Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 11-20-2015, 10:13 PM   #29
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Originally Posted by Vicster View Post
This thread got a little off subject, no one else has any ideas or thoughts on fixing my tune?
Email your tune to me and I'll look at it.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 11-21-2015, 09:54 PM   #30
Vicster
Vicster's Avatar
Drives: 13' ZL1
Cool Thank You
PM sent
Vicster is offline   Reply With Quote
Old 11-21-2015, 09:55 PM   #31
Vicster
Vicster's Avatar
Drives: 13' ZL1
Cool Thank You
Originally Posted by owhite3003 View Post
Give Jordan at JDP Motorsports a call or Joshua Starkweather a call. Both are great at what they do and are very helpful. Nice guys!!
Thank You!
Old 11-25-2015, 12:16 AM   #32
Infurno
Drives: 2013 ZL1 IOM
Awesome job!
Infurno is offline   Reply With Quote
Old 11-30-2015, 01:35 PM   #33
Vicster
Vicster's Avatar
Drives: 13' ZL1
Back on the dyno
So Tommy has the car back on the Dyno, he has never seen a car do this before. With tires rolling and the clutch pushed in idle is fine, release the clutch while in neutral and it bounces between 300 - 1500 rpm but, only when the tires are rolling. Performed learning for throttle and clutch, helped but, still has a slight bump in revs when clutch is released.
Old 11-30-2015, 06:29 PM   #34
owhite3003
Z-BEAST
owhite3003's Avatar
Drives: 2013 JDP ZL-850 Track Spec ZL1,
So Tommy has the car back on the Dyno, has never seen a car do this before. With the clutch pushed in idle is fine, release the clutch and it bounces between 300 - 2000 rpm. Performed learning for throttle and clutch, helped but, still has a slight bump in revs when clutch is released.
Be careful, may have freezing rain later tonight. Glad to hear that he is working on getting you dialed.
owhite3003 is offline   Reply With Quote
Old 12-01-2015, 07:13 PM   #35
Vicster
Vicster's Avatar
Drives: 13' ZL1
Cool missed the ice
Thanks for the concern, it was 20 to 24 degrees driving from Seattle to Vancouver. There was ice on the front of the car when we arrived. The trip home was allot wetter but no ice thank God! But the Michelin tires are allot better than the stock Good Years!!! They should have used them at the ring!!
Tommy did his best to retune the car, but it still has a bit of throttle rev up when the clutch is released. But, he was able to increase the HP 20 to 25 from 1500 to 6400 rpm. The total on the mustang dyno was approx. 660 hp, engine rev limiter was raised to 6600. But the dyno sheet only goes up to 6400 rpm. From what I have been able to figure out that is approx. 760 rwhp on a dyno jet dyno.
The car just never stops pulling, man I love this car!!!
Old 12-01-2015, 07:51 PM   #36
Vicster
Vicster's Avatar
Drives: 13' ZL1
Red face Thank YOU
E-mail sent.
Old 12-01-2015, 09:25 PM   #37
ZO6 Bryan
ZO6 Bryan's Avatar
E-mail sent.
I've been looking at it and right off the bat I see he didn't use the data from Injector Dynamics for the ID850's. Those are the injectors you have right? The offsets and min pulse width and other things haven't even been touched. That's the reason the ID850's cost what they do. Because they've done all the R and D to get the proper data and then they provide to you to use in the tune.
Bryan 2018 ZL1 M6
Old 12-02-2015, 05:38 PM   #38
Vicster
Vicster's Avatar
Drives: 13' ZL1
Unhappy What.....
I asked him, he said that he had updated it with the 850ID settings. So now what do I do? Does it have to be updated and dyno'd again? At this point I would rather fix it all myself, it may take some time to buy the HP Tuners VCM Suite $500 is out of reach right now, my daughters wedding is coming up....
Thanks for your help!!
Old 12-02-2015, 08:53 PM   #39
ZO6 Bryan
ZO6 Bryan's Avatar
He didn't.
Injector flow rate is wrong.
Short pulse adder table untouched
Short pulse limit untouched
Offset table untouched
Makeup pulse minimum untouched
Min pulse width untouched (this in particular would make it very hard for the PCM to control fuel at idle and low load conditions)
Not to mention that he has set a commanded AFR of 10.8 at WOT to make up for how far off the MAF table and injector data has been set. Actually it is set to bounce back and forth from 10.8 to 11.3 over the RPM range.
I would start all over.
Bryan 2018 ZL1 M6
Old 12-02-2015, 08:55 PM   #40
ZO6 Bryan
ZO6 Bryan's Avatar
Here the proper data that should have been used.
http://injectordynamics.com/wp-conte...-3-23-2011.xls
Bryan 2018 ZL1 M6
Old 12-02-2015, 10:34 PM   #41
Vicster
Vicster's Avatar
Drives: 13' ZL1
Unhappy Thank You
I have contacted him, but not heard back from him.... That is the same file I sent him when he first flashed my ECM. If he is not doing it right I do not want to take it back to him.... Anyone one in WA or nearby states that you would trust?
It is hard trusting my car to anyone, Tommy was so highly rated even here on the forum. I do all my own work, even designing my cam, that took me 2 years of learning and research. I guess I need to do this myself to.... THIS IS SO FRUSTRAITING!!!
Thank You!!
Old 12-03-2015, 04:08 PM   #42
Chrispy
11.91 ET Bone stock
Drives: 2015 Camaro ZL1
I wouldn't drive it till you get a base tune in the car with the injectors scaled. You could wash the Rings if it is pig rich.
Chrispy is offline   Reply With Quote
