Old 03-08-2017, 03:46 AM   #29
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
Originally Posted by MR 45TH View Post
How much heat did you have to use?
About 20-30 sec with my MAP gas torch.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 03-09-2017, 09:51 AM   #30
ProCharger
Drives: Many C7's
Originally Posted by xX-MIKE-Xx View Post
Everything they do is fast!
My kit went to Phastek, repackaged into smaller boxes so it could be sent through APO, and still seems like it arrived over here in just a few weeks. But they are also quick to help with adjusting the tune. Great guys to work with. Highly recommend!
ProCharger is offline   Reply With Quote
Old 03-15-2017, 06:56 PM   #31
Chief8404
HMC(ret)
Chief8404's Avatar
Drives: 2017 1LE(Traded In for a truck)
Originally Posted by ProCharger View Post
"Figure OUT" isn't really the correct term.
We have a file, just as we do for the vettes, trucks, etc.
However, GM has put in a locking method into the ECU.
This method is specific to each VIN #, not just model year.
(Ford will be swapping to this as well soon)
So right now we are working with two companies, to try and make this unlocking process something that can be done for average customers.
Right now, if a customer works with a shop, and HPTuners.
They can tune the cars like normal with a custom tune via HPtuners.
I will update the board when the day comes for a handheld option.
I assure you many are working on it. Since this doesn't just effect us, but ANYONE that want's to do any sort of calibration change on these cars.
Thanks for the question!
Erik
So not available for the 2017?
Chief8404 is offline   Reply With Quote
Old 03-15-2017, 08:29 PM   #32
Cdflyer
Cdflyer's Avatar
They just don't have the ability to send you their tune the way they can with the '16. So it really depends on what kit you want. If you want a D1, they don't have the tune for it, so you end up needing to have a custom tune anyway.
FWIW, I only went with their tune since I plan on going on Power Tour, and I don't know what fuel will be available. ProCharger's tune is good with 91 but I have 93 where I live. I'd hate to tune for 93 and then run into detonation if there's only 91 available on the tour.
Old 03-16-2017, 02:30 AM   #33
Chief8404
HMC(ret)
Chief8404's Avatar
Oh so I can get the P1 stock 7 psi boost kit with the canned tune? If a more aggressive tune is needed I'd just take it to a dyno tune anyway.
Old 03-16-2017, 04:15 AM   #34
Cdflyer
Cdflyer's Avatar
They don't have the canned tune for the '17. Each pcm has its own specific encryption from what it sounds like. So you'd just have to buy the Tuner kit, and then have it tuned by a local shop. I have a '16, and apparently this new style encryption has started with the '17's.
Old 03-16-2017, 04:34 AM   #35
Chief8404
HMC(ret)
Chief8404's Avatar
Thanks for the heads up!
Old 03-16-2017, 08:56 AM   #36
ProCharger
Drives: Many C7's
We are good to go on 2017's
Old 03-16-2017, 09:04 AM   #37
1le32907
Drives: Summit white 1le ss
If I place order tomorrow how fast can we get it out?
1le32907 is offline   Reply With Quote
Old 03-16-2017, 09:05 AM   #38
ProCharger
Drives: Many C7's
We are still our normal 5-10 business days from the time the dealer places order with us. ..... just like the others have talked about in this thread.
(Some have got them as fast as 4-5, even including shipping)
