03-15-2016, 11:19 AM | #29 |
Drives: 2012 Camaro RS 2LT 6spd man Join Date: Aug 2013
03-15-2016, 11:39 AM | #30 |
Did you fill it till it was up to the fill hole? Did you make sure it was fully drained?
Sent from my LGLS740 using Tapatalk |
03-15-2016, 11:46 AM | #31 |
actually i just noticed something...the machine at my cousins shop that pumps fluid in can also suck out fluid and we think the valve for the suction side was partly open...so it was sucking out some fluid as we were pumping it in...so it might only take 2 qts...
03-15-2016, 11:58 AM | #32 |
Drives: 2015 Black 2LT RS M6 Join Date: Aug 2015
I just changed mine out for the Royal Purple and tho I didn't measure it, we have it in 5 gallon pump buckets at work it looked like a lot more than 2 quarts in the drain pan.
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
04-20-2016, 11:48 AM | #33 |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
Bump....
Doing this this weekend...
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
04-20-2016, 02:42 PM | #34 |
Drives: 2015 Camaro 1LS M6 Join Date: Jan 2016
I think I slightly overfilled mine by half a quart. However, in doing so, I noticed the notchiness(?) that I once had is completely gone. It shifts a lot smoother. Is it okay to leave it like that or should I drain a little bit out?
Sometimes when I'm at a stop light, I can smell a slight gear oil smell through the vents though. However, I had that before I did the trans oil change so maybe that's not it. |
04-20-2016, 04:41 PM | #35 | |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
04-20-2016, 06:28 PM | #36 |
Okay, thanks. When I filled it up, I used the tube method from inside the engine compartment. When the gear oil started backing up into the tube, I quickly pulled the tube out and screwed the bolt plug back in. The tube that I used fit snugly into the hole. Meaning, no oil was able to escape when I was filling it except when I quickly pulled it out to put the bolt plug back in.
04-21-2016, 09:28 AM | #37 |
Drives: 2013 LS Join Date: Mar 2014
I am running royal purple in mine as well, switched over and you can tell a night and day difference. I also switched over to a hurst short throw shifter with the upgraded bushings. really made a huge difference in driving the car!
04-21-2016, 07:51 PM | #38 |
+1
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
03-17-2018, 07:27 PM | #39 |
Drives: 2015 Camaro 1SS 6M Join Date: Dec 2017
I agree. The 75-90 Redline oils worked great in all 6 of my Nissan/Datsun transmissions. I also used redline in my NP435. Great stuff.
01-17-2019, 11:13 PM | #40 |
Do not put gear oil in your transmission!! The gear oil is not designed for your tremec transmission!! You are going to eat away at the soft metals in your transmission if you don’t remove that. Ive done an excessive amount of research and if you refuse to use the oem fluids, in the diff and tranny, you can use the royal purple max gear 75-90 for the diff, and synchromax manual transmission fluid which is compatible with Dexron lll api rating and both products won’t damage the soft metals that comprise the synchros in the tranny!! Get rid of that amsoil stuff, I read it contains phosphorous and zinc which will react with the metals in your tranny. Use royal purple, it’s the safest to use next to the oem fluids! And it has the best shearing properties of any oil on the market. Which means more protection for moving parts!
01-17-2019, 11:37 PM | #41 | |
The diff takes 1.2qts |
01-18-2019, 09:36 AM | #42 |
I have used Redline in my old Camaro, same year and driveline. Amsoil in my current car. Amsoil in the diff, I have used royal purple as well (in my old Camaro 6 speed.)All good stuff, especially is running on the track.
