02-22-2011, 01:54 PM | #29 | |
LOL at most people here.
Drives: 2005 GTO,2006 M6, 2007 300 Touring Join Date: May 2009
So all I'm saying is the fuel really is no different. Just some bs that needs to be done to keep folks happy. Thats all I'm getting at.
Number 5952. oh yeahhhhhhh
02-22-2011, 02:00 PM | #30 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
02-22-2011, 02:02 PM | #31 |
Drives: 2011 Chevy Camaro Join Date: Sep 2010
There is a big difference in winter gas and summer gas in ny. My supra runs completey different with winter fuel(had to move storage areas and had to fuel up). EGTs where higher, timing was all over the place. Gas milage goes down in my truck gas truck yet up in my diesel. I know for a fact there is different gas coming out of the pump in the colder months. The gas stations even admit it. Delta sonic water mixed with gas is the worst out of the bunch. Sunoco is where I will always get my fuel because the cars change the way the run the littlest with their fuel.
02-22-2011, 02:05 PM | #32 | |
02-22-2011, 02:07 PM | #33 |
It sure is. Right now I have the EPA and DOE bothering me for my annual reports on what was sold for the year and to who and for what reason. A bunch of useless departments that the taxpayers shouldn't have to pay for if you ask me.
02-22-2011, 02:11 PM | #34 |
To answer the OP question lol, it most likely are the additives you put in. Those mixing with whatever additives the gas station may have put in could real be a bad combo and not compactable with one another.
02-22-2011, 02:16 PM | #35 | |
Drives: 67 Camaro Convertible Join Date: Jun 2009
Just found this on www.ask.cars.com The difference between conventional summer- and winter-blend gasoline has to do with the Reid Vapor Pressure of the fuel. RVP relates to the volatility of a gasoline. The more volatile a gasoline, the more likely it will evaporate as the temperatures rises; evaporated gasoline contributes to unhealthy ozone and smog levels. Summer gasoline has a low RVP and is less likely to evaporate when compared to the high RVP winter grade. The Environmental Protection Agency says conventional summer-blend gasoline contains 1.7 percent more energy than winter-blend gas, which contributes to the summer blend’s slightly better gas mileage. The Energy Information Administration says the switch between the two fuels happens twice a year, once in the fall (winter blend) and again in the spring (summer blend). Summer-blend gasoline is typically more expensive to produce than the winter blend, and it won’t affect vehicle performance or the durability of the engine and fuel system, according to the EPA. In many large cities as well as California and New England, the EPA requires the use of reformulated summer- and winter-blend gasolines. These RFGs contain oxygenates that lower RVP and other toxic chemicals even further than conventional gasoline.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof Placed order at dealer 4/24/09 1100 - 4/28/09 2000 - 5/01/09 2500 - 5/05/09 3000 - 5/05/09 3300 - 5/30/09 3400 - 6/05/09 3800 - 6/18/09 4000 - 6/18/09 4B00 - 6/18/09 4200 - 6/22/09 5000 - 7/01/09 6000 - 7/01/09 It's Home!! 0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less |
02-22-2011, 03:47 PM | #36 |
Custom User Title
Drives: Fast Join Date: Jan 2009
I like the idea of disconnecting the line somewhere and turning on the fuel pump.
02-22-2011, 04:00 PM | #37 |
Austin LT
Drives: 1LT - Airaid,JBA Axleback,VMax PTB Join Date: Jun 2009
Quote from:
http://auto.howstuffworks.com/fuel-e...ummer-fuel.htm Twice every year in the United States, the fuel supply changes. It's known as the seasonal gasoline transition. This change is the biggest reason for the price hike in summer gasoline. Depending on the time of year, gas stations switch between providing summer-grade fuel and winter-grade fuel. The switch started in 1995 as part of the Reformulated Gasoline Program (RFG), which was established through the 1990 Clean Air Act Amendments. The Environmental Protection Agency (EPA) started the RFG program in order to reduce pollution and smog during the summer ozone season, which occurs from June 1 to Sept. 15 [Source: EPA]. |
02-22-2011, 05:08 PM | #38 |
Psssssssssshhhhhhhhhhhhh!
Drives: under contruction Join Date: Nov 2009
I know my shop siphoned gas out of another member's tank when they tuned it for a supercharger. He had gotten a bad tank of gas and they couldn't get the timing right. They siphoned the gas and then refilled it with 93.
I'm sure your shop can siphon out the gas. |
02-22-2011, 05:14 PM | #39 | |
Drives: 2011 Blue1SSRS 623RWHP, 02 vette Join Date: Aug 2010
as for all the bull about gas start anouther thread that i NOT this guys problem.as he added his problem his self. sorry man.
2002 Vette (stock)
Team LS-3 |
02-22-2011, 05:16 PM | #40 |
Drives: 2011 Black 2SS/RS LS3 M6 Join Date: Aug 2010
Thats why I don't use stabil. I mix half a tank of 110 Unleaded race gas with fresh gas and put it on the battery tender. I start it once a month and a little drive if its dry.
02-22-2011, 05:35 PM | #41 | |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Stabil isn't going to kill the power. Spark knock from old gas is the most likely culprit. I've run Stabil in toys with zero knock. Months later, tons of detonation on the same tank - due to the gas has lost octane over time. The Stabil kept it from gunking up, but old gas is old gas, not going to have the same octane as fresh stuff. |
02-22-2011, 07:01 PM | #42 |
Drives: victory red 2010 camaro 2ss/rs Join Date: Mar 2010
How would adding 1.5% mixture of anything result in a 8.5% drop in hp.
The fuel would be last place I would be looking at right now |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
where are the vacuum lines back by the gas tank?? anybody have a pic of them? | 6bloodychunks | 5th Gen Camaro SS LS LT General Discussions | 2 | 01-02-2011 04:33 PM |
Problem filling gas tank at pumps with new nozzle | joepitt | 5th Gen Camaro SS LS LT General Discussions | 24 | 12-11-2010 01:23 PM |
Gas tank thinks it is full...help | paphialex | 5th Gen Camaro SS LS LT General Discussions | 35 | 12-25-2009 08:37 AM |
L99 Gas Mileage Per Tank? | ICE 2010 | 5th Gen Camaro SS LS LT General Discussions | 10 | 08-26-2009 10:01 PM |
BREAKING: Chevrolet Volt = 230 MPG City | FenwickHockey65 | General Automotive + Other Cars Discussion | 65 | 08-17-2009 12:53 PM |
