View Poll Results: Shifting into 2nd gear on your V6 M6? | |||
Periodic / Regular Grind | 194 | 45.97% | |
Periodic / Regular Bind | 89 | 21.09% | |
No Issue | 139 | 32.94% | |
Voters: 422. You may not vote on this poll |
Thread Tools |
06-28-2010, 03:40 PM | #15 |
Loose is Fast!
Drives: Mikes Hard Lemons Join Date: Feb 2010
Thanks for posting! Ill update the list when i get home tonight. Rolnslo thanks for the update. That gives us all some hope!
06-28-2010, 04:46 PM | #16 |
Drives: 2011 Mustang V6 Automatic Join Date: May 2010
06-28-2010, 04:55 PM | #17 |
Rolling along...
Either that or they better start making the necessary repair/replacement parts available ASAP to the dealers.
06-28-2010, 05:25 PM | #18 |
Drives: 2010 synergy 1LT camaro Join Date: May 2010
I have gear problems but mines an auto tho it is in 2nd gear that this problem is occuring almost like it is slipping then it jumps right back into gear
06-28-2010, 08:05 PM | #19 |
Drives: 2010 VR SS Join Date: Sep 2009
Add me to your list. I have to pull hard down to 2nd gear every time I shift. This can be at moderate driving to hard driving. This has happened from day one. I installed a Barton short throw and it made it feel more evident. I call it a bind because I have not ever heard a grind. I have 5500 miles on mine. I have noticed when sitting still and the clutch in, it will shift very smoothly.
06-28-2010, 08:12 PM | #20 |
And the list just keeps on growing ...
06-28-2010, 11:31 PM | #21 | |
Drives: White M6 1LT RS Join Date: Mar 2010
Ditto... Exact same problem here. When the clutch is punched in quickly it seems like it doesnt disengage, thus making the second gear shift a problem. Ordered a Barton Shifter. We'll see what happens. 2500 Miles. This is pretty annoying... I didnt just pay for a sports car that cannot be driven like a sports car. I hope GM will make this right.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! Last edited by Mach; 06-29-2010 at 09:24 AM. |
06-29-2010, 05:52 AM | #22 |
Loose is Fast!
Let me know what mileage your at when you have a chance so I can add it to the list.
06-29-2010, 09:26 AM | #23 |
MIC
Drives: 2012 SSRS 6sp man Blk Join Date: Nov 2009
See #50 in AY6 1st to 2nd grind messages
See # 50
06-29-2010, 12:01 PM | #24 |
Loose is Fast!
It did the grind going into 2 with the shop guy in the passenger seat as we left the dealership. He said pull over and let me try it. It doesn't do it again while he is driving so he dismisses it as me not being able to drive a stick.
The transmission also started making a sound at 3500rpm and up. It sounds kinda like when your garden hose isnt connected all the way. Of course it didn't do this when he was in the car.. just on the way there and on the way home... I am going to call the dealer and offer to pay the labor for them to pull the inspection cover and take a look at the gears to see whats going on in hopes that he will then find what I am feeling periodically in my commute to and from home. I am guessing it should be possible to do this in 1hr shop labor, so say $110?? Last edited by CAMAR0; 06-29-2010 at 04:09 PM. |
06-29-2010, 03:49 PM | #25 |
Drives: 2010 LS Join Date: Oct 2009
Under load 1st to 2nd gear grind from day one. Throw out bearing / input shaft bearing noise. Burning clutch smell at times. Has been back to dealer 4 times, they said it was normal and waiting for GM up dates on fix? (BS)
06-29-2010, 04:25 PM | #26 |
Loose is Fast!
I wonder if the new noise i had today was the same as your TO bearing noise? Im going to try to take some HD video of it tonight. If i have any luck picking up the noise ill post the video tomorrow.
06-29-2010, 05:19 PM | #27 |
Loose is Fast!
HOLY CRAP... THIS ISNT JUST A CAMARO ISSUE... ITS AN AY6 ISSUE PERIOD... CHECK OUT THESE LINKS WITH AY6 ISSUES ON THE TOYOTA FORUMS!!! AHHH
Re: Aisin AY6 Transmission Research? Mike, Yes we have. And we have determined that this stock transmission is CRAP. This is why after crying,throwing temper tantrums,arguing with Toyota and embarrassing ourselves doing a high RPM 1st to 2nd GRINDING gear shift that Allan Phillips is developing a T-56 swap. Why don't you join us in the group buy. http://www.customtacos.com/forum/sho...d.php?t=142459 http://www.customtacos.com/forum/sho...d.php?t=145475 http://www.xr-underground.com/forum/...ad.php?t=34962 The news just keeps getting better.... Last edited by CAMAR0; 06-29-2010 at 05:47 PM. |
06-29-2010, 05:26 PM | #28 |
Drives: 2010, 2000, 1971 Camaros Join Date: May 2010
+1 on the GRIND from 1 to 2. Only solution so far is slowing down the shift. All other gears are fine. Also have the Hurst short-throw installed. Same problem before and after.
Tags |
ay6, bind, grind, repair, swap |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
My SS Camaro's tranny sounds weird in 1st and 2nd gear. | RyanSSaddict | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 2 | 03-07-2011 02:08 PM |
HVAC issue... Anyone had this problem? | nashstat | 5th Gen Camaro SS LS LT General Discussions | 8 | 01-27-2010 04:19 PM |
Transmission output shaft | hiller72 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 267 | 12-02-2009 08:39 PM |
Will the A6 start off in 2nd gear like the vette??? | TomServo | 5th Gen Camaro SS LS LT General Discussions | 9 | 04-10-2009 09:41 AM |
Do you think it was right that the mustang got to use the trackpack in the comparison | perfxn | Chevy Camaro vs... | 91 | 03-30-2009 09:44 PM |
