12-15-2012, 03:47 PM | #29 |
9691 & 97586
Drives: 2010 SS, 1999 SS, 1993 Z28 Join Date: Mar 2009
I really hope its a true number.... and if it is... you will have gotten the freak of all 5th gens from the factory
12-15-2012, 03:51 PM | #30 |
Do you even lift, bro?
My baseline 1LE was 378WHP @ 1600 miles in a bay that was maybe 60-65*.
Thats 24 more HP. That's a TON of difference stock vs stock. Not convinced you're @ 402 but who cares really. What matters is the GAIN after mods on the same dyno with similar temps. :P
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461 |
12-15-2012, 03:54 PM | #31 |
9691 & 97586
I think comparing your dyno vid to his shows the difference in what gear the cars are in... even with the whipple on SUKXOST... his car takes a bit longer to turn up than his.
12-15-2012, 05:13 PM | #32 |
Drives: 2021 1LE Join Date: Jul 2011
12-15-2012, 06:01 PM | #33 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
I've never seen a dyno run go that quickly before on a car thats not making WAY more power than the 1LE is supposed to make. I'm guessing it was in 3rd.
But who knows...there are other factors.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
12-15-2012, 06:26 PM | #34 |
Get that 1LE to the 1/4 mile track and lets see 112-113 mph.
"Democracy Dies in Darkness" Last edited by Fraxum; 12-15-2012 at 07:20 PM. |
12-15-2012, 06:54 PM | #35 |
Drives: ‘21 ZL1 1LE 6MT Join Date: Jul 2012
Gears will make no change in horsepower. You will have to shift more frequently and you lose top speed with gears. And mpg could change as well.
ZL1 1LE Black - 6MT - PDR - Nav - Michelin PS4s
12-15-2012, 08:56 PM | #36 |
Comes down to the same thing I have been saying since I had mine on 3 different Dyno machines. Every machine gave me different numbers 2 Mustang and 1 Dynojet. Dynojet is always higher. 10%-13% higher.. I'm sure this post will get taken down again because it seems to piss people off when I explain this....
12-15-2012, 09:26 PM | #37 | |
12-15-2012, 09:56 PM | #38 |
Drives: 2013 1ss Join Date: Jul 2012
I am not sure how a dyno adjusts for different gear ratios but gear ratios effect torque and torque is an element in the H.P. equation. Think of gearing as a torque multiplier which is why they pull harder in a lower gear.
12-15-2012, 10:32 PM | #39 |
The tech said he thought it was because of the gears. I don't understand how all this works. All I know is the cars pulls harder every day.
12-15-2012, 10:40 PM | #40 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
my 2011 Vert M6 with just a CAI and GM axle-back dyno'd at 390. I was a bit surprised, but the dyno operator from Livernois said that was right in the ballpark of all the other 'stock' LS3's they've tested, so I'd believe the OP.
12-15-2012, 11:14 PM | #41 |
Don't dynos take gear ratio into account? I'm guessing it wasn't set for that perhaps?
12-15-2012, 11:44 PM | #42 |
What ever the tale of the tape turns out to be the setup on the 1le sure is making the most of what is there.
