Old 06-23-2018, 10:06 AM   #29
jbp8653
jbp8653's Avatar
Drives: 2017 ZL1,2013 ZR1, 1952 C3100 Resto
Just a question that maybe this is the wrong place to ask but here goes anyway. Would it be advisable to use this oil in a C6 ZR1? Seems like if it works good in a LT4 it should work good in a LS9.
2017 ZL1,Mosaic Black, auto,nav/pdr, Roto Fab,Mamo
2013 ZR1 60th Anniv.
1952 C3100 resto-rod. LS6, 4L60e, 228R cam
jbp8653 is offline   Reply With Quote
Old 06-23-2018, 05:18 PM   #30
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
I think it's supposed to aid the Direct Injection engines. Not sure if it would benefit the LS9 much/at all. Somebody with more experience may want to step in.
Old 06-23-2018, 06:32 PM   #31
hashtag
hashtag's Avatar
Drives: 2018 ZL1 A10/2018 GT350R #JR603
Originally Posted by Can'tHave2MuchHP View Post
Thought I'd make a post to help out anybody looking to do their 500/1500 mile service. And actually any service after that point too.
Let's get started with Oil. The OEM used fluid on the ZL1 is Mobil 1 5w30. You can use that oil if you're just driving on the street/drag strip. If you're tracking, you'd want to request 15w50.
As I'm sure most of you know by now, Mobil 1 brought out a new oil with GM for the new LT5 (ZR1) and LTA (CT6 V-Sport) and is now the standard fill for dealers on LT1 and LT4 engines as well. It's called Mobil 1 ESP 0w40 Dexos 2. Yes, long name. This is NOT the same oil as the current 0w40 Extended Performance or 0w40 European. This is brand new and is for the LT1, LT4, LT5, and LTA engines. For the LT4, it can be used for both street AND track use. I would highly recommend using this oil for ZL1s, ZL1 1LEs, Z06s, CTS-V3s, and LT1 based cars. In my case, I think the car idles and revs a little smoother, call me crazy but I'm not the only one reporting this. And the big benefit is of course it can handle both street and track use so no need for an oil change before a track day. This oil is ONLY available at Dealers at this time, it will be available to the public at the end of this year.
As for the differential fluid, you ONLY want to use the OEM ACDelco stuff. Don't let them put in anything else. The additive in the OEM fluid is critical to the eLSD.
I HIGHLY recommend noting the names and part numbers on your phone or a piece of paper when you go to take the car to service just to make sure you double check their work. Had I not been there, my service department was going to use a generic diff fluid and OEM 5w30 oil.
To make it easier, here's what you need to know:
Part Numbers & Names:
New Oil: 19370233 - Mobil 1 Dexos 2 0-40 ESP - 1 Quart (You'll need 10) (Just for extra info, 1 Liter is GM Part # 19353135 and a 55 gallon drum is GM Part # 19370234.)
Diff Fluid: 88862624 - 10-4034 - 75W-90 ACDELCO 1 Quart (You'll need 2, mine took about 1.75-1.8 quarts)
0w40 Oil Cap: 12686472 (Not necessary, but the info on it will reflect oil in the car)
Oil Filter: ACDelco PF64
While you're there, see if there are any open TSBs or updates for the car.
Hope this helps!
Side note: I have a Borla 60606 X Pipe on mine with a Corsa Xtreme 14784BLK axle back, which I installed at about 200 miles. So I had the tech re-torque all of the clamps. Happy to report they weren't loose or leaking at all, but it's always a good idea to check. If you want to read more about my exhaust setup, here's my thread on it: https://www.camaro6.com/forums/showthread.php?t=528893
Attachment 941974
Attachment 941977
Attachment 941978
Attachment 942041
Hi, I tried finding the Mobil 1 with the 19370233 part # & it stated that rhe oil was discontinued. Just to confirm the part number is 19370233?
