07-19-2023, 01:46 PM | #29 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Use to do it that way but since its in the garage on a lift with a cover, doesn't really matter that the trunk is not locked, and the weight of the trunk isn't heavy enough to press a groove in the rubber seal from the cord. |
07-21-2023, 02:11 PM | #30 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
I read your post that your original battery lasted since '12, so that says good things about your tender hook up. I knew my dead battery(ies) in both Camaros were pre-mature. Forgot to add, my old lady Camaro had a dead battery this year too, same type of hook up. I took a risk with this one and just jumped the battery and re-connected the tender directly to the battery terminals. I learned a lot this year.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
07-21-2023, 03:37 PM | #31 |
Will Cave
Drives: 2010 Victory Red 2SS LS3 Join Date: May 2023
My 2010 SS seems to crank a little slow when it's warm. It also sounds like the horn is having a hard time honking when I lock the car with the key fob. The lights always flash and do what they're supposed to do, but the horn sounds super weak sometimes. Sometimes it doesn't even make a sound at all and other times it sounds normal.
Is this pointing to my battery? The battery in the car now was in it when I bought it and I had it tested at an Advance Auto. The cold cranking amps are 750 on the battery, but the guy said it read just over 1000 when I cranked it up for him. It sounded sluggish when I cranked it up too. |
07-21-2023, 04:07 PM | #32 |
^Try fully charging your battery, and then see if the car acts differently. If the car goes back to cranking slow or low life in its accessories, then it could be the battery. Recall that the battery has to have adequate charge time and ability to hold a charge. If its not holding a charge then consider replacing it.
07-21-2023, 06:00 PM | #33 | |
Will Cave
08-04-2023, 09:05 AM | #34 |
Happy_Dan
I just replaced my original battery in my 2012 with 40K miles on it. It went dead over this last winter even on the tender. I am happy it lasted that long.
08-09-2023, 11:29 AM | #35 |
Drives: 2016 1SS Join Date: Apr 2012
If you get 3 Years here in Texas you're doing good.
08-10-2023, 01:30 PM | #36 |
Drives: 2023 Camaro SS Join Date: Aug 2023
Same. The OEM 5th gen battery somehow managed to survive 5 Arizona summers but after that it was toast every 2-3 years.
'23 Blue Camaro SS: "Pegasus"
----- gone, but not forgotten ----- '11 Gray Camaro LS: "Copmaro" '02 Red Camaro Z28: "Chimero" '01 Gold Camaro: "Goldie" '98 Black Firebird: "Blackhawk" Yes, I name cars, but they don't seem to mind. |
08-16-2023, 09:17 AM | #37 |
Never Satisfied
Drives: 2012 ZL1, 2017 Challenger Scat Pack Join Date: Nov 2014
Just Killed Mine
Replaced the OEM with another OEM after 6 years as a precaution. The replacement died on me this week after 5 years. My own fault though. It is stored in a very hot mini warehouse for up to a month at a time with no battery tender. I rotate cars in and out of the mini warehouse at 2-4 week intervals. Lesson learned, I'm going to stop by and give them a 15 minute drive at least every two weeks to keep this from crippling another battery or vehicle. Went with a Die Hard Platinum AGM this go round. I think I have learned my lesson on letting things sit.
2012 ZL1 A6 -stock for the moment, Go Mango Challenger Scat Pack Track Pack A8, 2022 Go Mango Hellcat Redeye Challenger, 2000 WS6 - M6, 433 RWHP, 405 RWTQ - SOLD
