11-05-2023, 09:00 PM | #309 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Metco with the extension, it is very close to the stock NPP exhaust.
https://www.ebay.com/itm/30463886602...mis&media=COPY https://www.ebay.com/itm/38522590986...mis&media=COPY
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
11-06-2023, 10:55 AM | #310 |
Joe G,
I have after market exhaust. Do you think this would still work. That is the loop I have been looking at |
11-06-2023, 11:18 AM | #311 |
It barely fits with stock exhaust, I know others run it with aftermarket but on mine is is very close about 1/8th inch of clearance.
11-06-2023, 02:30 PM | #312 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Mine clears an aftermarket exhaust.
Sent from my Pixel 5 using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
11-06-2023, 03:32 PM | #313 |
Mines fine there it's above the exhaust with the extension.
11-06-2023, 04:22 PM | #314 |
I’m putting mine up on the lift tonight I’ll com pare my exhaust to the pic. I genus worse case is I send it back if it don’t fit.
Thanks |
11-06-2023, 04:47 PM | #315 |
Drives: 2010 camaro ss Join Date: Aug 2021
I talked to Shane today at golf coast about my driveshaft vibration issue and he had some really good info on something to try before I pull mine out and send it to them.
He said he was talking to someone at ls fest that was telling him they were having a ton of issues with gen5 Camaros and driveline vibrations after switching to a one piece driveshaft with a manual transmission. They guy told him most of them were fixed by using a rev shift transmission insert. They are only $30. I ordered one and it will be here probably this week. I just don’t know if I’ll get it installed and a chance to drive it now till spring. We already had one snowfall and they put a ton of salt down on the main roads. Super nice guy to talk to! Sent from my iPhone using Tapatalk |
11-06-2023, 04:59 PM | #316 |
Please post back I have the insert sitting on the self. I haven't installed because I heard a lot of people complain about the NVH with them.
11-07-2023, 06:56 AM | #317 | |
11-07-2023, 07:18 AM | #318 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
IIRC, the insert just fills the voids in the soft factory mount and it did allow more transfer of noise from the bronze shifter cup in my TR6060.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
11-08-2023, 06:50 AM | #319 | |
I’m definitely willing to try it. Look at how many people you see out there with driveshaft vibrations after switching to a one piece no matter the manufacturer. Shane at gulf coast just said to try it and said either way he was willing to take mine back and try it out on there new balancer. My insert will be here today so I’m going to do my best to get it in and try it out before the weekend is over. Sent from my iPhone using Tapatalk |
11-08-2023, 10:12 AM | #320 |
CF VS Aluminum Driveshafts, Pros and Cons.
I’m going to replace the mount itself also. A new one is $37 and the rubber is starting to crack and separate from the metal part. So I guess I’m going to have to wait till tomorrow now.
11-08-2023, 10:43 AM | #321 |
Do you have to remove the mount to press in the insert?
11-08-2023, 11:58 AM | #322 |
