View Poll Results: What do you think will power the Z/28? ( | |||
Small (5 - 5.5L range) high revving engine | 26 | 8.10% | |
LT1 with minor power bump (CAI, exhaust, etc) | 10 | 3.12% | |
Heavily reworked LT1, similar to the LS6 from the C5 Z06; ~500 hp | 65 | 20.25% | |
Large displacement sucessor to the LS7, ~550 hp | 129 | 40.19% | |
LT4, same as from the ZL1, CTS-v, and Z06 | 50 | 15.58% | |
'super LT4' with a bigger blower or turbos making 700+ | 31 | 9.66% | |
Other (please specify) | 10 | 3.12% | |
Voters: 321. You may not vote on this poll |
Thread Tools |
03-08-2017, 02:08 PM | #323 | |
Drives: 2015 Z/28 Black Join Date: Nov 2016
Length (From back of block to front of engine - crank pulley) 27.1 in / 688 mm Width (Across Timing Belt Cover) 30.25 in / 769 mm Width (Across Rear of Cylinder Headers) 29.1 in / 740 mm Height (From Crankshaft Centerline to Top of Throttle Body Motors) 17.1 in / 435 mm Weight (Without Accessory Drive) 498 lb / 226 kg I found this on the Corvette forum for the LS7 --- 1. crank centerline to top of intake at 18.5" 2. overall width at the outside of the exhaust manifolds at 28".
2015 Black Z/28
70 Chevelle SS396 01 M3, 88 Land Cruiser |
03-08-2017, 02:18 PM | #324 | |
Drives: 21 Bronco Join Date: Jun 2012
Guess I was imagining bigger based on pictures I have seen comparing LS motors to the coyote |
03-08-2017, 02:28 PM | #325 |
Not sure... I think my post was wrong, so, I took out my comment... It says Width (Across Rear of Cylinder Headers) and I read Width (across rear of Cylinder heads).... So, I think I added too much for the exhaust manifolds... Instead of adding 3" on each side for the exhaust, it is probably more like 1" or 2" compared to headers... So, the motor could be closer to 4" or 5" wider than the LS7
2015 Black Z/28
04-10-2017, 04:38 PM | #326 |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
Looks like plenty of room to fit a DOHC V8 90 degree power plant to me...
Swift....Silent....Deadly
04-10-2017, 07:09 PM | #327 |
Life Is Short Enjoy It!
Drives: Original Owner 15 Z/28 #934 Join Date: Sep 2016
That Mercury Racing motor even detained to 650 hp is a great solution for GM for Z/28. NA and 8,000 RPM redline. What is not to like!
04-24-2017, 10:22 PM | #328 |
Drives: 2002 ws6 Join Date: Jul 2009
NA LT5, 6.2 DOHC 575 hp
Bolt on 2002 ls1 Trans am--- 11.5 @ 121 (1.72) 2000 da
