TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 08-24-2016, 04:58 PM   #29
Kenny Camaro
Drives: 2013 1LT RS Camaro
I hear ya....but not your exhaust.lol
Kenny Camaro is offline   Reply With Quote
Old 08-24-2016, 05:06 PM   #30
Kenny Camaro
That's true . And that's sounds goood.
Old 08-24-2016, 05:15 PM   #31
Shawno72
Shawno72's Avatar
Drives: 2015 Black 2LT RS M6
Should of gotten a composer to make that sweet exhaust note
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
Shawno72 is offline   Reply With Quote
Old 08-25-2016, 10:23 AM   #32
derek1387
Drives: 2015 1LS Red V6
Ugh.
Hoping it stops today so I can get some work done
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 08-25-2016, 01:06 PM   #33
derek1387
We are good! Storms are gone...for now. Ill be wrenching tonight!
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 08-25-2016, 03:41 PM   #34
Kenny Camaro
Yeah!!
Old 08-25-2016, 06:05 PM   #35
derek1387
Intro for the day
https://vimeo.com/180244216
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 08-25-2016, 08:42 PM   #36
derek1387
Super charger is installed. Power steering system finished!
Pictures in the morning of some do's and don'ts!!'
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 08-25-2016, 08:55 PM   #37
derek1387
Haha. No. Not yet.
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 08-26-2016, 05:29 AM   #38
derek1387
Alright! So, Day 2 is in the books
Power steering complete! Not 100% sure I like how the PS reservoir mounts up-may need to look at fabbing up a bracket to make it "square" and flow with the car a bit better.
The AN fitting connection is nice, because you can position the fitting however you may need it. Need to zip tie the return line down and out of the way as well.
PRO TIP!!! When you go to bolt the bracket up, make sure everything is loose on the bracket and tighten them up "together", as this is a precision machined bracket, with extremely tight tolerances .
Also, make sure you thread lock these two bolts with BLUE threadlock:
Next step once you have everything tightened up, is to loosely attach the belt. Main thing here is to have the belt around the AC and PS pump. Nothing else really matters at the moment.
Now we move on to mounting the pulley-there is a small rectangle key that fits in the shaft and pulley to hold it in one place. Notice the grooves in the pulley for additional grip!
And, this is the 3.8" Pulley. I will be testing a 3.48" as well
Then install the idler pulleys-new and improved with stronger, more robust bearings.
And now the fun part, especially if you are working by yourself! (NOT RECOMMENDED WHEN HANGING THE SUPERCHARGER)
Routing the belt! Over the bottom idler pulley, around the outside of the supercharger pulley, then under the top idler pulley!
8mm Hex/allen head to bolt the supercharger bracket to the inner bracket. The lower bolt is easy. The upper one...not so much. I had to improvise as I didnt have all of my tools with me.
Again, tighten them up incrementally. Not one fully tight, then the other. Tighten them together.
And there you have it
Mmmm.....
More to come!
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 08-26-2016, 01:49 PM   #39
derek1387
Going to do some touch up and clean up on the house routing today, then start mounting the intercooler and windshield washer assembly. Will be nice to have that again as I have been rocking without one since December.
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 08-26-2016, 02:53 PM   #40
JantzenOKC
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
Windshield washer fluid.... What's that?
3.6L Twin Turbo V6
Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension
10.75 @ 131mph
JantzenOKC is offline   Reply With Quote
Old 08-26-2016, 02:59 PM   #41
derek1387
I know right?
I never really used it much
Now that it's gone I miss it haha
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 08-26-2016, 03:02 PM   #42
Shawno72
Shawno72's Avatar
No need for blades either
