05-09-2016, 01:31 PM | #29 |
Drives: 2013 Red Hot Camaro Join Date: Nov 2011
Chip in windshield was repaired but still visible. It has yet to be replaced
05-09-2016, 02:21 PM | #30 | |
Drives: 2014 2SS/RS - SIM Join Date: Apr 2014
On the larger crack we did. I had my son on the inside pushing gently in and out on the crack area while I kept filling it. We even used a hair blow dryer to try and get all the bubbles out and let the resin in, turned out ok......we figured what do we have to loose, if we break it we have to get a new windshield anyway. |
05-09-2016, 04:00 PM | #31 | |
05-10-2016, 10:51 AM | #32 |
SS
I heard non HUD and a square of 3m for the HUD is a cheap Alternative
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
05-10-2016, 11:12 PM | #33 | |
05-11-2016, 08:08 AM | #34 |
Ed S.
Drives: 2015 1LS V6 6 speed manual Join Date: Nov 2015
I had my '15 1LS for less than 3 months when my windshield took its first hit--and since it was up in the top corner of the passenger side I didn't worry about it. I knew I was going to get hit again--and then I'd replace the glass (zero cost in AZ with Geico). FYI: Less than 2 months later, I replaced the glass. The actual invoice for that was $606.50 total.
"This is RED 5--I'm going in!" - Luke Skywalker
05-11-2016, 04:44 PM | #35 | |
Drives: 2015 2LT/RS BVM Join Date: Mar 2015
05-11-2016, 05:03 PM | #36 |
Drives: 2017 Camaro 2SS. 2013 Camaro 2LT/RS Join Date: Dec 2013
Just had mine done last week at Safelite. OEM HUD glass was $894 ($719 for glass), but insurance covered it under comprehensive (I have a 0 deductible). I took a pic of the info in the corner of the windshield before/after and it's identical.
Because of what I learned on here, I made sure that my policy had OEM-replacement included when I bought the car. Was really glad I did! |
05-11-2016, 06:46 PM | #37 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I had mine replaced by Safelite about a year ago. I got an OEM windshield, so it says GM. Are there any differences between the "GM" and the "others" besides the name on it? Prolly not. But I wanted mine to at least appear factory. They did a really good job, no new noises, paint blemishes, interior dust/dirt, or flushness issues. Looks like it was never replaced. Thank you Alaska and the vehicle shipment to Florida. But its only a windshield, could always be worse.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
05-12-2016, 10:50 AM | #38 |
Drives: 2015 Commemorative Edition 2SS/RS Join Date: Sep 2015
I had my windshield replaced back in November... only had the car for 2 months (Brand new 2015 2SS with the HUD) when my windshield took its first hit with a rock passing a semi on the interstate. The rock hit right in the lower center of the windshield and left a dime sized star looking crack.
When I got home, was going to get it repaired as soon as I could but before I could even take it to a repair shop, the windshield split clean across from one end to the other. I was upset... hadn't even had my first oil change and was already changing the windshield. Here in Maryland they don't do windshield replacements for free - at least not with USAA. I had to pay the deductible of $500. Cost a little over $650 to replace. I also had Safelite change it out. They did an awesome job. THEN... just this past weekend the NEW windshield took another hit in the same exact dang spot as the last one while on the interstate passing another car. I swear I think these cars must have a pocket of air that sucks rocks into that area. LoL. Anyway - I took it immediately to Safelite after I got home before it also split the windshield in half, and they repaired it for $70 with that resin stuff. They also hit it with an ultraviolet light and all. The only thing that was left behind was a divit of the point of impact... looks like a bug hit the windshield basically. So, I'm hoping this repair holds up - if I gotta keep replacing windshields before each oil change, I'm gonna loose my mind! LoL. |
05-12-2016, 11:03 AM | #39 | |
05-12-2016, 10:10 PM | #40 |
