02-12-2024, 04:43 PM | #29 | |
Drives: 2010 2LT/RS Join Date: Mar 2015
Dang! Seems as if anyone who leaves their AC knob a few clicks away from the cold setting... it is still bound to happen at one point or another...
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
02-12-2024, 05:46 PM | #30 |
Drives: 2013 zl1 vert Join Date: Dec 2018
I remember a forum member that was a service tech for chevy saying no matter where you leave the heat setting it still goes through the close cycle. i wonder what happened to that guy? he was a wealth of knowledge.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
02-12-2024, 05:57 PM | #31 | |
Drives: 2SS/RS Join Date: Sep 2008
02-12-2024, 06:01 PM | #32 |
Thing is, I'm willing to bet he doesn't actually have a bad blend door and instead his port leaked all the freon out which would make all the work for doing the bypass pointless since all he would have to do is replace the port and refill the freon.
02-12-2024, 06:06 PM | #33 | |
Yes I remember. What is the average cost these days to correct this and refill with freon? I know R12 is no longer in use and they now use the 134A.
2010 2LT/RS
02-12-2024, 06:09 PM | #34 | |
After you mentioned it, I'm starting to think the same with everything I have read so far on this issue.
2010 2LT/RS
02-12-2024, 06:21 PM | #35 | |
That is why every time I see a post about a possible blend door failure now, that is the first thing I tell them to check. The port going bad has been acknowledged by GM as an issue that requires yearly inspection and constant replacement and exhibits the exact same symptoms as the blend door. |
02-12-2024, 07:16 PM | #36 | |
This is good info and does not sound bad at all!
2010 2LT/RS
02-20-2024, 01:41 PM | #37 |
Update: Was off work the past three days and got a lot done with the Camaro. Was able to bring the car into a local shop today for AC service and they found that there was no freon and it was bone dry. They refilled it and it is running normal now with cold air coming through. However, they added a dye and if I run out again they will be able to see where the leak is coming in from. So for now all is good and there are no issues with the blend door at the moment
2010 2LT/RS
02-20-2024, 04:21 PM | #38 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
yea, but no heat Blend DOOR
Hot Wheels Emblems and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills, Hot Wheels door Sills.
02-20-2024, 06:25 PM | #39 |
What do you mean? My heat has been working fine all this time, it was my AC that quit blowing cold air. Both are functioning normal as of now.
2010 2LT/RS
02-21-2024, 12:30 AM | #40 |
You don't need to wait at all to find the leak (if it was empty to start with you have a leak). The dye that is used is fluorescent dye. If you have a black light, you can check right now and find the leak. The system is under constant pressure and will leak all the time, not just when in use.
02-21-2024, 06:59 AM | #41 |
mine broke to were i have AC but no heat
02-21-2024, 04:09 PM | #42 | |
I believe it finally happened... AC blend door??
I knew I still had a leak but was just a matter of time before it happened again. They hooked it up and let it run for 15 mins or so and so far couldn't detect a leak. They told me to come back if it happens again and they will fix it. And you weren't kidding... looks like all of my freon got dumped again and there is none left. Ha! Looks like a trip back to the shop. Btw i’ll pick up a black light from Harbor Freight on the way home from work and have a look see at where the leak is coming from. I won’t be able to take it back to the shop till next week Tuesday anyhow.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. Last edited by SummitWhite11; 02-21-2024 at 04:41 PM. |
