03-31-2019, 08:56 AM | #351 |
11" wheels and 315 tires...
The chart in the 1st post on this thread is really a great reference. I used to have 22" wheels in this size but you have to tie your E-Brake line back or it rubs. |
01-26-2021, 04:05 PM | #352 |
Drives: 2010 Camaro 2ss Black Join Date: Jan 2019
The info does help, but I need to know has anyone put 275/45/20 on the front? My rim is 20×9 for the front & 20x10 for the rear. Im trying to go with a bigger set of tires, the tire fitment should be fine but idk if the clearance is gonna be a issue? Anyone have experience or advance?? Please & thank u
01-26-2021, 04:31 PM | #353 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
I've got 275 45 20 on stock rims on the Front
Hot Wheels Emblems and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills, Hot Wheels door Sills.
01-26-2021, 08:12 PM | #354 |
01-26-2021, 09:53 PM | #355 |
Drives: 2010 Camaro V6 LT Join Date: Jan 2021
so all that being said could I run 20x10 285/35/20 on a +35 offset in the front?
Gonna do the same in the back but +25 offset for a staggered look. |
01-29-2022, 12:50 PM | #356 |
Drives: Chevrolet Camaro Join Date: Jan 2021
I went through the whole thread, but I still have one doubt:
My car came stock with 245/50R19 and I've been using Pirelli PZero Nero, but, unfortunately, the local distributor doesn't stock them anymore. Instead, they have Cinturato P7 which are almost twice the price. Besides P7 Cinturato, I could also find Michelin Primacy, I don't know the exact model. There are no other options available for this size, but there are a few options for 245/45R19 and 255/50R19. Since I would like to replace only the rear tires, do you know what would be the best combination that would not impact ABS and traction control 245/50R19(f)-245/45R19(r) or 245/50R19(f)-255/50R19(r)? |
01-30-2022, 09:53 AM | #357 | |
01-31-2022, 12:59 AM | #358 | |
In that case, the combination of 245/50 and 255/50 would be the best combination, since the difference in diameter will be 1cm, which is below half an inch. |
01-31-2022, 09:25 AM | #359 |
You are welcome sir... I'm running 285/35 front which are 27.9 dia and 335/30 rear which are 28 dia, was running 275/35 front with a dia of 27.6 with no issues, but had to raise the front up to a 285 because my front splitter was hitting some speed bumps. At one time I had the 275/35 front and 315/35 rear with the rear dia being 28.7 and the front 275/35 being 27.9 with no issues either. So that's almost 3/4ths of an inch!! So yea, you will be alright.
07-19-2023, 01:27 PM | #360 |
Drives: Chevy Impala, Buick LaCrosse Join Date: Jul 2023
I notice no one has posted to this thread in a while, and the chart at the opening is an outstanding sheet of info! I also checked out the Wiki link on the factory wheel offsets. Have those figures changed on the 2016-up Camaros? Stats on wheel-size.com list some slightly different figures but I've noticed the low offset wheels are harder to find while +30-35 seem plentiful. +35 in an 8.5 to 9.5 wheel should still clear suspension/steering parts?
02-21-2024, 10:55 PM | #361 |
Drives: 2013 SS Camaro Join Date: Oct 2018
15 inch wheels triggering trouble codes
Has anybody had an issue with installing 15 inch diameter rear wheels and all kinds of trouble lights coming on the dash? I Installed 15 inch diameter wheels on my 2013 Camaro SS and I am getting, SERVICE POWER STEERING warning on the DIC. Service Stabilitrack. No Traction control light is on. ABS light is on. Anybody have this happen and what is the fix?
02-22-2024, 10:24 PM | #362 | |
Drives: 2011 Synenergy Green 2SS/RS Join Date: Jan 2011
2011 Synenergy Green 2SS/RS Automatic.
04-21-2024, 09:42 PM | #363 |
Drives: 2012 Camaro 2SS/RS Join Date: Jul 2010
Quick question: I have Michelin PSS tires on my SS (on Forgestar F14 wheels). I this chart recommends 275/40, but my current front tires are 35. I think maybe this was because Michelin didn't make a 40? I'm thinking of getting some PS 4S tires, so would it be best to get a 40 on the front now?
Also, I want to go from 295s to 315s on the rear. Should I still stay with 275s up front? I have some Pfadt springs, and if I'm remembering right, the car is lowered about an inch. Recommended 20" tires for 2010 Camaro 245/45-20 = 28.7" tall, 8.0-8.5 wheel 255/45-20 = 29.0" tall, 8.0-8.5 wheel 265/40-20 = 28.4" tall, 8.5-9.0 wheel 275/40-20 = 28.7" tall, 9.0-9.5 wheel 285/40-20 = 28.9" tall, 9.0-10.0 wheel 295/35-20 = 28.1" tall, 9.5-10.5 wheel 305/35-20 = 28.4" tall, 10.0-10.5 wheel 315/35-20 = 28.7" tall, 10.5-11.0 wheel
04-22-2024, 12:19 PM | #364 |
When I had the MRR M228's on my Camaro, 20x10 front, I ran a 285/35, on the rears 20x11 I ran a 315/35 with no issues, lowered 1.25 on Pfadt springs. I also fitted a 335/30 MPSS on the rear wheels as well, ran them for a while, still no issues. Got new wheels, went wider, 20x10.5 front with 285/35, rear 20x11.5 with the 335/30 MPSS.. Still no issues..
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
CAMARO WIKI | Tran | Wiki | 66 | 04-22-2024 11:41 AM |
Drag Racing Suspension Kits | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 02-21-2010 08:48 PM |
The Camaro, what it has come to mean for me | Number 3 | 5th Gen Camaro SS LS LT General Discussions | 23 | 04-13-2009 09:31 PM |
Answeres to questions I have stumbled on | dieseldave24v | 5th Gen Camaro SS LS LT General Discussions | 13 | 02-23-2009 06:56 PM |
