comments about high camber and tire wear. Have fun! Cheers! |
11-17-2020, 12:09 AM | #37 | |
As for how the car was set up, I believe I simply told him to get as close to the ZL1E alignment specs as possible, but with the crash of my car at the track I really stopped paying attention to the alignment, so I forgot that the rears were set to slightly more than the -1.7 that the ZLE has. I like the look of the slightly lowered car so I’d rather correct for this with aftermarket parts if possible, even though it’s more expensive. Yes I’m probably being very perfectionist but on a corner heavy track I want every single advantage I can get in order to stay ahead of all the Porsche gT3‘s I’m up against on this tight technical track. Overall I hope to beCome a better observer of how my car is handling as I get more track time next season with my Current modifications and set up. But like you said last year, it’s definitely hard to tell what’s going on when everything is happening so fast and I’ve only had about 10 full track days if you don’t count the three training days Where we weren’t pushing hard and all the Half track days I had car problems
11-17-2020, 07:59 AM | #38 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
I think the question remains: how do you know the car's geometry needs "corrections" just because you lower it slightly? And if so, what will you correct, and how will you know what to correct? Don't forget, if you increase the effective spindle height (which is what the "roll center correction" shims achieve), then that has other implications for geometry, such as where the RC moves and how quickly as the suspension compresses and rebounds. The existence of these parts implies that "RC correction" is needed, but has anybody really quantified that? Again, I don't think Chevy does anything to correct it for the different ride heights of the various Camaro models.
Matt Miller
2020 SS 1LE |
11-17-2020, 10:35 AM | #39 |
toe rods with lockout are awesome going to see if i can get more camber in front without camber plates first then see what else i want to add spl parts makes good products just gets $$$
11-17-2020, 11:27 AM | #40 | |
11-17-2020, 11:53 AM | #41 | |
One can spend tons of $ without making much difference and even making things worse vs better (been there done it). Then things become complicated in a hurry, while your wallet gets thinner and new parts get sold off at 50 cents on a dollar Frankly, you could put a red stripe on a hood and go a second faster. In other words, a driver putting a really good lap together and gaining time with mods not playing any role in the outcome. So, there is that to consider, especially if you cant reliably FEEL and hence judge each mod. Going forward, you'll have a faster car due to a bigger blower and slightly different weight balance (I assume). This will bring new challenges of faster speeds from which to start corner entries, etc. Albeit on your track this may not matter as much, due to its config. PS Note that GM recommends 2.5F and 2.0R for ZLE. So not surprised they gave ya this rear camber if you asked for ZLE values, albeit i think most ZLE owners run a higher F camber. Bottom line, i would judge its effectiveness based on tire wear and since you haven't commented on this subject per se, i assume it was alright? |
11-20-2020, 11:01 AM | #42 |
spl parts just announced they will be doing a black friday sale 20% off if anybody wants to grab some!
