12-08-2017, 07:17 AM | #29 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
I can't recall as to what it was, slander maybe.. Apparently who I recommend the shell gas station to, worked at a speed way refinery, they escalated it up the ladder. I was 23 years old then, at the time, when someone from corporate threatened to sue me because of I think it was slander term they used. I just didn't care. let them figure it out.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
12-08-2017, 09:37 AM | #30 |
Drives: 2SS 1LE Join Date: Oct 2011
Has a lot of the "red flags" of a scam...
12-08-2017, 02:19 PM | #31 |
Drives: 2010 Camaro Join Date: Nov 2009
Oil Man has it correct out of all that have posted, at least what I have read.
First, ALL fuel comes from the same bulk tank farms and is graded by octane. Any additives above what is required by law for highway use is done either in the truck transport or at the station when it is delivered by the driver. I have watched at the port and all fill up at the same bulk tanks. Next, while top tier fuel was an excellent choice for older port injection engines as the fuel constantly washed and cooled the valves keeping them clean and deposit free, no fuel touches the intake valves back sides where the coking takes place any longer with GDI engines (except the few that have added in small port injectors in an attempt to slow the coking rate, but so far these all show coking nearly as severe as no hybrids, but is far from a fix. So, what is top tier doing for these new GDI engines? Absolutely nothing except possibly helping injectors stay clean, but at 2,000-3,000 PSI there is not a very high incidence of "dirty" injectors as in the past port injection engines operating at 45-55 PSI. |
12-08-2017, 02:40 PM | #32 |
Drives: HB 2SS Join Date: Apr 2017
Isn't it more of a question of the compression level of the engine and detonation? It doesn't really clean anymore but the octane plays a role.
12-08-2017, 03:02 PM | #33 |
HYPER SS
I thought it came down to detergents they were using.
Ordered: 1/15/2016
12-08-2017, 11:46 PM | #34 |
12-09-2017, 08:34 AM | #35 | |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
12-09-2017, 10:57 AM | #36 |
Drives: 2019 ZL-1 Join Date: Feb 2009
No thats Bullsh*t.......
4 degrees would be like 87 octane.....or less....
2012 Yukon XL Denali w/ 6.2 AWD |
12-09-2017, 12:25 PM | #37 | |
Drives: 17 Camaro 2SS 50th Anniversary Conv Join Date: May 2017
BP is a Top Tier Gas http://www.toptiergas.com/licensedbrands/
2017 2SS 50th Anniversary Convertible,A8,MRC,NPP,NAV,Black Bowties
12-09-2017, 12:31 PM | #38 |
I use ethanol free 93 which is available at a local gas station that has newer tanks. The gas is also dispensed from a pump that is only for this gas.
The pumps that have the button you press to select the grade can have up to a gallon of 87 in the line, if the last user pumped 87, there will be up to a gallon of it still in the line. So if your putting 93 in, your not really getting 93, it will be lower with the gallon of 87 put in with it. The ethanol free is only 4 cents more per gallon than local top tier's, and I get 2.5 mpg better than any of the top tier gasolines I've tried. If you can find ethanol free premium in your area, from a dedicated pump for it, run a tank of it and see for yourself.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
12-09-2017, 08:25 PM | #39 |
Drives: 2014 Stingray, 2017 Cadillac XT5 Join Date: Jun 2017
The multi-button pumps give you far less than a gallon of the last selection. As I recall when I complained to BP a couple of years ago, the hose has about 3/10 of a gallon. That is too much as far as i am concerned, but far less than a gallon.
If that ethanol free pump has the name of a Top Tier gasoline brand on the pump, it is also Top Tier. Gasolines listed on toptiergas.com must have Top Tier additive packages in all of the pumps dispensed with their name affixed. For it to be non - Top Tier, it must be a separate pump with no markings for the Top Tier listed brand. |
12-10-2017, 07:09 AM | #40 | |
Drives: 17 ZL1 Join Date: Mar 2017
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp |
12-11-2017, 11:44 PM | #41 |
I use Unicorn pee-pee. It makes me fly.
02-25-2018, 11:43 AM | #42 | |
Drives: 2018 SS 1LE Join Date: Feb 2018
Back when the premium was 20 cents a gallon it was a no brainer. These gas stations have gotten clever advertising only regular and diesel. You pull in and find up to a 80 cent differential on premium now. I have a brand new HEB gas station that undercuts everyone else. Gas gets sold quickly. I understand they may not have the “top tier” additive package but does it really matter? I’ve resolved to put Techron in every month instead. HEB premium is $2.50. The “top tier” marketing cartel licensing play guys charge $2.80-$2.99 for premium. I use 150 gallons a month. That’s between $45 and $74 extra a month. I’m not going to pay that. I’ve bought enough Techron for 6 months from Amazon. I also bought Lucas additive I might use between Techron. Some Liqui Moly Jectron to change it up every now and then. It seems the sensible thing to do. These guys will market to you like Michael Kors does to women. I can buy my own additives if need be. I’m not paying 80 cents a gallon extra. They do this to drive more traffic to their stations rip you off on gas and get more convenience store sales. If they stop making us subsidize regular grade gas and become more honest about displaying premium gas prices again I’ll go back. Until then I will vote with my wallet. They think people who buy cars that need high octane gas are price inelastic fools who don’t care about what they pay. They are wrong. Most of us are intelligent enough to call out the marketing BS play. They want everything to be a fashion statement these days “I use xyz gas only, I only wear xyz headphones, I use only xyz cell phone service” etc. it’s gone a bit too far. |
