Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 12-08-2014, 07:54 AM   #29
marticus24
Drives: 2012 ZL1
Originally Posted by ZL1Dan View Post
Thank you for the extremely helpful post. I wish I was better at "search" on this forum!
marticus24 is offline   Reply With Quote
Old 12-08-2014, 08:27 PM   #30
Stoneb1
Drives: 2013 ZL1
Originally Posted by marticus24 View Post
Thank you!
I also received a response from SRP just before you posted this. They also said that the same kit fits the ZL1 fine. So double confirmation .
Also, thanks for the install tips... I'll definitely note them. One additional question - I haven't looked closely at the pedals, but do the stock pedals have cover that pops off like the non ZL1 pedals, or do these just bolt right on top of them? Guessing yes based on your comment about the ribs. Any other comments on your satisfaction with the SRP pedals?
The clutch and brake pedals have a cover that you remove and then drill holes into the base metal. On the gas pedal, I removed the silver part which is there for visual effect and then mount the SRP pedal directly onto the plastic remaining pedal. Sorry I do not have install pics, but any installed pics would look just like the others posted above.
Stoneb1 is offline   Reply With Quote
Old 12-08-2014, 09:23 PM   #31
marticus24
Drives: 2012 ZL1
That's exactly what I needed to know. Thank you!
Old 12-09-2014, 12:07 AM   #32
Nor Cal ZL1
Nor Cal ZL1's Avatar
Drives: 2013 ZL1 M6
As an alternative you can just add the throttle. This is how I will approach it.
Nor Cal ZL1 is offline   Reply With Quote
