08-30-2020, 11:44 AM | #29 |
Drives: 2011 Camaro SS Join Date: Jul 2017
I dyno my L99 car for baseline. I was hoping it made the usual power these cars do and it did. However I wanted to see what I ended up at after my mods. My goal is to add 300 rwhp after I'm done. I'll be going to the same tuner and dyno so for me it's what I gained afterwards. My cam and turbo install is almost done. So I'll be dyno tuning it hopefully in September.
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
08-30-2020, 11:50 AM | #30 | |
Drives: 2013 Camaro 2SS/RS Join Date: Aug 2020
08-30-2020, 12:00 PM | #31 | |
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert Join Date: Sep 2019
I'm pretty much old school too in that respect though. If the car feels good to me, has the acceleration I like then I'm ok. My days of finding a stretch of lonely country road and doing 1/4 mile drags against my buddies are long gone. |
08-30-2020, 12:08 PM | #32 |
I agree with others that bolt ons won't do a whole lot. Time for a camshaft and some valve train upgrades. Go aggressive.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
08-30-2020, 05:35 PM | #33 |
My stock 2011 L99 with just a CAI, axle back, HFC's dyno'd 331 on a Mustang dyno. Then we installed the LT's, off road mids and re-tuned it and got 365rwhp and 357rwtq. So I would agree, you are where you need to be. Then we did the cam swap, LS3 conversion and a 3200 stall and an LOD X-1 intake and now we are at 485rwtq and 476rwhp on a dynojet.
08-30-2020, 05:43 PM | #34 | |
Drives: 2012 Camaro SS Join Date: Dec 2019
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
08-30-2020, 06:42 PM | #35 |
Thanks Big, yea I'm impressed with quick she is off the line, and how hard she pulls all the way out to 7200rpms shift point! I have a couple Camaro friends and 1 Challenger friend, and they all love to ride in my Camaro. One of those Camaro friends has a 2013 ZL1 with just a CAI on it so far and he says my Camaro pulls harder than his ZL1 !! And he says it even seems much quicker. That makes me feel pretty good for sure. Now I just need to get this 4000-4200 stall in there !! lol
08-30-2020, 09:05 PM | #36 |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
Don get me wrong I am in no way disappointed in the car!! It's definitely the fastest and most fun car I've ever owned. Just thought it would have dynoed a little higher. The converter is by far the best mod hands down.
GPI SS3 cam with top end goodies,Circle D 4c 3800 w/Derale trans cooler kit sold by GPI,3.90 yukon gears,Kooks long tube headers,Roto fab cold air intake, Corsa extreme 3" cat back, Dyno tuned by Andrews Auto Georgetown MI, Heritage Grille, T4 splitter with under tray, Anvil spoiler,MRR 228 reps with Nitto NT555G2 tires 315 rear 275 fronts,BMR poly bushings,HD Diff cover from RDP,Raytech install kit
08-30-2020, 09:15 PM | #37 | |
I remember when I first got my car and tried roll racing a Mustang (legally on a track of course!). It was a 2015 GT and it SPANKED me, like not remotely close. I don't even think I had a tune yet. What an eye opener. That was all I needed to motivate me though, and I ain't done yet! Now I have a cammed LS3 behind my 6L80 and it seems like everyone and their mother is boosted and pushing 600 rw+. There is always something you can do to make these cars more powerful as long as you have the coin. But once you get there you will discover there is ALWAYS someone faster than you, and it's time for Mo Powah! It is a never ending quest.
08-31-2020, 09:52 AM | #38 |
Oh, and I forgot to mention, that's with stock heads too. But with the BTR .660 springs, pushrods and bronze trunnion upgrade.
08-31-2020, 01:20 PM | #39 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Numbers look fine to me. The gears also throw off the dyno numbers compared to those running stock gears, it will read a little lower than what it actually is. Your mods are more for acceleration so you increased your 1/4 time over stock by quite a bit even though the HP TQ numbers aren't that much higher than stock. IT's just a tool. 1/4 mile times is where it really matters. Add a cam if you want to see a good HP TQ jump.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
08-31-2020, 02:59 PM | #40 | |
What does a higher stall converter feel like? They are doing mine when I do the can and heads and was just wondering what it feels like. But like states hp is just one thing. I’ve seen videos of 800hp dumped cars running 8’s
09-01-2020, 03:56 PM | #41 |
Yea the stall I have still in there is the 3200, the 4200 goes in later this week, I hope. But yea it is different than a stock one for sure. With the stock converter the trans is "tight" with the higher stall it is a bit looser, when you take your foot of the brake she just kinda pokes along and when you accelerate easily along you can feel the looseness of it, when you wrap on it the thing will flash up to around 3400, mine is a 3200 and it flashes up to there and locks and pulls like a train, and when you let off it will unlock and the car RPM will drop way down and coast, then you pick it back up and it will flash back up to the 3400 and lock and load !!. It is a really cool feeling. I have mine set to be locked in all of my "manual" mode gears so I can cruise along at whatever speed and cool the trans back down after some "spirited" driving. Hope you are installing a trans cooler too, you'll need it.
09-01-2020, 04:31 PM | #42 | |
