06-30-2016, 01:24 PM | #29 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Also remember, any sludge forming compounds formed in the crankcase are routed through the PCV system back into the intake, where they can sludge valves and everything else. So yes, gasoline can impact sludge formation all over the engine no matter where it is injected. |
06-30-2016, 01:43 PM | #30 | |
Drives: 2016 Camaro 1LT M6 Join Date: Aug 2008
Sure, we will go with that. Sludge is formed basically when oil is never changed or there is a terrible design flaw that allows for oil to build up in one area of the engine. Gas has almost nothing to do with sludge because once gas becomes dissolved into oil it actually breaks it down into a thinner weight. It's much more important to use a high grade oil in a direct injected engine than the actual choice of brand gasoline. Not the other way around. Top tier gas is not really a concern anymore thanks to the way that the fuel is actually directed and aimed into the compression stroke. The higher PSI allows the fuel to be become a very fine mist instead of rain drops. Doing that allows for a much cleaner burn and less chance of residue sitting and burning on the actual injector. |
06-30-2016, 02:30 PM | #31 |
FASTER!
Drives: Challenger Hellcat, 2SS Camaro Join Date: Apr 2008
Meh, I only run top tier (Shell) in my supercharged Challenger because it's critical in that motor/setup, but for anything else any big brand should be fine. I have a buddy who's a pretty high up at Conoco Philips and he has told me there really is no difference no matter where you buy it outside of the detergent additive each brand uses. It all comes from the same supply chain. I've never checked, but figure he'd know. He also has a twin turbo 1000HP Challenger so not like he's not a car guy.
In my Camaro I just run a major brand that's cheapest for 93 octane. For those talking about a dealer service to clean the top end, what about a Seafoam treatment yourself? |
06-30-2016, 03:28 PM | #32 |
Drives: 2016 Camaro 2SS Join Date: Jul 2015
06-30-2016, 03:33 PM | #33 | |
マスタング = 遅い
Bottom line is I only run top tier gas in all my cars, so there is no change for me. As for the oil, I mentioned that in my post on the previous page... Not the same thing. |
07-01-2016, 09:32 AM | #34 | |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Any oil being recycled through the intake does have to go by the valve tops and contributes to the carbon build up. |
07-01-2016, 10:26 AM | #35 |
Drives: 2016 Camaro Black 2SS, 69 Camaro Join Date: Jan 2016
I just checked my Mishi can and there was at least 2oz in it. So, in my case money well spent. And I do use "top tier" gas as well.
2 SS Murderd
69 Camaro Pro-Touring |
07-01-2016, 01:48 PM | #36 |
FASTER!
RE: Seafoam
How is it not the same? It's a detergent that cleans the top end/valves through the intake. I'm not talking about pouring it in the fuel tank, I'm talking letting it be drawn through the intake via vacuum line. I've used it several times on other cars. Any forum vendors I should consider for the Mishimoto? |
07-01-2016, 04:13 PM | #37 |
He's probably talking about walnut blasting
07-01-2016, 05:39 PM | #38 |
Drives: 2016 Camaro 1SS Join Date: Jan 2016
This would explain why I never have any oil in my can. Most of the time I drive pretty relaxed or at least at lower rpms.
2016 Nightfall Gray Metallic 1SS 6MT, Edelbrock E-force supercharged, Killer Chiller with 3-way bypass, catch can ***FOR SALE, MESSAGE ME IF INTERESTED***
Previous: '12 Mustang GT 6MT (12.47 @ 115.88) '09 G8 GT (11.86 @ 120.47) '05 GTO 6MT (slow, lol) '01 Grand Prix GTP converted to turbo, high 11's |
07-06-2016, 08:34 PM | #39 | |
Drives: 2016 Camaro 2SS NFG M6 MRC NPP Join Date: Mar 2016
http://www.corvetteforum.com/forums/...on-valves.html "Quote: vettman96 asked: Is there any issue known with deposit buildup on the back side of the intake valves due to not having a port injection system? Is GM aware of, and if so do they have any plans for correction with the intake valve coking issue present in the direct injection platforms as a result of the PCV system. Many members of the community are seeing an excessive amount of oil and carbon deposit buildup on the intake valves after only 5,000-10,000 miles and worse with even higher mileage engines on the C7. While I understand the purpose of the PCV system as it relates to emissions, with the introduction of direct injection there is no longer a cleaning process in place that would be naturally present such as from a port injection system. Quote: Tadge answered: Good technical question vetteman96. The short answer is: No, we have not seen any issue with deposit buildup on the back side of the intake valves due to not having a port injection system. You correctly point out that the continuous flow of clean air and gas over the intake valve tends to keep it very clean. That has been a characteristic of small block V8's for decades. Of course, appreciation of that characteristic is limited to those who disassemble their engines. Most customers are unaware. Given that all SIDI engines give up that benefit in favor of other important attributes, we did extensive testing to make sure there were no customer-observable penalties. We intently looked for unusual deposit formation during the entire Gen 5 Small Block development phase (4 years) as well as the 200,000 mile in-vehicle long term testing. We have not seen anything unusual and zero performance degradation. Granted, deposit formation on SIDI engine intake valves is greater than what is seen with PFI engines, but the Gen 5 engines are typical for SIDI engines, and in fact better than other SIDI engines we have benchmarked. So the bottom line is that we believe the carbon build up is only an internal cosmetic issue, not anything that will affect customers over the life of their cars." |
07-07-2016, 09:23 AM | #40 |
FASTER!
I take it Tadge is a Chevy engineer? I don't know how forthcoming Chevy engineers are on these forums, but we had Dodge engineers answer questions on our Mopar forum and those of us that know anything about cars got a good laugh at their answers. It got so bad the engineers were heckled when they dared show up to events.
I don't know enough about this to discount anything Tadge posted, however, so take what I say with a grain of salt and as an experience on a completely different platform. However, being an engineer myself, I do know there are design criteria and acceptable levels of variance (think power loss) built in to a project. As long as those variances remain within the project tolerance they consider it a success. Obviously this almost always becomes a battle between the bean counters and the engineers who actually want to build the best product available and are forced to compromise to meet budget and timeline. |
07-07-2016, 12:36 PM | #41 | ||
07-07-2016, 12:43 PM | #42 |
Tadge and his team also rated the C7 A8 as track ready. It is not exactly. So take everything everything with a grain of salt. GM is just following in line with all the other OEMs on saying it's not an issue. Because loosing a few MPG or slight loss of engine efficiency is not a concern, especially when it occurs close to the end of the warranty or just beyond.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
