02-12-2018, 08:40 PM | #29 | |
Drives: 2017 1SS camaro ,2SS a 68 + 08 C6 Join Date: Dec 2017
Then check , check and check again !!! Oh AND WHATEVER YOU DO. DONT TINT THE INDOWS TOO DARK , MAKES IT WAY WAY WORSE ESPECIALLY AT NIGHT !!! |
02-12-2018, 09:27 PM | #30 | |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
In my opinion, this blind spot criticism of our Camaros is legitimate (Mustangs have better vis), but very much overblown (Challenger rear-quarter vis is dramatically worse than the Camaro). Tried 'em both...do the same and see for yourself!!
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
02-12-2018, 11:05 PM | #31 |
Drives: 2SS 1LE Join Date: Oct 2011
The lack of visibility is real and it's an issue to overcome. The less you see outside, the less situational awareness you have, as in, there's a panel truck over there, a semi a few cars back in that lane, a ford moving 20mph faster than all the other traffic two lanes over. This builds a mental "picture" of what is going on around you, so if a rock came loose off a hillside or a dog ran out into traffic, you would know what direction you can move the car instantly without having to first check your mirrors to see if you can move in that direction, then react (which may be too late). 99.9% of the time, this doesn't matter, but in a critical situation where you are faced with the unexpected (like the Spanish Inquisition), this knowledge and information could be critical. If you adjust the mirrors properly, you can see the "blind spots"...But, you are still looking in a "tunnel" effectively, the rear view mirror limits your visibility, the side mirrors cut out a lot, the high sills limit your visibility, etc. Moving over more than one lane at a time can be risky for this reason.
I for one feel the trade-offs are worth it. This is why the car looks the way it does, and I think it looks fantastic. You can adapt, but humans are not perfect machines, they are incapable of doing a task perfectly each time. Fate is the hunter that is waiting for you to slip up just a little bit, and everyone does at some point. For every person that complains about visibility, there's a nice econo-box car waiting for you at your flavor of dealership that doesn't have this issue. I like the exotic looks of our cars.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
02-12-2018, 11:37 PM | #32 |
Drives: 2017 1LT RS M6 Join Date: Jun 2017
I found this video on you tube and I bought these for about $8.00 stuck them on I had to look twice at each mirror, but I have no blind spot.
https://youtu.be/sGk_7V8lJUg |
02-13-2018, 04:37 AM | #33 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
Blind Spots I have no blind spots.
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
02-13-2018, 04:43 AM | #34 |
#TeamBeckyD
Honestly I have been driving Camaros and Firebirds since 1992 ( 9 cars in all ) I guess I am used to the so called blind spots I have zero issues with driving these cars day or night.
#TeamBeckyD
02-13-2018, 05:25 AM | #35 |
Thank you Al Oppenheiser!
02-13-2018, 06:33 AM | #36 | |
Drives: Hyper Blue Metallic 2016 2SS M6 Join Date: Nov 2013
02-13-2018, 06:46 AM | #37 |
Drives: 2014 Cyclone mustang Join Date: Feb 2016
Mirror adjustment and "Defensive driving" , my Mom taught me, yup. We own sportscars & must take the responsible approach, not to do so is irresponsible.
2014 Cyclone/Select Shift/"/Sold
2016 ruby red GT w/3.55:1/resonator delete X- pipe/UPR catch can/Airaid "tube"W/AEM/J&M/BigWorm/BMR /SVE /ZL1addons/Redline/Steeda/BG fluids/ |
02-13-2018, 08:42 AM | #38 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
As everyone else has said...adjust your mirrors.
If you can see the side of the car, you are doing it wrong. With mirror set correctly, you should be able to see a car that is on the immediate lane on either side of you come out of view of your rear view mirror and at the same time, coming into view on your side mirror as they pass you. Fixed.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
02-13-2018, 10:00 AM | #39 |
Drives: 50th SS Convertible Join Date: Jul 2017
I put the top down
02-13-2018, 10:38 AM | #40 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Another important tip when changing lanes is to use your turn signal to notify drivers behind you, and hopefully beside you that you're changing lanes. This gives the other driver(s) time to anticipate your move. It's just added insurance. Plus, you'd be the only driver on the road using them.
02-13-2018, 10:42 AM | #41 |
Drives: 2016 SS Convertible Join Date: Sep 2016
02-13-2018, 10:58 AM | #42 | |
Drives: 2017 Camaro 2SS Join Date: Jul 2007
San Diego, CA - 2017 2SS (A8) Arctic Blue Metallic
