Old 01-07-2017, 06:26 PM   #29
aa406079
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6
Originally Posted by Hypertrophy View Post
Gotta see it on the car...
If the car was flat black ...louvres and the side grills above would complete the mad max look...
and guess what... 2017 is the Ronald Reagan 80's all over again...
aa406079 is offline   Reply With Quote
Old 01-07-2017, 10:05 PM   #30
jrs580
jrs580's Avatar
Drives: 2016 2ss
Originally Posted by Steel_Rain View Post
Dang! OP asked for help and most of the comments are degrading toward him and why his idea sucks. What is up with that?
Thanks MovieGuy for pointing him in the right direction. I wish more wanted to help instead of vomiting their preferences.
+2
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in.
jrs580 is offline   Reply With Quote
Old 01-08-2017, 12:26 PM   #31
RenegadeXR
RenegadeXR's Avatar
Drives: 2011 Camaro SS
As others have said, wait for MRT to come out with them. It's almost guaranteed. Should look nearly identical to the 5th gen's, which I have.
They are powder coated aluminum, held down by two latches at the bottom that in turn securely grab two "nubs" that are attach to a pair of small adhesive pads that you can remove from your window later on if desired. Top is secured by adhesive "hinge" pads which lets you lift the louver upward to clean your glass. Finally, it comes with a couple "prop rods" hidden in the bottom-most louver which you can swivel down to help keep the assembly propped up when you're cleaning the rear window.
No other product offers this setup or anything near this level of quality, AFAIK. All other products are cheap ABS plastic that will fade in no time and look like garbage. No rattling at all -- I actually tried to listen carefully for noise after installing these and wound up instead noticing a lot of noise that my *sunroof* makes, which I now can't "unhear." :P When I bring my car in for service, sometimes people ask what the GM part code was for these... I guess that's a way of saying they look like they could be stock. They do sort of match the body lines of the car well and look like they match the shark fin antenna to some extent even.
Finally, as for visibility, it's kind of like blinds on a window. If they are angled the right way, you can see out but still have privacy. These are angled such that to the driver, each louver looks like a maybe 1/4 inch thick metal metal slit traveling across the window. It doesn't impede visibility at all and actually *helps* at dawn or dusk if the sun is behind you.
RenegadeXR is offline   Reply With Quote
Old 03-28-2017, 05:34 PM   #32
Pindecko
Pindecko's Avatar
Drives: Summit white 2SS
Originally Posted by Fergy View Post
Hi everybody, new guy here!
I was just wondering if anyone knew of a company making louvers for the rear window on the 6 gens yet?
searched the web but didn't find anything...
Thanks for any info
I just found this: https://www.carid.com/willpak/rear-w...3&url=86272776
2016 summit white SS with 2300 Maggie Heartbeat, Rotofab CAI, kooks headers. Michelin PS4S tires.
Pindecko is offline   Reply With Quote
Old 05-02-2017, 01:33 PM   #33
PhantomV8
PhantomV8's Avatar
PhantomV8 is offline   Reply With Quote
Old 05-02-2017, 02:01 PM   #34
Fergy
Fergy's Avatar
Drives: 17 Camaro SS2, 93 C1500 Silverado
Originally Posted by Pindecko View Post
I just looked at the willpak's site and their PDF doesn't list 6gen only 10-13 models
17 SS2, Nightfall/Kalahari, M6, muffler delete, skip shift delete, wideband O2, Flex fuel sensor
Fergy is offline   Reply With Quote
Old 06-09-2017, 02:26 PM   #35
ian351c
Drives: 2017 Camaros 2SS
I saw one of these on the road a few days ago. It looked pretty good, though it was a car that someone spent quite a bit of money on going for a certain look (black paint, everything blacked out). http://www.americanmuscle.com/mmd-re...uver-1516.html
I like the look, but of course ABS plastic is not a long term solution. Then there's how would these look on a Camaro instead of a Mustang.
ian351c is offline   Reply With Quote
Old 06-11-2017, 10:03 PM   #36
fastball
Drives: 2017 Camaro 2SS 6MT
Uh, no. There's only one car louvers look right on and that's a 1970 Boss 302.
fastball is offline   Reply With Quote
Old 06-11-2017, 10:08 PM   #37
Dethsupp0rt
Drives: None
Dethsupp0rt is offline   Reply With Quote
Old 06-12-2017, 11:30 AM   #38
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
put whatever you want on your car. You make the payments. F everyone else
SSTony is offline   Reply With Quote
Old 06-12-2017, 11:31 AM   #39
SSTony
SSTony's Avatar
Drives: SS Camaro
i think the Side Window Louvers painted the color of the car looks sharp.
Old 06-12-2017, 11:47 AM   #40
fastball
And that's perfectly fine, just be willing to accept the comments when you post on a forum and say "what do you think about ______ on my car?".
I see louvers on the back window of any car first thing that comes to mind is butterfly collars and Saturday Night Fever.
Old 06-12-2017, 12:30 PM   #41
DarkFangz1100
Drives: 2016 Camaro SS
Originally Posted by CreativeDawn View Post
What do you think of these? The "Camaro" lettering is literally an actual Emblem inside the louver.
Pics on a car and you may have a sale....
DarkFangz1100 is offline   Reply With Quote
