07-06-2017, 06:40 PM | #29 |
Every car I've had launched harder at the track. I think your car may bog a little more with a harder launch. At least my 2010 manual did.
The 6 gen launch is phenomenal both track and street. Meanwhile the dodges, mustangs and M4 are all difficult to launch. Was your 3.5 done with the pressing of the brake to the floor and the gas pedal so the car revs at 1800 rpm and you just lift off the brake and step into the gas. Stock at the track my best run was with me just mashing the gas pedal. Using the launch control cost me a tenth. Not engaging launch control but foot braking and holding gas at around 1700 rpm was tenth worse than the launch control. So, basically, my best technique so far is just mashing the gas pedal like an idiot. My 3.4 was using "mash control."
SS, A8, Procharger, M&T's and stuff... |
07-06-2017, 07:38 PM | #30 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Launch control for the street. mashing the gas with the foot lightly on the brakes at the track with all nannies off. Not enough to hold the car from accelerating...but enough to keep it from moving forward slightly. The car will move slightly if one simply transfers the right foot from brake to gas. It seems to hit the tires a little bit harder than just letting off and flooring it.
I cant get a good launch on the street without TC/launch control it seems. But then again I haven't practiced it a ton. I get no bog with a hard launch at the track since I did transmission tuning with removal of torque management. When stock with a hard hook I could feel a slight bog/reduction of power even with all nannies off. yeah the 3.5 was holding the brakes and using the launch control just flooring it. |
08-05-2017, 03:44 PM | #31 |
Drives: 2017 ZL1 A10, 2015 C7 Z51 Join Date: Aug 2011
Best I did on the street was 3.7. This was Sport mode, no burnout, stock tires, traction control on, quickly roll into first and then mash it the rest of the way. Think my wife was in the car when I did it as well.
2017 Camaro ZL1 - Nightfall Gray Metallic - A10 - Roto-Fab intake
08-07-2017, 07:37 AM | #32 |
Drives: 2016 CAMARO 2SS Join Date: Apr 2017
Best to date is 4.3 no tcs with some wheel spin in the TEXAS heat. Looking forward to some cooler days!!
2016 SS A8 STOCK 12.35@113.6 DA 1956
PRAY E85 TUNE,PRAY PORTED IM/TB,ROTOFAB DRY, DRAG PACK 11.33@121.8 DA 1248 PRAY PORTED MSD, 2" TSP LT's 11.38@122.4 DA 3664 GFORCE DRIVESHAFT,LME 174 T-STAT,ATI UDP up next... |
08-14-2017, 05:12 PM | #33 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
I'm catching up... Just finished up my water/meth injection install reworking the tune. Sent from my iPhone using Tapatalk |
08-14-2017, 06:24 PM | #34 |
Drives: 17 SS a8 Join Date: Feb 2010
This is my best. Warmed up 20" drag radials.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
08-15-2017, 08:46 AM | #35 |
Drives: 2016 2ss Join Date: Jun 2016
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in. |
08-15-2017, 08:48 AM | #36 |
My best is still 3.9 lightly warming up my f1's. Maybe I should have bought a 4 banger.
08-15-2017, 09:11 AM | #37 |
This is only about a 1.75sec 60' time. I am curious what a sub 1.5sec 60' time would show for a 0-60.
08-15-2017, 10:33 AM | #38 |
Drives: 2019 2SS & 1998 SS Join Date: Jul 2017
This is best I've got. Bone stock 2016 SS M6 on stock tires. Just heated em up some on a good concrete road. Never been to the track yet, only had the car a month.
08-19-2017, 12:12 AM | #39 |
Drives: Camaro 17 SS Join Date: Jan 2017
Just a little track work.
08-23-2017, 09:50 AM | #40 |
downhill?
2016 NFG 1SS A8
08-23-2017, 12:24 PM | #41 |
Mine couldn't hit 60 in 2.8 unless I pushed it off a cliff.
08-24-2017, 01:48 AM | #42 |
Drives: 2016 2SS Join Date: Jul 2016
I will have to see what mine is next time out. It is hard to get it all to work with the converter. I have gone 1.44 60ft's though. The 1.6 60fts seemed to produce 3.4-6 0-60 average but with taller tires it is all off. It also said I was running 11.7's when I was running 11.0's.
