Old 01-15-2018, 01:00 PM   #29
l.o.d_yankee
l.o.d_yankee's Avatar
Drives: 2010/2SS/M6/440ci
We are shipping out the first batch right now as we speak
l.o.d_yankee is offline   Reply With Quote
Old 01-15-2018, 01:13 PM   #30
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
Where can you buy them?
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 01-15-2018, 02:15 PM   #31
rviper24
rviper24's Avatar
Drives: 2013 Camaro SS 6-Speed
Cant wait to see DYNO numbers!
2013 Camaro 1SS 6-Speed LS3
All stock.. For now...
rviper24 is offline   Reply With Quote
Old 01-15-2018, 02:49 PM   #32
xc_SS/RS
Drives: 2010 Camaro SS/RS
send me one and i'll find a dyno to test it! I'll compare it with a stock manifold, rod-mod manifold and i can include track times.
worth a shot lol
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 01-15-2018, 03:04 PM   #33
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Those short runner manifolds don't work good on a LS3, they loose torque like crazy if you are running NA. It will make power way up at 6-7 thousand rpm. It does look nice and would be nice for forced induction.
This video has short runner manifolds the last two runs, they suck.
zz430camaro is offline   Reply With Quote
Old 01-15-2018, 03:32 PM   #34
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I would think a high revving LLSR build would be a good place to install one. But on a bolt on car or small cam/bolt on? Too much loss on the bottom end for me.
But if I remember correctly, they claimed gains throughout the power band, which I just don't see possible with those runners. It just looks too close to those sheet metal intakes in design for me to see it being viable. But I am very far from anything resembling an expert, so WTF do I know?
InFiD3ViL is online now   Reply With Quote
Old 01-15-2018, 03:52 PM   #35
xc_SS/RS
i think it has longer runners to make it more of a mid-length runner manifold so the losses shouldn't be too bad in the lower RPM's
2010 2SS/RS
Old 01-15-2018, 04:24 PM   #36
l.o.d_yankee
Its on the fb page/website
Old 01-15-2018, 04:28 PM   #37
l.o.d_yankee
We already have some but we also understand people would like to see third party testing. It has been tested at peitz performance tunes in houston as well as the school of Automotive tuning in houston.
Old 01-15-2018, 04:41 PM   #38
l.o.d_yankee
Correct, the runners are longer than a typical "short runner" intake so one might call it a mid- length. it does has an appropriate taper in the runner to keep mid range velocity up.
Old 01-15-2018, 05:09 PM   #39
Punisher_ATX
Drives: 2010 SS
Send one to us and well test it on an engine dyno compared to any intake of your choice. and any cam of your choice.
Punisher_ATX is offline   Reply With Quote
Old 01-15-2018, 05:32 PM   #40
Buschman
Buschman's Avatar
Just went through your facebook page, the only 2 dyno sheets on there show from 5k rpm and up. Would you post a full sheet, with afr numbers?
2018 ZL1
2015 1SS 1LE
Stock...ish
Old 01-15-2018, 06:08 PM   #41
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Nice
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 01-15-2018, 06:19 PM   #42
l.o.d_yankee
We have already tested it on an engine dyno at s.a.m tech. We certainly appreciate the offer. Our shop 5th gen' s engine (440,12:1 Compression on dart pro1 heads) will be on the engine dyno soon. Where we'll be conducting a small intake "shootout"