2018GT350R+2018 ZL1 "Red Hot" A10 w/ PDR, Nav, Carbon Fiber Hood insert, Carbon Fiber Dash Insert, Carbon Fiber Fuel Dior & Sun Roof. T/M T-Body, Roto Fab & Borla S Type.
hashtag is offline   Reply With Quote
Old 06-23-2018, 06:42 PM   #32
TMS
TMS's Avatar
Drives: 2018 ZL1 1LE - HBM, PDR
I just ordered some a week ago and received via UPS yesterday. Number is correct. I did hear they are phasing out the Liter stock for the Quart stock. Perhaps that is cause for the part# confusion.
Sent from my SM-G950U using Tapatalk
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
TMS is offline   Reply With Quote
Old 06-23-2018, 07:31 PM   #33
Can'tHave2MuchHP
Drives: Fast
I listed all three part numbers you can try. Liter is likely what still works, the quart is JUST released. So try liter and quart numbers and see. Both numbers are correct.
Old 06-23-2018, 07:56 PM   #34
Alain
Alain's Avatar
This is great info !!!!!! Thank you!!!!!
I should be hitting the 500 mile mark sometime next week. I need to get those ZL1 Addons lifting points for the pinch welds before I bring the car in.
2018 ZL1 1LE/Red hot
Old 06-23-2018, 08:42 PM   #35
Can'tHave2MuchHP
Drives: Fast
Old 06-24-2018, 09:46 AM   #36
meSSohappy
meSSohappy's Avatar
I just had my oil changed. Dealer wouldn’t put in the 0w40...said it was an upgrade for corvettes only and not included in the free oil change. Said they could order it and install on
Next oil change if I paid for it. Is this the case everywhere? Are you guys getting the upgrade for free? I’m in Canada FYI.
Also, great post, but is there an official GM site somewhere wher I can go to show my dealer this posted Mobil 1 upgrade?
Thanks ��
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
meSSohappy is offline   Reply With Quote
Old 06-24-2018, 12:59 PM   #37
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Thanks ��
It's not Corvette specific, it's ENGINE specific... they should do their homework better. But I am not sure if it's included in the courtesy oil change.
Old 06-24-2018, 01:25 PM   #38
mspeed1LE
mspeed1LE's Avatar
Drives: ZL1 1LE SUMMIT WHITE
Great info! Changing oil for track sessions is a PITA.
2018 ZLE * StudioRSR Half Cage * SkidmarkGarage Rear Seat Delete * ZL1ADDONS Lift Pads * Roto-Fab CAI * Forgestar CF5-V's * Michelin PS4S * Racequip 6 Pt. Harnesses * Sub-strap Brackets by Carmena Performance * Speedhut Shift Light * Leroy Eng. Hidden Hitch (for the TYR RAT)* Gen5DIY Rapid Flash 3rd Brake Light * KOOKS 2" LT * Green Cats * AWE Cat-back Track Edition *
________________________________________
2005 NISSAN TITAN
1997 BMW E39 (Thug In A Suit) R.I.P. 10/04/18
2002 MAZDA Protege 5 (Time Attack, Hillclimb) SOLD
mspeed1LE is offline   Reply With Quote
Old 06-24-2018, 10:40 PM   #39
meSSohappy
meSSohappy's Avatar
IKR...when they said that I mentioned it was the corvette engine....not worth arguing over on the first oil change but will be pushing for it at 1500 miles.
Old 06-25-2018, 01:10 PM   #40
SDMARO4482
Drives: 2017 NFG ZL1 M6
Great post. I recently switched to the ESP 0W 40 and concur with your assessment that it runs smoother and quieter. I was a little surprised at how noticeable it was.
Also, since a liter is slightly more than a quart make sure you check at the 9 liter point. At 9 liters it was just barely showing on the fill marks. Having the quart product out should take the guess work out. I used just a hair over 9 liters. You do not want to overfill!
SDMARO4482 is offline   Reply With Quote
Old 06-25-2018, 01:39 PM   #41
KevinTernes
Drives: 2016 Camaro SS
If you buy a 55 gallon drum, it looks like you save about a dime per quart.
KevinTernes is offline   Reply With Quote
Old 06-25-2018, 07:25 PM   #42
Alain
Alain's Avatar
Thanks ��
Boy, I hope my dealer doesn't give me any of this crap when I go next week to get my oil changed.
