Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 05-26-2016, 09:45 PM   #29
Tenring
Tenring's Avatar
Drives: 2014 2SS/RS - SIM
I was wondering why some were labeled E.....think I will be throwing a few filters out.
In fact I think I am running one...........................great oil change tomorrow.
Tenring is offline   Reply With Quote
Old 05-27-2016, 07:30 AM   #30
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Originally Posted by maddoggyusa View Post
This. If it's not the filter, I'd bet it's some electrical problem. The pump is probably fine... I don't think they can fix themselves.
Actually, there are reports that the bypass valve/piston in the housing can free back up and return the oil circuit to normal all on its own.
Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 05-30-2016, 08:06 PM   #31
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Wait...another oil pump failure?
I mean...again?
Not to be a smart ass, but make sure you have the stock tires on there so they won't void your entire power train warranty when you bring it in.....again....
OUCH!
Yeah, I know...
Low blow...but hey, what do you expect when you the opportunity arises to make something right but fail to do so.
TAG UR IT is offline   Reply With Quote
Old 05-31-2016, 12:59 PM   #32
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
I mean...again?
OUCH!
Yeah, I know...
Yea, maybe we should be putting coyotes in our Camaros. At least Ford honors warranties. Luckily I had a 3rd party warranty to cover my 2nd LS3.
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 07-31-2016, 10:05 AM   #33
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
Originally Posted by camguynj View Post
I recently set a Dashlogic alarm to display and remain on whenever PSI <20 In the past 2 mos it's gone off around a half dozen times but for only stayed on for a second or two when coming to a semi-sudden stop but just on an uphill or downhill incline. Oil level was a quart down so I added a 1/2 qrt and the alarm happened once again at first low dimple. Other than that PSI is 28 at warm idle, in the 40s at 1,500 rpm or above. 20k on the car. Seems the alarm goes off just when oil might be surging in the pan due to stopping on an incline Thoughts?
Your car was 1QT low so you added a half QT? Just asking.
Eddiefuzz is offline   Reply With Quote
Old 07-31-2016, 10:13 AM   #34
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Good question. Didn't want to risk over filling in case I read it wrong given the difficulty of seeing clean oil on the dimple portion of the stick.
camguynj is offline   Reply With Quote
Old 08-04-2016, 11:47 AM   #35
camguynj
camguynj's Avatar
7/31/16 Originally Posted by camguynj
Update 8/4/16 Changed oil today. 30min driving no problem mostly hiway. Exiting a fairly level off ramp about 40mph while still in 6th I had to come to quick stop -because some A-hole limo driver with NY plates (probably Mesheet Mydraws from Buttfuknstan ) must have realized he made a wrong turn and decides to stop on the ramp so I push the clutch in, no time to downshift, and apply the brakes ( no skiddding ), immediately the Dashlogic low Oil pressure <20psi display appears & chimes for 1-2 secs same as when qt low. Come to conclusion that only rpm and/or engine load% affect PSI not qty in pan
