10-09-2016, 06:56 PM | #29 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
I enjoy my popping sound on deceleration.
I what makes me enjoy the car so much.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
10-09-2016, 08:42 PM | #30 |
Drives: Miss Con Ception Join Date: Aug 2016
10-10-2016, 08:41 AM | #31 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
The belch of a fire breather!
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
10-10-2016, 09:59 AM | #32 | |
10-10-2016, 10:07 AM | #33 |
Drives: 80 Z28 - 93 Z28 - 14 Camaro SS-RS Join Date: Sep 2016
On Hollywood Blvd I got to take a Hurican on a test drive it was awesome and when you put it in Sport or Corsa mode it open the exhaust up and puts a huge smile on your face. It was a life changing experience to drive that car. I got it up to 130Mph up in the Hollywood mountains.
10-10-2016, 10:57 AM | #34 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
So for those "bashin" tunes that allow decel pops...do you have stock exhaust manifold/cats or headers short/long wit or wit/out HF cats? Per sig my tune wit dynoSteve and I seriously doubt he tunes for a "fake" snap/crackle/pop just to pull the wool over our eyes...really??? I attributed this to my HF cat's more than anything...stock cat's on our cars ARE THE MOST RESTRICTIVE part period...stock cats burn all gases by SLOWING DOWN the exhaust flow...just look inside....soooo with HF or off road ext these gases then end their existence on a fiery explosive note...any dynoSteve custs wanna chime in or even Steve if he is lurkin...lol....my ONLY concern is my stock muff's splittin but then I can justify cat back!
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
10-10-2016, 11:20 AM | #35 | |
They are always looking for better brains. |
10-10-2016, 11:31 AM | #36 | |
The noise you hear in a fuel injected 21st century vehicle when decelerating. Those pops when decelerating are produced when no fuel is introduced to a cylinder. There is no combustion and the exhaust does not rush out of the cylinder. So there are pulses of air coming through the exhaust instead of a steady flow of exhaust gases. The different lengths of the exhaust paths as well as the intermittent fuel shutoff per cylinder can make the sound seem random. The solution if you don't like the sound is to avoid engine braking. Use the brakes instead of downshifting. Upshifting or sliding into neutral. TLDR? Me either I hope it helps.[/QUOTE] I didn't miss the point...I was just responding to the OP's suggestion that every 21st century fuel injected car gurgles when decelerating. I wanted to point out that it is not an inherent ordained attribute of awesomeness in the Camaro but rather a tuning choice made by GM....and if the owner has the audacity to not like it...it can be removed with a little tweak in the tune. |
10-10-2016, 11:33 AM | #37 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Norm
'19 WRX 6M (the family sedan . . . seriously) |
10-10-2016, 02:30 PM | #38 |
Boom...and no not a GM engineer...just good ole common sense...factory exhaust designed for EPA tree huggers...so no gas guzzler tax ROFL...
10-10-2016, 04:29 PM | #39 |
10-10-2016, 04:32 PM | #40 | ||
Your Camaro does not. |
10-10-2016, 06:19 PM | #41 |
Have you seen the inside of the OEM mufflers? They have a J-tube for the drone and more insulation that most people's attics. Again...without changing anything else on the car, the gurgle can be removed WITH A TUNE. You were right though, there is a difference between a backfire and what our cars are doing.
10-10-2016, 06:30 PM | #42 |
Major difference between M6 and A6 exhaust cat back....
