dave@hennessey
Old 04-18-2012, 08:29 PM   #29
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
Originally Posted by kevin1106 View Post
Not sure of the best bang for the buck. But def the best. Pedders supercar coil overs. This is my 3rd suspension. Wish I would have went this route first. Would have saved lots of $$$
I believe BC Racing makes Pedders coilovers.
I have BC coilovers and LOVE them. Best mod I've done both aesthetically and functionally.
Sent from my Galaxy Nexus using Tapatalk 2
YouTube
Old 04-18-2012, 09:36 PM   #30
Whiteside Customs
Drives: 2011 1lt/rs, 2010 2ss/rs, 2004 GTO
I have never had a customer disappointed with BC Racing Coilovers. Most people buy into hype. Those that don't get an AMAZING product at an AMAZING price!
Whiteside Customs is offline   Reply With Quote
Old 04-18-2012, 10:03 PM   #31
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Nino, glad you decided to give them a try. You will love this setup. To bad you are not closer so Mike could do the install.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 04-18-2012, 10:27 PM   #32
MiSS1LE
MiSS1LE's Avatar
Drives: 2014 1LE & 2014 C7
I had my BC BR racing coilovers installed ,April 6th by Mike at
Whiteside Customs .
I couldn't be happier the stance and the ride are awesome I can really feel the difference in the cornering as well much better now.
I also had the complete ,Whiteline Bushings & Whiteline rear sway with the Whiteline rear end links installed ....
Thanks Mike ,
MiSS1LE is offline   Reply With Quote
Old 04-19-2012, 10:09 AM   #33
Whiteside Customs
Whiteside Customs .
Thanks Mike ,
You guys are making me blush!
Old 04-21-2012, 09:57 PM   #34
Montducati
Montducati's Avatar
Drives: 45th Edition SS, Ducati Diavel, 996
What's the average shop time/charge to install coil-overs?
2012 45th Edition SS LS3 Hurst equipped
Bowtie!! What Bowtie??
Montducati is offline   Reply With Quote
Old 04-23-2012, 08:53 AM   #35
Rallyman6
Member
Rallyman6's Avatar
Drives: '10 2SS/RS IOM, Wht Stripes, Roof
For the $ = BC's are A+
Originally Posted by Nessal View Post
IMO, if you're looking to just lower your ride then get the BC coilovers. My car is a DD and I would never even use the higher end coilovers to 20% of their potential so I saw so sense in getting them. My goal was to get a lower and stiffer ride and the BC fits the bill. Find out what your goals are and then go from there.
2SS/RS IOM, Wht Stripes, 6MT, IO Interior, Roof, Eibach Sways, BC Coilovers, BMR Swing arms,Barton Short Shift, BBK LT's, GMPP exhaust, Hi-Flow Cats, MAST Stage 2 Cam, CAI = 470RWHP
Rallyman6 is offline   Reply With Quote
Old 04-23-2012, 10:06 AM   #36
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
It really depends on what your goals for the coilovers are. If you're just looking to get the car setup at the exact stance you're looking for, figure about 4 hours for installation and to setup your ride heights, then another hour to align after the ride height has been set.
If you're looking to really get the most out of your performance coilover package add in another 1-2 hours for a proper corner balance after the alignment has been performed. Corner balancing is the process of adjusting the ride heights of the coilovers to ensure cross weights between the Left Front and Right Rear, and Right Front and Left Rear are as even as possible... this will ensure the best cornering performance with coilovers.
PfadtRacing is offline   Reply With Quote
Old 04-23-2012, 12:46 PM   #37
Whiteside Customs
Old 04-23-2012, 12:49 PM   #38
ModBargains.com
ModBargains.com's Avatar
Drives: Widebody 2013 Mustang GT
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
Originally Posted by BAWLZ SS View Post
Well guys i wanna get coilovers mainly cuz i want to lower my car and run 20X10's up front. I love the stance of a lowered car but i do track the car about 4 times a year. (either auto cross or drag) just want it to handle better when cornering hard. (even better than now) so with that said what do u guys recommend???
If you want have a real performing set of coilovers, I'd look at the KW Clubsports which are high and low speed compression adjustable as well as rebound, and ride height adjustable. A set of those are the top dog in terms of affordable suspension units that will be below your competitive Ohlins and Moton kits.
ModBargains.com is offline   Reply With Quote
Old 04-23-2012, 01:37 PM   #39
PfadtRacing
Let me clarify something real fast, after rereading our post above I want to be pretty clear about the order of operations when installing coilovers.
Be sure to get your car corner balanced BEFORE you have the car aligned. During the process of corner balancing they will be tweaking your ride heights, which will slightly change your alignment. Be sure that the car gets corner balanced BEFORE alignment, because the car will need to be aligned any time a ride height change is made.
Old 04-23-2012, 02:19 PM   #40
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
So corner balancing is sort of like raising or lowering the car to shift weight around which changes the balance? So I would guess that having it properly corner-balanced could mean the car might not sit the same height across the fronts or the rears depending on how the weight distribution was to start with?
bannonm is offline   Reply With Quote
Old 04-23-2012, 02:23 PM   #41
ModBargains.com
To add something about the KW Clubsports, I also added in this article I found, by KW in regards to their clubsports... Got some fun photos in there as well:
KW Suspensions has increased its coilover lineup for the 2009 Chevy Camaro. The new KW Clubsport coilover kit now offers serious weekend track enthusiasts a daily driven and track capable coilover suspension.
http://blog.kw-suspension.com/archives/2796
Old 04-23-2012, 02:56 PM   #42
PfadtRacing
Exactly. If you measure the car from ground to top of fender after a corner balance you may find that the car might not sit exactly level left to right. During the corner balance the shop will either have you sit in the front seat, or ballast the front seat to your approximate weight, along with the approximate fuel load you plan to run most of the time. Once the weights have been set they roll the car onto scales and then make small changes to the ride height of the car until the Corner weights (LF+RR and RF+LR) are the same. The overall weight distribution of the car will determine exactly how much difference there is in ride height between left and right sides. Usually the difference is so small that it's not really noticible, but the scales will tell the whole story.
The corner balancing procedure isn't going to be necessary for everyone, but for those folks building cars that will see track time it's a really great idea.
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
Remote Reservoir Seperate Bound and Rebound Adjustable 5th Gen Coilovers JusticePete Suspension / Brakes / Chassis 144 12-07-2011 03:50 PM
pfadt and pedders coilovers bmbbl be Suspension / Brakes / Chassis 47 02-14-2011 04:50 PM
Pfadt Coilovers, special CAMARO5 member PRICING of $2099!! PfadtRacing Suspension / Chassis / Brakes 6 10-21-2010 10:47 AM
Happy Birthday Silver Streak! RT21 Off-topic Discussions 11 04-28-2009 12:13 AM
