03-04-2019, 01:56 PM | #29 | |
Drives: A few Join Date: Oct 2017
We are talking more DE level guys here though where 90% is going to be good enough and it's not that hard to do if you understand how to do it. I'm certainly not suggesting someone easily figures out a 4 way damper while changing spring rates, tire compounds, etc in a few sessions. A buddy does that for Indy and they have a shock dyno in their rig, tons of sensors that they can run during practice, etc. In those cases, I agree with you. But improving upon MRC with mid range(4-5k) dampers is certainly possible for track day enthusiasts who invest the time to learn suspension tuning. Your first timer buying some 3 way MCS dampers and just "playing with settings" will never get there. It takes time to learn it first.. after that it's fairly rinse and repeat. As for changing it per track that again depends on how serious you are. I don't bother because I'm also not going to change springs rates like a real race team would. I'm there to have fun so that 90% range again is good enough for my DE car. I have been there, I've had multiple springs that I tested at different tracks to find the ideal setup for each.. but quite frankly I just don't care to anymore. I think sometimes we just go too far in thinking the MRC setup is magical and it's super hard to improve upon. Having said that I have no plans to change mine out because the 1LE is just a fun toy I take to the track sometimes. It's not my race car and it's not my primary DE car. Heck, it'll be third or forth in line to be with me at the track now. It's PLENTY good enough stock for what I need it to do. Although I still kind of want a ZL1 or ZLE My camber comments were specifically about the SC3R. Different tires like different settings. To evenly use the regular SC3 -2.6 isn't enough in my experience. From the (edit: 1) ZLE guy I've talked to -3 is not enough for the 3Rs. I haven't run them because the one 1LE guy I talked to that did destroyed his fronts in 1 day with -2.5. Well destroyed the front outer edge, the rest of the tire was still great of course.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback Too many cars.. never. |
03-04-2019, 02:38 PM | #30 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Dave, now that you have put it this way: i fully agree with ya! Id only add one extra thought:
I do believe MRC is a big trick suspension which suits a dual purpose car like no other. Track setting is mighty capable, while touring is nice for long drives to and from. Elsd is calibrated accordingly and so is PTM. That said, for a hard core folk there clearly are ways to improve on it should they wish to move towards more of a race car vs a street track car. But for a vast majority of us, major pace improvements will come with more skill and stickier tires - guaranteed and with zero risk of possibly messing up an already highly capable set up. That was my key point i suppose. Cheers! |
03-04-2019, 02:47 PM | #31 |
I have 2.6F on my 1le and the wear is just fine with G3s.
When i ran slightly wider RE71R the inside wear was s bit of an issue on inside front. So all in all it works for me. |
03-04-2019, 03:20 PM | #32 | ||
Now if I was less lazy and would swap them on the wheels I could get a lot more life out of them The other 1LE guys at Sebring have similar wear issues. Well the ones running 2:26s or so are anyways.. I'm sure the guys running mid 2:30s aren't having as much wear
-Dave
03-04-2019, 04:25 PM | #33 | |
03-04-2019, 05:52 PM | #34 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
While the RE71r I believe have the same tread depth across the entire tire. Pretty genius of Goodyear if you ask me.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
03-04-2019, 06:55 PM | #35 | |
Besides it costs extra ans makes little sense to me... |
03-04-2019, 09:47 PM | #36 | |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
I really appreciate all the info you guys are all giving, makes things a lot easier than trial and error.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
03-04-2019, 09:49 PM | #37 | |
03-04-2019, 09:52 PM | #38 | |
I've heard guys can get up to 3 track days out of the SC3R's if they flip them side to side. Your thoughts?
03-04-2019, 11:48 PM | #39 | |
Also I assume these tires would need a lot of negative camber (more than -3) like the SC3R and R7’s do in order to not cord prematurely on the inside or outside edge?
03-05-2019, 01:17 AM | #40 | |
If you want to maximize longevity (and cost) go with a square set up a la Provoste. If my memory serves me right he runs 285s 18s all around without camber plates but with a strut mod. This permits him to move wheels F to R. Otherwise Todd always recommends getting 2 sets of fronts to a set of rears for a staggered set up. I am pretty sure Provoste's camber doesnt exceed 3 and he drives his car to/from long distances. His info is in one of the threads but i cannot find it now. Hopefully he will chime in here with details. Otherwise just PM him. PS dont be afraid to skinny the size of skicks a bit. They are stupid fast regardless |
03-05-2019, 10:04 AM | #41 | |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
03-05-2019, 08:38 PM | #42 | |
You use Pirelli DH slicks so I assume that would be your recommendation over other options? I see GTTrackDays.com has 19" Pirelli slicks, any reason not to go with 19" wheels except less selection of slicks? He doesn't list inventory so I'm not sure if the size/spec list is referring to Pirelli DH slicks or another type of slick. Was thinking of going with 305/690/19 that have a 27" diameter. Does the 690 stand for the side wall height?
Tags |
coilover, dssv, track, zle |
