Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 11-08-2023, 12:10 PM   #323
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
From my understanding you do not have to remove it.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS
Stainless Works Ceramic LTH/HiFlo Cats
SCT X4 Dynosteve,
Hotckis 1" Springs & Chassis Max Brace
BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings
Pedders Radius Rod Inserts Strut tower brace
Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 11-08-2023, 12:45 PM   #324
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
Just ordered a revshift insert today. I'll be able to speak on the driveline vibration as i have a 1 pc DSS aluminum shaft. Although I don't have alot of vibration with mine and i have poly diff and cradle mounts. All the old forums said the NVH would be bad, but I hardly noticed it. My tuner said that around 150mph, he did feel a vibration on the dyno.
Follow me on instagram @The_bald_eagle_machine
https://www.camaro5.com/forums/showthread.php?t=600181
Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links.
The_bald_eagle_machine is offline   Reply With Quote
Old 11-08-2023, 04:17 PM   #325
bstromback2002
bstromback2002's Avatar
Drives: 2010 camaro ss
My old mount has definitely seen better days and was definitely starting to sag.
bstromback2002 is offline   Reply With Quote
Old 11-08-2023, 04:20 PM   #326
Joe.G
Joe.G's Avatar
Wonder if that's enough to cause a change in angle for vibration purposes.
SCT X4 Dynosteve,
Old 11-08-2023, 04:24 PM   #327
bstromback2002
Possibility. Either way it’s getting the insert at the same time. Not to worried about nvh. I have bmr engine mounts and pretty much everything and anything else that was rubber is now bmr also, except the cradle bushings I just did inserts.
Old 11-08-2023, 06:33 PM   #328
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I have this DS as well, with the solid cradle mounts. After we installed it I had very little vibration at all. My stocker vibrated more. When we had it on the dyno tuning it we ran the engine up to 7500 in 4th gear for the final pull and he didn't say anything about any vibrations. I may have got a good one, so far.
1JEWLDSSRS is offline   Reply With Quote
Old 11-10-2023, 06:06 AM   #329
bstromback2002
I installed the insert in the mount and I don’t think you could just push it in there maybe if you could get a c clamp in there to squeeze it in but honestly like I said earlier as quick as it was getting the mount out of the car I think it would take you twice as long trying to get it installed in the car.
Old 11-10-2023, 08:24 AM   #330
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Were you able to press it in by hand or are pliers/hammer needed?
camguynj is offline   Reply With Quote
Old 11-10-2023, 08:59 AM   #331
bstromback2002
CF VS Aluminum Driveshafts, Pros and Cons.
It comes with some grease you rub all over it then a Rubber mallet and a couple good whacks and it slid in most of the way. Used a 1/2 extension and a hammer to get it fully seated the last 1/8 of a inch. If someone really didn’t want to take it out of the car you would definitely need to jack the transmission up if your mount was sagging as bad as mine was.
Old 11-11-2023, 11:13 AM   #332
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
Have you drove it yet to find out if it fixed your vibration issue ?
Went ahead and bought me one just in case . I’ve got my cf gc drive shaft here waiting to be installed when I get the motivation to do it
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9
Risingson05 is offline   Reply With Quote
Old 11-11-2023, 02:56 PM   #333
bstromback2002
Just got back. It’s better but still there I was starting to feel some vibration around 75 and now it’s up to about 85 and before I didn’t feel like I ever wanted to hit over 110 and I went quite a bit faster than that today. It’s definitely still there but not the way it was before.
Old 11-12-2023, 08:03 AM   #334
camguynj
camguynj's Avatar
Can you live with it or are you going to send it back to GC to have it rebalanced ?
Old 11-15-2023, 05:26 PM   #335
Anthony S
My review on the Revahift poly insert. I consider my car highly modified at this point. Compared to the poly diff bushings, cradle bushings, one piece driveshaft... the revshift poly insert by far has produced the most notable nvh of any of the mods. BUT the shifts feel more connected and stronger. I think it's a huge difference in a positive way. Those who want a butter smooth ride. Don't do it. I did have someone comment on my Instagram that in combination with BMR poly motor mounts, they couldn't get there car to shift into second with the insert installed.
Old 11-16-2023, 05:06 PM   #336
bstromback2002
Sending it back. It went out today. Super nice people down there at gulf coast. Shane said he has done some testing between his old and new balancer and a shaft has balanced perfect on his old one and once it hits top rpm on his new one there will be a vibration.
