Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 01-27-2015, 12:18 PM   #29
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Hey John, think there was a typo. 18" 10.5 +53 fit.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 01-27-2015, 12:47 PM   #30
62nalide
62nalide's Avatar
Drives: 2013 SS
I'll post pics later today if folks want pics of different setups.
62nalide is offline   Reply With Quote
Old 01-27-2015, 06:09 PM   #31
suspectz28
Drives: 2011 SS
Will the c4 Zr1wheels fit on the rear? 50mm offset
suspectz28 is offline   Reply With Quote
Old 01-27-2015, 08:37 PM   #32
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Got a link?
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 01-29-2015, 03:10 PM   #33
Pro Stock John
Writer
Race Star 17x9.5 update:
Our shipment of the new Camaro wheel is set to ship sometime in March to early April.
I'll keep checking on this.
PROJECT HEAVY CHEVY
Old 01-29-2015, 06:37 PM   #34
united1
united1's Avatar
Drives: slpzl585vert.
Hi , I just bought a set of m/h 390/40/17 mounted on bogarts . These are wider then what I see listed here . Will these fit without problems ?
Thanks guys<img src=images/smilies/w00t.gif border=0 alt= title=W00t class=inlineimg />
united1 is offline   Reply With Quote
Old 01-29-2015, 08:30 PM   #35
Pro Stock John
Writer
I have not listed them because they are an inch taller than stock, a 29.5" tire. Some might say an inch is not that big of a deal. Please share a pic of them on the car if you can.
PROJECT HEAVY CHEVY
Old 01-29-2015, 08:40 PM   #36
I've been waiting on these 18"X 11 ZL1 replicas since last summer...
http://www.camaro5.com/forums/showthread.php?t=379333
Just about to give up and get some Welds.
This also looks pretty good for an 18" DR
Old 01-29-2015, 09:25 PM   #37
united1
united1's Avatar
The car is in hibernation now . As soon as the snow melts I'll post up some pics.
Old 01-30-2015, 08:31 AM   #38
LoneCynic
LoneCynic's Avatar
Drives: 2015 BVM 1SS/1LE
I have a 2015 1LE, and though not interested in drag racing, I'd like a second set for daily driving in early and late winter when there is no snow around, but it is still too cold to run the stock wheels/tires. Would a square set of 18x9.5 40mm offset wheels fit all around on my car? I've asked this question many times around the forum, but I always get conflicting information. It seems if I'm not wanting a winter tire setup, a track setup, or a drag racing setup, then no one can give straight information.
The car comes with a track setup set stock, so I'm covered there, and I won't drive it in snow, so I don't need winter tires in that sense. I just want a daily driving set that can be rotated for longer life. I'd like advice on doing that. I want to get absolute confirmation before I pull the trigger. I was thinking of going with the TSW Interlagos or Nurburgrings in this size.
LoneCynic is offline   Reply With Quote
Old 01-30-2015, 09:51 AM   #39
Pro Stock John
Writer
I don't think 18x9.5 40mm offset wheels made by any company will fit both the rear and the front without modifications. I ran a set like that of ZR1 replicas, and the fronts required grinding on the knuckle and running a 5mm spacer. That said, I think you find a square set in a different offset.
PROJECT HEAVY CHEVY
Old 01-31-2015, 02:58 AM   #40
LoneCynic
LoneCynic's Avatar
Good to know, thanks for the response. Can you recommend the correct sizing and offset I would need in an 18 inch wheel to accomplish my goal? I had that info from another topic a while back, and just want to make sure I order the right size. I don't want to use spacers, and don't want to grind anything. I am willing to replace the front brake pads to eliminate the roller skates, and I'm willing to tie back the hand brake line, but anything beyond that is out of the question for me. I'm wanting to order a set of five, four squared setup, plus a spare. These are for daily driving, long distance road trips, etc. I don't want to wear out my stock set doing these things with the car. Any definitive information you can provide would be much appreciated. Thank you.
Old 01-31-2015, 09:50 AM   #41
FKNGRSY
Drives: 2014 1SS
Are skinny tires DOT? I wanna run a full set of weld RTS. Radial out back and skinnies up front. Anyone run skinnies on the street?
FKNGRSY is offline   Reply With Quote
Old 01-31-2015, 10:10 AM   #42
Pro Stock John
Writer
Square 18's, like TSWs or Forgestars... Nice setup but not really a drag racing setup so I don't have personal experience there. I would think though since our stock rears are 20x9 that there would be 18x9s, possibly wider, that would fit our cars.
Some skinny tires are DOT. You can drive them on the street. The MT 28x6x17s for example are DOT + Radial + Skinny.
PROJECT HEAVY CHEVY
