View Poll Results: Are you interested in 1LE replicas? | |||
Don't like these rims | 22 | 13.50% | |
Interested, but I want the real deal (don't want) | 25 | 15.34% | |
I want replicas, stock size | 49 | 30.06% | |
I want replicas, size that fits my stock tires | 32 | 19.63% | |
I want replicas, 19 inch diameter | 15 | 9.20% | |
I want replicas, other reason | 20 | 12.27% | |
Voters: 163. You may not vote on this poll |
Thread Tools |
02-14-2016, 06:14 PM | #29 |
Drives: Camaro Join Date: Jan 2016
Just to clear things up that may change voters opinions, yes we can make these wheels to accept your current OE tires but that means that the wheel will have to be no wider then a 20x9 which will eliminate the concavity of the wheel, for us to get maximum concave to look like the OE 1LE wheel it will require a 20x10 front and 20x11 rears. Or if concavity is not a concern 20x9 maybe a 20x9.5
02-14-2016, 08:45 PM | #30 | |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
As someone interested in that option, I realize the 9" won't have the concavity of the wider rims, but I don't think it means that it will "eliminate" the concavity of the wheel. At least I don't see why it would...they should still be far from "flat". If you were to go with a rim that has a more aggressive offset than the stock wheel...in this case it should at least be more a little more concave than the stock wheel, but less so than the 10" and 11" wide versions. Example: I had the Style 41 ZL1 replicas on my last car. They were all 9" wide, and had a +27mm offset that poked them out further than stock. Now, they also didn't have the same concavity as the 10 and 11" rims, but again, with that offset they were much more aggressive looking than stock and had more concavity. I loved it...had all the look, and they were also the lightest option. I shaved weight over my stock rims. So would something like that be possible for these rims? I will say that it will be disappointing if the 9" wide wheels have the same offset as stock. Personally, I would go with a 9" in the front (0.5" gain over stock) and a 10" in the rear if your 10" wheel also fit well in the rear and put my stock tires on....otherwise I'd go with 9" all around, and happily give up the 0.5 width in the rear and still mount my stock tires. Appreciate your time on this, and love that you are already getting a start.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
02-14-2016, 09:03 PM | #31 | |
Drives: 2016 Black 1SS Camaro Join Date: Jul 2012
2016 Camaro 1SS M6 with MRC and NPP.
“Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.” Albert Einstein |
02-14-2016, 09:21 PM | #32 |
02-14-2016, 09:24 PM | #33 |
Drives: Wife's 14' IS 250 Join Date: Mar 2014
I want the 10" front 11" rears, but I want the Z28 style rims, these new 1LE rims aren't as nice as 5th gen.
-11% tint all around Ordered • 2/06/16 Built on • 3/22/16 Adopted • 4/07/16 Sold on 2/05/16: 2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior: -Borla ATAK catback -Range AFM delete -15% tint all around -Red LED interior bulbs -55k white Cree LED fogs -License plate LED bulb swap -12" Sub Kit, BA amp swap -Oracle ghosted LED sidemarkers |
02-15-2016, 12:19 PM | #34 | |
i would recommend contacting Element wheels as they are a current sponsoring vendor and definitely have the wheels in the proper 2016 fitment in stock. lets get you on a set and get some pics |
02-15-2016, 12:32 PM | #35 | |
davet
Drives: 2016 2SS Mosaic Black Join Date: Apr 2010
Replacement car ordered 2/02/2016
2/03/16 2500 2/04/16 3000 no TPW 2/8/16 3000 TPW 2/29 2/18/16 3400 3/3/16 3800 3/4/16 4B00 3/5/16 4300 3/7/16 4200!!! |
02-15-2016, 12:33 PM | #36 | |
Ok for sure.. Just ordered my Camaro, will be at least 3 months before she arrives. I'll check out element in meantime. Thx Sent from my iPhone using Tapatalk
02-15-2016, 12:41 PM | #37 |
Just wanted to clear up a few thing's on the replica subject. especially for the track course guys and only to reasure that you will receive a high quality wheel.
A wheel can only be considered a replica do to its design and some replicas have received a bad reputation but is not the replica is the manufacture behind it and what they decided to do with it. simple example: some manufactures will replicate a wheel and will offer a general size and width and there job is to sell numbers to the masses at a cheap price, 20" for 1000 at the most this is more likely a standard cast wheel in which the manufacture only cared for the design aspect. now what if a manufacture took that same design but used a better construction?? maybe full blown Forged, maybe Flow Forged or maybe low pressure casting, all these are 3 better options then standard cast and make for a better stronger wheel. Thats our goal: make a better, lighter constructed wheel for the community back by a reliable source. trust us someone in this industry will make this 1LE Rep and are probably already planing out the whole thing and will be priced in the 1,000.00 set mark, this is great for those who want the look and visual aspect, I want to give you guys the visual aspect and a strong light weight Rotatory Forged wheel. |
02-15-2016, 01:37 PM | #38 | |
Basically, the real question is, do you think you could make a 9" wheel with a more aggressive offset than the stock wheels (in my case, the standard 5 spoke) and more concavity? If you can't answer that question now I understand, but I will say again that I'd assume they would have a more aggressive offset. If not, that will diminish a lot of interest in something that would fit stock tires. My opinion anyways. Thanks.
02-15-2016, 01:45 PM | #39 | |
Not saying this is the route you should go. I still very much appreciate what you are doing, and I am definitely a potential buyer! Many buyers want a forged wheel. Many (including myself) don't want or need a forged wheel. As long as the wheel is safe and abides by standards, then I see no reason not to purchase it if it checks all the boxes. All I'm saying is, $1,100 set of wheels that does all I need versus 1,600 set that is forged...I'm going for the cheaper set lol. Call me cheap if you want.
02-15-2016, 02:16 PM | #40 | |
02-15-2016, 02:31 PM | #41 |
Drives: Blk/Blk 2018 Sierra SLT Join Date: Dec 2006
So is this a go? Im about to order up my Camaro today or tomorrow
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6 |
02-15-2016, 02:52 PM | #42 | |
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
