03-19-2017, 06:46 PM | #29 |
Can you pull (read) the current tune from the car?
03-19-2017, 08:52 PM | #30 |
Drives: 16SS-A8-Magnuson-SW-Gforce Join Date: Nov 2016
I think the car is pulling power. Either because of knock or something in the torque table. You need a tuner that is good with the lt1
03-20-2017, 09:03 AM | #31 |
Drives: 2018 ZL1 Join Date: Sep 2016
Ok guys little update. Talked to the tuner and he admitted he forgot to change the cam timing, so I'm going back to him because he wants to make things right.
03-20-2017, 09:44 AM | #32 |
Drives: 2017 Nightfall Grey Auto 2SS Join Date: Mar 2012
03-20-2017, 09:45 AM | #33 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
03-20-2017, 09:54 AM | #34 |
Drives: 2016 2ss Join Date: Aug 2016
cam timing.. Im by no means a professional tuner but i have a decent understanding of an engine. I wouldn't expect he could do much with cam timing except adjusting when the variable valve timing kicks in any other cam timing is done by mechanical means. Maybe he meant ignition timing but that would be a pretty big deal to forget to touch that.
03-20-2017, 11:32 AM | #35 | |
Drives: Many C7's Join Date: Apr 2014
P1SC 3.90" pulley Snow Meth kit Car runs 10.60's @ 133 Here is an image, to show you where your issue starts. Figure out what she's upset about right here, and you will find your power. The curve should be nice and SMOOTH all the way up, even on a Mustang Dyno. (thats what we use here, and its calibrated allll the time) |
03-20-2017, 12:32 PM | #36 |
Drives: 2016 1SS, 2017 JKU Wrangler Join Date: Mar 2016
yeah what he said ^^
That thing should be blasting you in the back of the seat by that point.
SLO 1SS - sold
1SS MRC NPP 6MT 2018 Ram Rebel 4x4 5.7 |
03-28-2017, 09:16 AM | #37 |
Ok so shitty update.
Found out that cylinder 6 7 and 8 are misfiring at that 4800 rpm mark. Ruled out plugs, wires, coils, and injectors so they are thinking valve train. So idk what I'm going to do, break into the motor and get it fixed for $2k or strip the car and selling everything. |
03-28-2017, 09:22 AM | #38 | |
Drives: 2018 ZL1 Join Date: Oct 2011
2018 ZL1…Many mods to come
03-28-2017, 10:10 AM | #39 |
Thinking it might have been failing slightly, and then the blower hurt it more. As of now it's only at a higher rpm under load.
03-28-2017, 10:34 AM | #40 |
Drives: 2016 1SS D1SC Methfed Lowered Wrapd Join Date: Apr 2016
I'd get a second opinion from someone else just in case... Hopefully they didn't shit the bed playing around with the tune and ended up putting you in deeper water, and are now trying to squeeze you for cash.
03-29-2017, 08:07 AM | #41 |
[QUOTE=ProCharger;9624353]If not more... I made 644 rwhp on the last one.
P1SC 3.90" pulley Snow Meth kit Car runs 10.60's @ 133 That's very impressive to say!!! Are those the only mods done to this car? |
03-29-2017, 08:18 AM | #42 | |
Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
