Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
View Poll Results: Do you have 2nd Gear Grind, what's your shifter?
OEM 75 28.85%
OEM Hurst 76 29.23%
Aftermarket 49 18.85%
No 60 23.08%
Voters: 260. You may not vote on this poll
Old 02-17-2012, 10:56 PM   #29
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
Originally Posted by Bad70supreme View Post
Mine was doing it bad at high RPM, I changed the break fluid with freash dot4 and put royal P syncro mesh in the trans... My trans works awsome now, I havent had problem since the day I did it.
I also changed my trans fluid to royal purple syncromax and no longer have and grinding. I have the mgw.
IDEALG is offline   Reply With Quote
Old 02-17-2012, 11:07 PM   #30
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
I did, but I'm not sure if it's still there or not. I got the grind at high RPM quick shifts a few times, but since then I've either been shifting slower or earlier. I recently changed the fluid to royal purple, but haven't done a redline shift since then. I have the Barton shifter and love it.
Sterling is offline   Reply With Quote
Old 02-17-2012, 11:46 PM   #31
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
Thanks for voting guys. Hopefully we can get more votes to where the data is actually useable.
Click to view my build thread
The Stig is offline   Reply With Quote
Old 02-18-2012, 12:14 AM   #32
Run and Gun
Run and Gun's Avatar
Drives: 2011 1SS/RS , 1966 GTO
Out of the votes casted it looks like 75% have 2nd gear grind issues. We need a recall
A machine for shrinking time and distance.
Run and Gun is offline   Reply With Quote
Old 02-18-2012, 12:22 AM   #33
The Stig
The Stig's Avatar
Be patient. Trust me, I know how to go about this. Check out my old break squeal threads.
Old 02-18-2012, 03:26 AM   #34
Run and Gun
Thanks for your help.
Old 02-18-2012, 03:38 AM   #35
w[h]o
Drives: 2010 Camaro
What happen if you start off at 2nd gear?
w[h]o is offline   Reply With Quote
Old 02-18-2012, 08:35 AM   #36
SinisterEcho
SinisterEcho's Avatar
Drives: 2010 2SS/RS M6/LS3
The grind only happens shifting into 2nd... But if you start out in 2nd you will have a slower acceleration.... Not the best idea for racing IMO....
My Mod Journal <-- Its updated... again!
SinisterEcho is offline   Reply With Quote
Old 02-18-2012, 10:15 AM   #37
Big Top Gt
Drives: IOM 2010 2SS/RS (LS3)
Send a message via AIM to Big Top Gt Send a message via Skype™ to Big Top Gt
Only when it's cold.
When it does happen, it does it at any speed and any rpm.
Big Top Gt is offline   Reply With Quote
Old 02-18-2012, 11:48 AM   #38
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Does this problem extend into the 2012 model year?
I have been considering trading my A6 for an M6, but now I wonder...
Old 02-18-2012, 12:01 PM   #39
The Stig
The Stig's Avatar
I don't honestly know. Someone with a 2012 could answer that for you though.
Old 02-18-2012, 01:50 PM   #40
SinisterEcho
Old 02-18-2012, 02:29 PM   #41
OUTATIME
OUTATIME's Avatar
Drives: 2010 IOM 2SS/RS
I have a 2010 which doesn't grind at all - however, I can't even shift fast because it is notchy as hell. I freakin need to start lifting if I want to make a quick shift.
OUTATIME is offline   Reply With Quote
Old 02-19-2012, 11:50 PM   #42
pogiskier
pogiskier's Avatar
Drives: 2011 camaro 2ss black,hurst shifter
I had this grind issue really bad last year at less than 3000 miles. My dealer got me a new trans. and most of the issues went away. I only get it when it is cold. if i wait for 15 to 20 min for the trans to warm up i have no issues. I have read a survice bullition on this issue but I am not sure were it is now, I saw it on this site. I said that the driver needs to wait for the car to warm up before you drive spiritedly.
pogiskier is offline   Reply With Quote
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 92 06-02-2021 04:17 AM
Another TR6060 with 2nd gear grind DRG BSTN SQUIRREL V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 9 12-16-2011 03:41 PM
2011 2SS/RS Problems: Engine Squealing, Brake Squealing, 1,2 Gear Grind. Please Help. qniknam V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 10-30-2011 10:36 AM
2nd gear and Reverse of Fiero grind/won't go into gears. Any takers? Arachnyd General Automotive + Other Cars Discussion 0 03-20-2011 01:05 PM
3rd gear grind ? Only 3000km Inferno Orange SS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 22 12-28-2010 03:25 PM
